Old 15th March 2007, 07:21 AM   #1
Default Accessing EEPROM
Im just starting out with the PICs. Im currently using the PIC16F628 to play with.
My objective is to make an LED controller that has multiple light patterns, etc. Thanks to Nigel Goodwin's site and others I have that part covered. I will be using a momentary switch to change the patterns. Again, that has been adequately explained.
Now I am stuck on saving the pattern. That is, I want to be able to store pattern number 8 as the startup pattern instead of having to cycle through 7 other patterns every time I start up the LEDs.
My first guess is using the 128bytes of EEPROM, however I am more than willing to entertain other suggestions. I am sure this has been addressed, however I have been unsuccessful in my attempt to find the code or tutorial applicable.
Thanks,
Clayton
Clayton is offline
Old 15th March 2007, 07:42 AM   #2
Check out Nigels tut5 - there's a eeprom read and write routine.
http://www.winpicprog.co.uk/pic_tutorial5.htm
gregmcc is offline
Old 15th March 2007, 07:56 AM   #3
Thats exactly what I was looking for. Thanks.
Clayton
Clayton is offline
Old 21st March 2007, 07:48 AM   #4
I have run into another problem. I have attempted to use the EE_Write and EE_read subroutines from the above tutorial, yet my chip doesnt cooperate. It works fine w/o the eeprom routines.
Here are the routines as I have them now, with minor modifications to meet my program:
EE_Read
bsf STATUS, RP0 ; Bank 1
movlw EEPROM_Addr
movwf EEADR ; Address to read
bsf EECON1, RD ; EE Read
movf EEDATA, W ; W = EEDATA
bcf STATUS, RP0 ; Bank 0
movwf PatternCount ; returns value of pattern
call CheckSwitch ; calls routine to select pattern
EE_Write
movfw PatternCount ; read current value
bsf EECON1, WREN ; Enable write
movwf EEDATA ; set EEPROM data
movlw EEPROM_Addr
movwf EEADR ; set EEPROM address
movlw 0x55
movwf EECON2 ; Write 55h
movlw 0xAA
movwf EECON2 ; Write AAh
bsf EECON1, WR ; Set WR bit
; begin write
btfss PIR1, EEIF ; wait for write to complete.
goto $-1
bcf PIR1, EEIF ; and clear the 'write complete' flag
bcf EECON1, WREN ; Disable write
retlw 0x00
PatternCount is my defined variable.
I have defined EEPROM_Addr as Equ 0x00.
I did not see any of the other labels being defined in Nigel's tutorial so I presume they are understood by the MPLAB IDE.
Again, I have searched around, including on this site, but I cant make heads or tails of this matter. Any and all help greatly appreciated.
Thanks,
Clayton
Clayton is offline
Old 21st March 2007, 07:59 AM   #5
You should not define EEPROM_Addr as equ 00.
You should define EEPROM_Addr to somewhere that is user RAM. Such as 0x20. You should then write zero to EEPROM_Addr.
So, at the top of your code you would have,
EEPROM_Addr Equ 0x20
Or some other address that is not used for something else.
And then in you main code you would have either,
clrf EEPROM_Addr
Or,
movlw 0x00
movwf EEPROM_Addr
HTH
Pommie is offline
Old 21st March 2007, 08:00 AM   #6
P.S. You can see if your write routine is working by putting the chip back in the programmer and reading it.
Pommie is offline
Old 21st March 2007, 09:15 AM   #7
Pommie,
I see what you're getting at. I modifed the above to look like this:
movf 0x00, w ; read current value
movlw 0x2100
movlw 0x55
movlw 0xAA
; begin write
goto $-1
movlw 0x02
movwf PORTB
retlw 0x00
As you see, I changed the address of EEADR to 0x2100. The LED at 0x02 on PORTB lights up indicating completion of the routine, but the change in not reflected when I read the chip. Any other suggestions?
Thanks,
Clayton
Clayton is offline
Old 21st March 2007, 09:17 AM   #8
BTW the above routine is the only one running in the program.
Again, Thanks,
Clayton
Clayton is offline
Old 21st March 2007, 10:14 AM   #9
So how do you expect to fit 0x2100 in an 8 bit variable?.
My tutorial routine is fully working, why not use it 'as is' to prove it works, THEN try and modify it to do exactly what you want.
Old 21st March 2007, 10:36 AM   #10
As always, Mr. Goodwin, you are doing a fine job of exposing poor PIC/electronics understanding by us new guys. Believe it or not, I do appreciate it.
As to your suggestion, I did take it. Here it is in its current version.
EE_Write
movf PatternCount, w ; read current value
movlw 0x00
movlw 0x55
movlw 0xAA
; begin write
goto $-1
retlw 0x00
As you see, not much has changed. I changed the initial f register to PatternCount and I hard coded 0x00 into EEADR instead of using a constant. Minor change, really.
