I am using Inchworm to program My targeted Microcontroller, my targeted microcontroller is also PIC16F877A.
I write this program in Assembly Code:
;**********Declaration & Microcontroller configuration************** Processor 16F877A #include "P16F877A.INC" __config 0x3F3A ;*******************Declaration of Variable************************* cblock 0x20 CounterA CounterB CounterC endc ;******************Program memory structure************************* org 0x0000 goto main ;************************Main Program******************************** main movlw b'00000000' movwf TRISC Program movlw b'00000000' movwf PORTC call Delay movlw b'11111111' movwf PORTC call Delay goto Program ;Endless loop Delay ;PIC Time Delay = 0.3130012 s with Osc = 20.000000 MHz movlw D'8' movwf CounterC movlw D'248' movwf CounterB movlw D'106' movwf CounterA loop decfsz CounterA,1 goto loop decfsz CounterB,1 goto loop decfsz CounterC,1 goto loop return END Code:
Clean: Deleting intermediary and output files. Clean: Deleted file "LED.err". Clean: Deleted file "E:\Projects\LedTest\LED.cod". Clean: Deleted file "E:\Projects\LedTest\LED.hex". Clean: Deleted file "LED.lst". Clean: Done. Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F877A "LED.asm" /l"LED.lst" /e"LED.err" Message[302] E:\PROJECTS\LEDTEST\LED.ASM 21 : Register in operand not in bank 0. Ensure that bank bits are correct. Loaded E:\Projects\LedTest\LED.COD. BUILD SUCCEEDED: Wed Mar 07 22:58:48 2007 Code:
MPLAB ICD 2 Ready Erasing Target Device... ...Erase Succeeded MPLAB ICD 2 Ready Blank Checking... ...Program Memory .. Config Memory ...EEPROM ...User ID Memory ...Blank Check Passed MPLAB ICD 2 Ready Programming Target... ...Validating configuration fields ...Erasing Part ...Programming Program Memory (0x0 - 0xB7) Verifying... ...Program Memory ...Verify Succeeded Programming Configuration Bits .. Config Memory Verifying configuration memory... ...Verify Succeeded ...Programming succeeded 07-Mar-2007, 22:51:58 MPLAB ICD 2 Ready Where is the mistake??? |
wish mine was working
did you release it from reset? what does your target circuit look like? Last edited by williB; 7th March 2007 at 05:43 PM. |
I would check the configuration word.
To run a PIC
you need to power the chip apply 5V to mclr to keep it out of reset it must oscillate (with a clock chip or a crystal) and the LED circuit must be hooked up correctly. if all this is correct , maybe it is blinking too fast to see |
I am using Firefly Z.........ZIF only to program PIC16F877A.
What williB said.
Then use the Inchworm as an debugger(not programmer) to program, then try to step through you code. If you do not know what I am talking about check out the Microchip doc on MPLAB and debugging Esp chapter 5 on ICD. http://ww1.microchip.com/downloads/en/devicedoc/51331B.pdf |
spouse i have a hex file compiled from another compiler(Mikrobasic) & want to feed this hex file into my targeted controller(PIC16F877A)..... how can i do this using inchworm???????????????????
Thanks to the Lord Allah........
Problem solved... There is a little mistake in program, i didn't select proper Banks for Registers. Below is the correct program, Code:
;**********Declaration & Microcontroller configuration************** Processor 16F877A #include "P16F877A.INC" __config 0x3F3A ;*******************Declaration of Variable************************* cblock 0x20 CounterA CounterB CounterC endc ;******************Program memory structure************************* org 0x0000 goto main ;************************Main Program******************************** main banksel TRISD movlw b'00000000' movwf TRISD Program banksel PORTD movlw b'10101010' movwf PORTD call Delay movlw b'01010101' movwf PORTD call Delay goto Program ;Endless loop Delay ;PIC Time Delay = 0.3130012 s with Osc = 20.000000 MHz movlw D'8' movwf CounterC movlw D'248' movwf CounterB movlw D'106' movwf CounterA loop decfsz CounterA,1 goto loop decfsz CounterB,1 goto loop decfsz CounterC,1 goto loop return END |
File / Import "filename.hex" That's it, PICBASIC Pro can be integrated into MPLAB |
I have a HEX file named LEDS.HEX in my computer want to feed this file into PIC16F877A using inchworm.
1. I open MPLAB 2. I press File>Import, then i select my desired HEX file 3. OUTPUT windows is showing in Build tab Quote:
Ayne ,
if you just want to see it 'in memory ' click on the View tab , then click 'program memory' |
| DSpic compiler and programmer | jrz126 | Micro Controllers | 31 | 20th April 2008 10:03 PM |
| PIC Programmer using C | burg | General Electronics Chat | 2 | 24th January 2007 07:26 AM |
| Getting started with PIC programming and building the Inchworm | Hedos | Micro Controllers | 3 | 30th November 2006 02:44 AM |
| Using C or Assembly? | rkim01 | Micro Controllers | 2 | 5th July 2006 02:06 PM |
| Newcomers, please read! (PIC regarded) Upd. 0xD | Jay.slovak | Micro Controllers | 0 | 17th April 2005 01:04 PM |
