Old 19th March 2007, 02:31 PM   #46
Originally Posted by gramo
Did you change the voltage divider to use 2.5K resistors?
Perhaps it’s meant to be the voltage difference between the two wires, or just the one on the right, I have no idea as I don’t have your manual.
I didn't change because the voltage divider for gear indicator is working perfect with 10K resistor.
My problem now is the signal from the speed sensor to digital speed indicator.
I post previously an attached circuit that I'm going to use to try to lower the voltage signal to 5 V because I think that's is the problem.
Kiko is offline
Old 19th March 2007, 03:17 PM   #47
You don't need the 2 diodes as the pic has identical diodes built into it's input pins. Just try a simple RC filter first and see how that works out. I think 100k (+10K) is probably too high to start with. As your only going to 300Hz then 10k and 0.1uf is probably a good starting point.
Pommie is online now
Old 19th March 2007, 08:28 PM   #48
But do I have to lower the voltage peak to 5V?
Kiko is offline
Old 20th March 2007, 01:14 AM   #49
The 10K resistor should take care of that.
Old 20th March 2007, 02:11 AM   #50
Ok I have finished to do that and with the bike on the jack the speedo is working great, no problem anymore, and tomorrow I'll test on the road...
Thank you
ps. I have not finished. I have lot of questions coming to finished this project.
Thank you very much
Kiko is offline
Old 20th March 2007, 06:56 AM   #51
Geez, my bad, I was thinking that the speed was ADC based, sorry
digital-diy.com - Hobby microcontroller projects and tutorials. Assembly, PICBasic and C examples.
gramo is offline
Old 20th March 2007, 03:13 PM   #52
No problem at all as your help was very valuable to me.
So I made a road test today and the gear indicator is working perfect and the speed indicator is working nice and smooth but at high speed I have some indication discrepancy that is proportional to speed but I think I can fix it changing the values of RC filter (Am I correct?).
I think now we have here, with help from you guys, a very good starting point for people who want to make a project like that.
All I can say is thank you very much.
By the way, do you have or know any guide that I can use to change the alpha LCD to graphic LCD using proton+ basic?
Rgds
Kiko is offline
Old 22nd March 2007, 03:28 PM   #53
Hi there,
This is fascinating, I'm trying to do the same thing with a 16F876A and my Yamaha (it doesn't have a Gear Position Indicator so just speed).
Kiko could you post your completed schematic because I'm at the stage now where it works on the bench but I fear I may encounter the same problem you had.
Cheers Rik
quickrik is offline
Old 24th March 2007, 12:19 AM   #54
Originally Posted by quickrik
Hi there,
Cheers Rik
Sure don't worry. I will post as soon as I fix my computer because I had a little problem with it and I'm reinstalling everything in it. But the speed and gear indicator is working perfect.
Since my main goal is to make one with graphic LCD display, I'd like to hear from you guys the display conections as well as the main code (Proton+ Basic) and if it's necessary to use an external eeprom.
I'm using KS0108 display driver...
Tks
Kiko is offline
Old 24th March 2007, 07:30 AM   #55
Hi there,
Cheers Rik
If you add an RPM pickup you could do the Gear Position Indication using a little math.
D.
danci1973 is offline
Old 24th March 2007, 10:34 AM   #56
D.
Only if the clutch is out . I do like that idea though. You could display speed, RPM and gear with just the 2 signals.
Old 24th March 2007, 12:50 PM   #57
I think it can be done. Just the update might have a little delay while debouncing/calculating the shifts and RPMs.
Now what to do if you are idle at a stop light. I used to stop and then down-shift into first at times. So you would not get a gear update until moving again.
mramos1 is offline
Old 24th March 2007, 02:35 PM   #58
Could you please post the maths? This way the QUICKRIK can start his project.
Kiko is offline
Old 24th March 2007, 02:51 PM   #59
Attached is the schematic that I used, with help from you, for my bike Speedometer and Gear Indicator.
It's working perfect but as I sad before I'd like to use a graphic LCD instead.
Thank you
Kiko is offline
Old 25th March 2007, 10:37 AM   #60
hi guys i'm triyng to find a schematic for gear indicator for my gixxer that take signal from speed and rpm signl (plus neutral light for zero) but it seems that it doesn't exist anywhere... do you have any idea?
fxvxca is offline
speedometer
digital speedometer using AT90S2313 fever Micro Controllers 57 29th January 2008 07:45 PM
Speedometer Project Help ADAM117 Electronic Projects Design/Ideas/Reviews 2 8th December 2006 06:00 PM
Pulse divider for a Speedometer spestis Electronic Projects Design/Ideas/Reviews 3 25th July 2006 03:17 AM
Tachometer and Speedometer replies Kiko Micro Controllers 0 26th April 2004 01:57 AM
Electronic Speedometer using stepper motor roryp General Electronics Chat 6 10th April 2003 01:06 PM