Refresher on my program, I am using a table to sequence the LEDs. PatternCount is what I am using to store the counter in. Each time the switch is pressed, PatternCount is increased. I know this part is working as the LED patterns do change. However, the EE_Write is not writing this to the EEPROM. I have the Call to EE_Write immediately before the increment counter commands in the same routine. Therefore, every time the pattern is changed EE_Write should be firing and updating the EEPROM. However, that is not the case. I am hoping that either you or someone else might have an idea.
Thanks,
Clayton
Clayton is offline
Old 21st March 2007, 11:26 AM   #11
On a brief look at that I don't spot any obvious problem, what about the rest of the program?.
Old 21st March 2007, 11:41 AM   #12
Nigel,
Due to the size of the program (252 lines) I decided to email it to you. It went to the lpilsley.co.uk account.
Anyone else interested in helping, I will be glad to email other copies after I wake up this afternoon.
Thanks,
Clayton
Clayton is offline
Old 22nd March 2007, 12:37 PM   #13
Ok, I just found out how to post the code in that scrolling window. So here is the program.
;Sequence of LEDs						;
;Author Clayton Bradley					;
;This version cycles through different	;
;possibilities.  Also allows selection	;
;of a specific pattern by means of a 	;
;momentary switch 						;
;Credit due to Nigel Goodwin for various;
;routines borrowed throughout this 		;
;program.								;
	LIST	p=16F628			;tell assembler what chip we are using
	include "P16F628.inc"		;include the defaults for the chip
	__config 0x3D18				;sets the configuration settings (oscillator type etc.)
	cblock 	0x20 				;start of general purpose registers
		count1 					;used in delay routine
		counta 					;used in delay routine
		countb 					;used in delay routine
		LightVal				;the lit LED
		StrobeCount 			;Counter for number of times the LED strobes
		StrobeTimes				;number of times the LED strobes
		PatternCount			;Choose pattern
	endc
	SWPORT equ PORTB
	SW1 equ	0x00
	AllLEDs equ b'11000110'		;Just a bunch of easy to use mnemonics for the LEDs
	LeftLEDs equ b'00000110'
	RightLEDs equ b'11000000'
	TopLEDs equ b'01000010'
	BottomLEDs equ b'10000100'
	LeftXLEDs equ b'10000010'
	RightXLEDs equ b'01000100'
	LED1 equ b'00000010'
	LED2 equ b'00000100'
	LED3 equ b'01000000'
	LED4 equ b'10000000'
	PatternNumber equ 0x07
	org		0x0000				;org sets the origin, 0x0000 for the 16F628,
								;this is where the program starts running
	movlw	0x07
	movwf	CMCON				;turn comparators off (make it like a 16F84)
   	bsf 	STATUS,		RP0		;select bank 1
   	movlw 	b'00000001'			;set PortB all outputs except port 0
   	movwf 	TRISB
	bcf		STATUS,		RP0		;select bank 0
	movlw 	0x03				;moves the number 3 into StrobeTimes
	movwf	StrobeTimes			;number of times the LEDs strobe
	clrf	PatternCount		;initialize Pattern Count
;;;;;;;;;;;;;;;;;;;;;;;;;;;;Start of Program routine;;;;;;;;;;;;;;;;;;;;;;;;;;
	call	EE_Read
CheckSwitch
	call	EE_Write
CSDelay
	call	Delay_On				;allow time for debounce
	btfss	SWPORT,	SW1				;check if momentary switch has returned to open
	call	CSDelay					;if not, cycle through again
	incf	PatternCount, 0			;increase pattern count, so as to cycle through next pattern
	xorlw	PatternNumber			;check for last entry by xoring value in Pattern Number with Pattern Count
	btfsc	STATUS,	Z				;check status bit to see if set, if so, Pattern Count higher than Pattern Number
	clrf	PatternCount			;if status set, reset Pattern Count
	movfw	PatternCount			;move value of Pattern Count to W to be used in choosing from table
	incf	PatternCount			;increase Pattern Count to next value
	call 	PatternTable			;now got to Pattern Table to select the next pattern
;;;;;;;;;;;;;;;;;;;;;;;;;;CODE TO STROBE LEDS;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
Strobe_LED						;code for strobing the LEDs
	movwf 	LightVal			;moves the LED code in the W reg into LightVal for safekeeping
	movfw 	StrobeTimes			;moves the value of StrobeTimes into the W register
	movwf	StrobeCount			;moves the value to the W register into StrobeCount
StrobeLoop
	movfw	LightVal			;move LightVal into W
	movwf	PORTB				;move W into PORTB to turn on selected LEDs
	btfss	SWPORT,	SW1
	call	CheckSwitch
