Old 13th March 2007, 05:43 PM   (permalink)
Default IR detector which port? RB0 (int), CCP1 or generic PIC pin?
When using a 38KHz IR detector, what type on input pin is your favourite (least software overhead)?
Bill
Smart Kits build Smart People
Old 14th March 2007, 12:59 AM   (permalink)
An interupt pin set to rising edge, unless you have a problem with noise.
straight answer, har har."
Sceadwian is offline
Old 14th March 2007, 03:14 AM   (permalink)
Good question. And one I've been comtemplating recently.
If you want to decode Sony SIRC 12, 15, and 20 bit codes and you use the CCP "capture" mode timers then how would you know if you're decoding a 12, 15 or 20 bit code? In other words, how would you know when to stop waiting for a new edge interrupt?
It almost seems better to use CCP "compare" interrupts at computed intervals to sample and filter the 2400/550 "start" bit, the 550/550 "0" bit, or the 1100/550 "1" bit and simply clock in 20 bits, though the last several bits may be null for 12 and 15 bit codes.
Is there a better way to come up with a small simple reliable interrupt driven background decoder task?
Mike, K8LH is offline
Old 14th March 2007, 04:17 AM   (permalink)
I'm using CCP1 (PWM) to run a relay, and tmr1 osc (32KHz) and will lose the CCP2. So I have to use RB0.
Bill
Old 14th March 2007, 09:37 AM   (permalink)
You're using a PWM signal to drive a relay?
Old 14th March 2007, 01:42 PM   (permalink)
PWM 100% to pull in the relay and 50% or so to keep it engaged.
Bill
Old 14th March 2007, 02:09 PM   (permalink)
That's got to be one of the most exotic uses for PWM I've come across (grin). I've used a resistor in series with a relay to accomplish something similar. When you first key the relay it sees the full voltage and as the current ramps up there's a small voltage drop built up across the resistor. Of course this wastes power on the resistor while your scheme is conserving energy quite nicely.
Old 14th March 2007, 02:20 PM   (permalink)
If you place an electroytic capacitor across the resistor the charging current will provide a full voltage pulse to the relay, then after it's charged the resistor will provide the holding current - fairly standard practice!.
Need help badly on Inchworm and MPLAB thushy Micro Controllers 14 11th March 2007 07:05 PM
Newcomers, please read! (PIC regarded) Upd. 0xD Jay.slovak Micro Controllers 0 17th April 2005 02:05 PM
