| hi Can any body help me?? i need circuit description for interfacing a dc motor with 8051 uc! | |
| hi aabbas how r u what u actually wana do to a dc motor by interfacing with microcontroller | |
| hi abbas, What type of motor do you want to interface? Example: 12Vdc requiring say, 100mA ? Do you want to control its speed or just stop and start it? EricG | |
| [quote=ericgibbs;201365], i want dc motor controlled through 8051. Example: 12Vdc requiring say, 100mA ? Do you hav a prj to control its speed or just stop and start it? | |
| hey!! you have the same name as me how do you intend to control it?using pwm i guess or you just need to turn it on and off? OR this is a hardware question?
__________________ i would explain it to you but it would make your brain explode! Last edited by silvarblade; 27th October 2008 at 09:14 AM. | |
| [quote=Muhammad Saeed Anwer;658932] Quote:
You should decide on the motor control you require . Start/Stop is a simple medium power drive transistor, the transistor base being switched by a 8051 output, via a base resistor. For Start/Stop and simple reversing a 'H-bridge' is normally used, controlled by ON/OFF Fwd/Rev signals from the 8051. For the above and SPEED control a 'H-bridge' driven by the 8051 using PWM control signals.. Which is it.?
| Hi Eric, that is correct, I'd like just to add that if bidirectional control is not needed, a MOSFET transistor can be used. There are "logic-level" N-channel MOSFETs (for example RFP3055LE) that can be controlled directly by a logic output. Simple and better solution than a BJT. Petr | |
| Not to hijack this thread, however I have a question that I believe is in line with this topic so I thought I'd ask it here instead of starting a new thread. What would you recommend for controlling the speed of a higher current DC motor? The motor is a 100W MY68 model (24V and rated for 6A, 2300 rpm) and I would like to be able to reverse the direction of rotation. I am thinking about using the PWM module on a PIC18F4550 (or any PIC with PWM capabilities for that matter) and a few power Mosfets in an H-bridge configuration. The problem is I believe sizing components carefully so the system is reliable long term and using adequate protection so that I won't have any components die because of excessive current/heat. | |
| Lots of examples: Motor, Coil, Relay, and LED Drivers | |
| hi silvarblade! thanks 4 guiding. i m located at Karachi, Pakistan. what about u? i need code of this prj but when u insert rpm motor will rotate at this speed? i now about its diagram but problem of its code of controlling the duty cycle which is responsible for increasing the speed of motor. plz help me. again thanks to all 4 guiding. | |
| interfacing 8051 to a gsm phone | simrantogether | Micro Controllers | 7 | 7th August 2008 07:50 PM |
| need urgent help on interfacing USB bluetoothdongle wit 8051 | prasaddinkar | Micro Controllers | 6 | 24th January 2006 12:46 AM |
| interfacing DS-12887 and PCF8591 with 8051 | useant | Electronic Projects Design/Ideas/Reviews | 0 | 28th August 2005 04:01 AM |
| ADC 0809 interfacing with 8051 | infinity | Micro Controllers | 3 | 3rd May 2005 09:03 PM |
| interfacing 16*16 matrix display with 8051 | pmphilip | Micro Controllers | 0 | 1st February 2005 04:47 AM |