	call	Delay_On			;call the delay we set for LED on time
	movlw	0x00				;moves value for LEDs off into W
	movwf 	PORTB				;sets PORTB to off
	btfss	SWPORT,	SW1
	call	CheckSwitch
	call	Delay_Off			;calls the delay set for time LED off
	decfsz	StrobeCount, 1		;decreases StrobeCount, skip if zero
	call	StrobeLoop			;loops back for another flash
	retlw 	0x00				;return code
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;EEPROM ROUTINE;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
EE_Write
	movlw	0x00
	movlw	0x55
	movlw	0xAA
									; begin write
	goto	$-1
	retlw 0x00
EE_Read
	movlw 	0x00
	movwf	PatternCount		; restore previous value
	retlw	0x00
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;LED LOOPS;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
WigWag_Loop						;loop for the WigWag option
	call 	WigWag_LEDs			;calls the actual code of WigWag
	goto 	WigWag_Loop			;continuous loop
X_Loop
	call 	X_LEDs				;calls the actual code of X_LED
	goto	X_Loop
TopAndBottom_Loop				;loop for TopAndBottom option
	call 	TopAndBottom_LEDs	;calls the actual code of TopAndBottom
	goto 	TopAndBottom_Loop	;continuous loop
Sequence_Loop					;loop for Sequence option
	call	Sequence_LEDs		;calls the actual code of Sequence
	goto	Sequence_Loop			;continuous loop
ZigZag_Loop						;loop for ZigZag
	call 	ZigZag_LEDs			;calls the actual code of ZigZag
	goto 	ZigZag_Loop			;continuous loop
All_Loop						;calls a variety of flash patterns
	call 	All_LEDs
	call 	All_LEDs
	call 	WigWag_LEDs
	call 	WigWag_LEDs
	call	X_LEDs
	call	X_LEDs
	call 	Sequence_LEDs
	movlw	LED1
	call 	Strobe_LED
	call 	ZigZag_LEDs
	movlw	LED1
	call 	Strobe_LED
	goto	All_Loop
;;;;;;;;;;;;;;;;;;;;;;;;;;;;LED CALLS;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
All_LEDs						;code for flashing all LEDs
	movlw AllLEDs				;move all LEDs into W
	call Strobe_LED				;strobe
WigWag_LEDs						;code for WigWag pattern
	movlw	LeftLEDs			;move left LEDs into W
	movlw	RightLEDs			;move right LEDs into W
X_LEDs							;code for flashing an X pattern
	movlw 	LeftXLEDs			;move top left and bottom right LEDs into W
	movlw 	RightXLEDs			;move bottom left and top right LEDs into W
TopAndBottom_LEDs				;code for top and bottom pattern
	movlw	TopLEDs				;move top row of LEDs into W
	movlw	BottomLEDs			;move bottom row of LEDs into W
Sequence_LEDs					;code for sequence of LEDs
	movlw	LED1				;move top left LED into W
	movlw	LED2				;move bottom left LED into W
	movlw	LED3				;move top right LED into W
	movlw	LED4				;move bottom right LED into W
ZigZag_LEDs						;code for zigzagging LEDs
;;;;;;;;;;;;;;;;;;;;;;;;;;;DELAY CODE;;;;;;;;;;;;;;;;;;;;;;;;;;;;
Delay_On
	movlw	d'40'				;delay 40 ms (4 MHz clock)
	movwf	count1
d1	movlw	0xC7
	movwf	counta
	movlw	0x01
	movwf	countb
Delay_0
	decfsz	counta, f
	goto	$+2
	decfsz	countb, f
	goto	Delay_0
	decfsz	count1	,f
	goto	d1
	retlw	0x00
Delay_Off
	movlw	d'75'				;delay 75 ms (4 MHz clock)
	movwf	count1
d2	movlw	0xC7
	movwf	counta
	movlw	0x01
	movwf	countb
Delay_1
	decfsz	counta, f
	goto	$+2
	decfsz	countb, f
	goto	Delay_1
	decfsz	count1,	f
	goto	d2
	retlw	0x00
;;;;;;;;;;;;;;;;;;;;;LED PATTERN TABLE;;;;;;;;;;;;;;;;;;;;;
PatternTable
	addwf	PCL, f					;add W from Check Switch to the PCL to select proper pattern
	call 	WigWag_Loop
	call 	TopAndBottom_Loop
	call	X_Loop
	call 	Sequence_Loop
	call 	ZigZag_Loop
	call	All_Loop
end
Any help greatly appreciated.
Thanks,
Clayton
Clayton is offline
Old 22nd March 2007, 09:23 PM   #14
Turns out, I was having some stack overflow issues also. They never became a problem until I tried to use the EEPROM routines.
Thanks again to any and all who scratched their heads on my behalf.
Clayton
Clayton is offline
Old 22nd March 2007, 09:30 PM   #15
Presumably from using 'call' instead of 'goto' in Pattern Table?.
accessing, eeprom
Spurious write or corrupting EEPROM ??? Mr.Anderson Micro Controllers 5 19th August 2006 02:33 AM
working with eeprom pages? justDIY Micro Controllers 1 7th October 2005 10:21 AM
Writing Data to the EEPROM Electrix Micro Controllers 2 31st August 2005 07:39 AM
sequential read to AT24C01A serial EEPROM giaracam Micro Controllers 2 26th October 2004 04:19 AM
Writing to EEPROM rizzy Micro Controllers 3 27th January 2004 05:01 AM
