Old 8th March 2007, 02:51 PM   (permalink)
Default Guitar Tuner Circuit with ATMEL AT90S2323 Help
I will do this guitar tuner project in the attachment. My questions are;
1-) How i will convert GTUNER.C codes into .HEX or .ASM? or What can I do to program my Atmel microcontroller with which codes (.c , .asm , .hex)?
2-) I will also do a simulation of it. Proteus is good at it. But how I will make a real-time simulation with Proteus? for example, in simulation are there any leds that are lit up when sending signal?
Thank you...
Zedone is offline
Old 8th March 2007, 03:19 PM   (permalink)
You need a C compiler to compile the program to a .HEX file (preferably the same one the author used), then a programmer to get the .HEX file into the chip.
Can't help you with simulators, I never use them - but is Proteus an Atmel simulator?.
Old 8th March 2007, 07:24 PM   (permalink)
He mentioned the AVR-GCC on some of his other projects. You can see if that will compile the source (.c) to your .hex file.
I think he has a (yaap) programmer circuit on his home page as well, it can write the .hex for you to the chip for you if it does the 2313.
mramos1 is offline
Old 12th March 2007, 12:04 PM   (permalink)
proteus is a general simulation software that includes MICROCHIP PIC series, Atmel series, and any other things. But I dont know how to simulate that project even if i draw it in Proteus.
Zedone is offline
Old 12th March 2007, 12:20 PM   (permalink)
i overcomed this problem with WinAVR compiler. thank you.... But on the other hand, i have a problem too. Here I couldnt find AT90S2323 in the shops. So I have to change it with AT90S2313 that is found easily.
****The question****
How can I replace AT90S2323 with At90S2313 in the circuit? Does anybody know the pin connections of it? At least, i am thinking that a more-advanced Atmel (at90s2313) may have another Atmel (at90s2323) in it.... Any idea?
Zedone is offline
Old 12th March 2007, 09:34 PM   (permalink)
The atmel.com website said the Tiny25 was to replace that chip. The 2313 is not an 8 pin chip, but it can probably be made to work as well, unless there is a large RAM requirement and ADC.
I would read the datasheets.
If you try to used the 2313, you will just match up the pin names. I did not see anything special about the 2323.
I thought about moving it to the PIC chip, but did not want to install a C compiler. My sons have guitars.
mramos1 is offline
Question about HT 8870 in the TELESWITCH circuit !?! zambalik General Electronics Chat 11 6th September 2007 01:11 PM
Bass guitar tuner help dennisM Electronic Projects Design/Ideas/Reviews 11 18th April 2006 12:29 PM
Where can I get a guitar tuner built? Josephhh Electronic Projects Design/Ideas/Reviews 0 2nd September 2005 03:53 PM
555 Monostable 2 second output circuit Help Turbo Boss Electronic Projects Design/Ideas/Reviews 2 3rd August 2003 06:41 PM
Guitar Tuner eddie Electronic Projects Design/Ideas/Reviews 1 2nd February 2003 03:28 PM
