Old 12th March 2007, 09:40 AM   (permalink)
Default Problems with pic programmer
Hi
i build a jdm, with an indipendent power supply, to program PIC. As interface i've used a DB9 serial port but i've got some problems with my USB - DB9 serial convertor. In fact my programmer work fine with the serial port of an old PC but it won't work with a USB-Serial converter (my main PC has only usb port). I've done some research over internet and more people seem to have the same problem with this kind hardware, could u give me a more information about that? Is there a programmer that works fine using a usb-serial convertor?
AcmeMan is offline   Reply With Quote
Old 12th March 2007, 10:30 AM   (permalink)
I've also had problems using a JDM programmer and a USB - Serial converter.
I now use a PicKit2 programmer, and a couple of ZIF adapter boards that I built. It works fine for all the PIC micros I use.
clicky clicky the link for more info :
http://www.microchipdirect.com/produ...words=DV164120
Shax.
A bus station is where a bus stops...
A train station is where a train stops...
On my desk I have a work station...
Nuff Sed!!!
Shax is offline   Reply With Quote
Old 12th March 2007, 10:40 AM   (permalink)
I'd like to build the programmer by myself. Could u post the scheme?
Old 13th March 2007, 09:45 AM   (permalink)
I've read over internet that Velleman programmer works fine with the usb-serial convert, is there someone that could confirm that?
Old 13th March 2007, 09:53 AM   (permalink)
The only way to be sure is to use a real serial port programmer, like the InchWorm - you NEED a processor on board for a serial port programmer. JDM style programmers, that connect to the serial port (but don't use it) simply waggle the handshake lines - this doesn't transfer well through most USB/Serial converters.
Old 13th March 2007, 10:02 AM   (permalink)
InchWorm? Could u give me a link?
Old 13th March 2007, 10:13 AM   (permalink)
Just search in this forum!.
Old 13th March 2007, 10:26 AM   (permalink)
On the contrary, if you read Velleman's own product pages and forums for their K8048 and K8076 PIC programmer devices you will see that they explictly state that usb-serial convertors are not supported and that a real serial port is required.
DeeJay is offline   Reply With Quote
Old 13th March 2007, 10:33 AM   (permalink)
I've just found this document:
http://www.electro-tech-online.com/a...f?d=1157519728
it seems that the difference between classical jdc, or other programmer it's just the max232 that normalize the voltage level. So could i just add a max232 to my jdm programmer to obtain a result?
Old 13th March 2007, 03:00 PM   (permalink)
I use a parallel port (LPT) programmer P16PRO,
its work very reliable
taner is offline   Reply With Quote
Old 13th March 2007, 03:17 PM   (permalink)
akg
the jdm requires the higher level voltages from an rs232 , hence it may not work with laptops and usb adapters
Gods own Country
Incredible !ndia
www.flickr.com/photos/_akg/
"Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime."
akg is offline   Reply With Quote
Old 13th March 2007, 03:52 PM   (permalink)
I think it's safe to say that if you don't have a real serial port (ie - a desktop serial port, not a laptop or a usb-serial adapter), you might as well forget about using a JDM. You might be able to find the some way to make it work with some "band-aid" circuitry, etc, but you're pretty much guaranteed to endure a lot of headaches in the process, and probably still won't end up with a reliable programmer in the end.
There are other options out there, ie - parallel programmers, PROPER serial programmers (that don't draw power from or otherwise abuse the serial port), and USB programmers... JDM serial programmers are almost invariably the cheapest option, but they're still a waste of time and money if they simply won't work for you because of your computer hardware, so you might as well look into more suitable options, even if it costs slightly more.
EEgeek.net
evandude is offline   Reply With Quote
Old 13th March 2007, 05:04 PM   (permalink)
My programmer it's like your but i have used the serial port instead of parallel. I think that i'll try the way of max232 and at least i use the parallel port.
Building First Pic Programmer Bryan76 Micro Controllers 50 6th February 2007 04:45 PM
PIC Programmer using C burg General Electronics Chat 2 24th January 2007 07:26 AM
Stupid PIC problems ArtemisGoldfish Micro Controllers 2 21st January 2007 01:17 PM
Newcomers, please read! (PIC regarded) Upd. 0xD Jay.slovak Micro Controllers 0 17th April 2005 01:04 PM
Problems with CPLD programmer Snowman Electronic Projects Design/Ideas/Reviews 22 14th December 2003 02:45 AM
