Old 1st March 2007, 01:28 PM   (permalink)
Default Floppy disk interfacing...
I would like to experiment by interfacing a floppy drive to a micro-controller systems...
I would like some advice on this....
The two ways that I know this can be done is by
1. FD Controller
2. Direct control by my controller.
Which is a more prefered way? In terms of the economy? Do FD Controllers cost more than a controller with i2c bus?
I am willing to use a 2nd controller if all IO lines of one get used for the floppy disk controlling operations...
Bharath Bhushan Lohray.
M.Sc. Electronics.
lord loh. is offline
Old 1st March 2007, 04:07 PM   (permalink)
If you search the PICList archives there's been a LOT about attempting this over the years, generally it's been considered as too complicated and not worth doing. This is even more true now, with floppies essentially obselete, and cheap memory cards far easier to interface and much larger than a floppy.
Old 1st March 2007, 04:25 PM   (permalink)
Years ago I was employed in the disk drive industry. I agree with Nigel. Designing and building a read/write chain for MFM encoding and decoding is not for the faint of heart. IC controllers from Western Digital like the 1771 and the 1791 were a step in the right direction, but were not complete solutions.
I'd suggest you study the circuits used in the Apple II which essentially avoided what were at the time very expensive chip choices. Their approach had some problems like variable density recording, but it was good enough for the times.
Papabravo is offline
Old 2nd March 2007, 08:26 AM   (permalink)
Ah, yes. Apple "soft sector" disks (grin).
Mike, K8LH is offline
Old 2nd March 2007, 12:21 PM   (permalink)
Why not just use SD/MMC cards, Proton+ has simple commands to interface with them, and they generally hold much more data, and are much more robust
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
Old 2nd March 2007, 04:02 PM   (permalink)
There was a guy somwhere on the net, who used an old ISA I/O card to controll the floppy drive, but I'm not able to find the link.
szabi is offline
Old 3rd March 2007, 01:15 AM   (permalink)
It was nice to here MFM again (bet I still have a pair of cables in the garage).
But I agree that SD would be a better direction (not knowing what you are trying to do). I just bought four 2gig MINI SD with SD sockets for $48 plus shipping (US).
Mind you floppy drives are $5 here in the US, but still all the work and overhead.
mramos1 is offline
Old 3rd March 2007, 02:51 AM   (permalink)
If you want to work with floppy drives (especially of the 3.5" type) then you should probably go for Macintosh drives from the early to mid 90's, their connectors used only 12 or so pins. Good luck, I guess.
ArtemisGoldfish is offline
Old 3rd March 2007, 12:51 PM   (permalink)
Default Thank you...
Thank you...
My question was not so much technical... I wanted some wise advice and I got it...
Thanks again...
M.Sc. Electronics.
Floppy drive interfacing penoy_balut Electronic Projects Design/Ideas/Reviews 5 13th September 2006 09:24 AM
MMC card reader using floppy disk cable William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 1 12th September 2006 11:01 PM
interfacing microcontroller to floppy drive froten Micro Controllers 16 18th July 2006 11:57 PM
Reading a floppy disk manually mstechca General Electronics Chat 25 21st August 2005 10:33 PM
