I'm taking the ground from somewhere in the instrument cluster.Originally Posted by danci1973
I'll try to change the ground...
See attached the bike's diagram
Thank you
Thank you
Heres your real life data:Originally Posted by Kiko
As they overlap, I had to find the "Middle" between each set. Take the First Gear for example:1st gear = 1.243v to 2.586v
2nd gear = 2.124v to 3.210v
3rd gear = 3.178v to 3.486v
4th gear = 3.633v to 4.400v
5th gear = 4.215v to 4.887v
6th gear = 4.461v to 4.942v
Neutral = 4.678v to 5.245v
1st 1.243v - 2.586v
2nd 2.124v - 3.210v
Now the "Overlap" from 1st too 2nd is 2.586 minus 2.124 = 0.462V
As I now know how much they overlap by, I simply divide this by 2 so I can split the overlap evenly 0.462 / 2 = 0.231
And now add that value to the lower voltage 2.124 + 0.231 = 2.355
There you have it - the "Middle" point for the overlap between gears
I did however modify the gap between 2nd to 1st as it was not the same (too small) and figured it was a miss read
I said i modified 2nd to 1st, I meant 2nd to 3rd
Ok I understood, but one more question my friend, in your simulation you told the voltages (sine wave) for each gear are 10khz from min to max, Why? and don't you think it's better to put a little delay between the readings for speed because as it's a digital reading any little change on the speed will be displayed on LCD but not on the original speedometer?Originally Posted by gramo
Rgds
I chose a frequency of 10K as a random "out there" number, to simulate noise from other devices on motorbikes circuits, it could be much less that.Originally Posted by Kiko
There is no delay in the routine - as I 'average' multiple samples with the following code
This way, I can average out and slew noise from my final result. Lets say for example my 15 readings were the following (The bike is in 1st gear):Code:Result = 0 Total = 0 X = 0 Repeat Result = ADIN 0 Result = Result * 2 Total = Total + Result Inc X Until X = 15 Total = Total / 15 Total = Total * 5 / 1023
1.25, 1.0, 2.3, 2.7, 1.1, 1.5, 1.7, 1.77, 1.79, 1.2, 2.4, 2.45, 1.5, 1.6, 2.8
The samples in bold were "out of range" and could have been produced from noise/spikes from else where in the motorbikes circrtry.
But as I have taken 15 samples, I can now find the average.
So all those numbers added together gives: 27.06
The average is 27.06 / 15 = 1.804 Volts
And this 'filters' out the noise - no need for a delay persay - the time that 15 samples takes is the delay. If you find that this speed is too fast, then put a simple delay in the repeat loop, eg
And that will help generate a broader time scale for your samplesCode:Result = 0 Total = 0 X = 0 Repeat DelaymS 1 Result = ADIN 0 Result = Result * 2 Total = Total + Result Inc X Until X = 15 Total = Total / 15 Total = Total * 5 / 1023
Looks similar to my bike's diagram. Does your bike have three wires to GPS (gear position switch)?Originally Posted by Kiko
The voltages from the gear position switch should be 'stable' and pretty much spot on as the ECU is using those to choose different ignition and/or fuel maps for first three gears (to prevent 'accidental' wheelies, I guess) and to enforce a speed limit in the top gear (on the GSXR-1000 and Hayabusa).
D.
OK as we say down here in Brazil "living and learning", so can I do the same with speed code below (your code)?Originally Posted by gramo
KMHT=Counter PORTC.7, 500 ' I increased the value of period from 250 to 500 but the reading still too sensitive
If KMHT=0 Then Goto Display_speed
Temp_Float=KMHT
Temp_Float=(Temp_Float*2)*8 ' I round 7.2 to 8 which gave me a more accurate speed reading
KMH=Temp_Float/10
KMHT=KMH
Display_speed:
If KMH_Last<>KMHT Then
Print At 1, 1, DEC3 KMHT
KMH_Last=KMHT
EndIf
GoTo Start
Thank you again for your valuable help
Yes sir, it has 3 wires and I took the signal from "P" wire near the ECU connector as you can see on the diagram. And as I post before I'm almost sure I have a GPS or generator or regulator problem, first because the voltages overlaps and second because on the bench the circuit works very nice and the only thing I can see strange on this bike is that it drinks a lot of fuel and it's fast, so it may be a indicative of GPS problem and because of that the ECU chose a higher gear (5th) to deal with. I don't know...
I don't think the Suzuki TL1000 has a speed limit but I'm sure it has a RPM limit above 10500 RPM with load.
Thank you
Just for information, I changed the ground of the circuit that I took from somewhere of the instrument cluster and now the circuit is very stable, so the problem was GROUND. The Gear indicator is working perfect... But not the speedometer that when I turn the ignition ON it shows me 10 Km/hr and in 30Km/h shows 60Km/hr and so on, with more speed the difference between analog and digital increase.Originally Posted by danci1973
I had to change the resistors of the voltage divider from 1k to 10k because with 1K the voltage on the lcd indicator drop about 1.5 Volts.
Change the number of samples too 100 like I did above, you could even go higher, but it will slow down your program. This should help smooth the SpeedoCode:Result = 0 Total = 0 X = 0 Repeat DelaymS 1 Result = ADIN 0 Result = Result * 2 Total = Total + Result Inc X Until X = 100 Total = Total / 15 Total = Total * 5 / 1023
Leave 7.2 in this part, dont round it
The issue with the miss reading could be the impedance is too high for the ADC circuitry in the PIC. The datasheet specifies 2.5K Max impedance. This is to allow the internal capacitors on the PIC to charge and discharge properly, try use 2.2K resistors on the voltage divider.Code:Temp_Float = KMHT Temp_Float = Temp_Float * 4 * 7.2 KMH = Temp_Float / 1000 KMHT = KMH
Let me know if that helps![]()
OK so let me try to explain what the problem is now:Originally Posted by gramo
I'm not having anymore problems with the gear indicator so when I changed the ground the problem has been fixed. The gear indicator is working perfect.
When I power the circuit installed in the bike the speed indicator is zero as the bike is stoped (no speed).
When I start the engine the speed indicator shows 10km/hr but it's not smooth and with the increase of the speed it shows incorrect readings like I posted before.
The speed sensor this bike uses is attached as reference, please see if I took the signal from the correct wire.
Did you change the voltage divider to use 2.5K resistors?
Perhaps it’s meant to be the voltage difference between the two wires, or just the one on the right, I have no idea as I don’t have your manual.
Am I right in thinking that the ADC part is working correctly and the problem is with the pulsed speed input?
Assuming I'm correct on the above assumption, it sounds like you are getting noise interference. Try connecting a 1K resistor from the sensor to the pic and a 0.1uF capacitor from pic to ground. If you still get noise then increase the capacitor , if you get no reading then reduce it. If it only works at certain speeds then post back.
Yes Mike you're right... I'll try to do the following (attached) see if you agree.
What's the max signal amplitude that the PIC can deal with? Because the signal from speed sensor is 0 to about 300 hz 12 Volts pulsed and I think the circuit attached is going to lower the pulsed voltage to 5 V.
