Old 1st March 2007, 12:55 PM   (permalink)
Default Is the program OK?
;by joseph
STATUS EQU H'03' ;STATUS REGISTER
TRISB EQU H'86' ;TRISB REGISTER FOR SETUP OF PORTB
PORTB EQU H'06' ;PORTB REGISTER TO DRIVE PORT B
COUNT1 EQU H'0C' ;COUNT VARIABLE 1 IS IN GENERAL PURPOSE REG 08H
COUNT2 EQU H'0D' ;COUNT VARIABLE 2 IS IN GENERAL PURPOSE REG 09H
;***SET UP PORT B IN & OUTPUT****
BSF STATUS,5 ;SWITCH TO BANK0 TO SET UP PORT B
MOVLW B'11110000' ;RB7,6,5,4 IS INPUT
MOVWF TRISB ;RB3,2,1,0 IS OUTPUT
BCF STATUS,5 ;SWITCH BACK TO BANK0 TO USE PORT B
;***MAIN PROGRAM****
START MOVLW B'00000101' ;MAKE RB0&2 HIGH: MOVE FORWARD
MOVWF PORTB ;
MOVLW H'FE' ;RESET COUNT1 TO 254
MOVWF COUNT1 ;
MOVLW H'FE' ;RESET COUNT2 TO 254
MOVWF COUNT2 ;
BTFSS PORTB,4 ;
CALL LEFT ;EXECUTE LEFT ROUTINE
BTFSS PORTB,5 ;CENTER
CALL LEFT ;LEFT ROUTINE
BTFSS PORTB,6 ;
CALL RIGHT ;RIGHT ROUTINE
BTFSS PORTB,5 ;LEFT AND CENTER
BTFSS PORTB,4
CALL RIGHT
BTFSS PORTB,6 ;RIGHT AND CENTER
BTFSS PORTB,5
CALL LEFT
BTFSS PORTB,6
BTFSS PORTB,5
BTFSS PORTB,4
CALL STOP
GOTO START ;RETURN TO LABEL START
;***BACKLEFT ROUTINE****
LEFT MOVLW B'00001010' ;MAKE RB1&3 HIGH: MOVE BACKWARD
MOVWF PORTB ;
CALL DELAY ;
MOVLW B'00001001' ;MAKE RB2&3 HIGH: ROTATE LEFT
MOVWF PORTB ;
CALL DELAY ;
RETURN
;***BACKRIGHT ROUTINE****
RIGHT MOVLW B'00001010' ;MAKE RB1&3 HIGH: MOVE BACKWARD
MOVWF PORTB ;
CALL DELAY ;
MOVLW B'00000110' ;MAKE RB2&3 HIGH: ROTATE RIGHT
MOVWF PORTB ;
CALL DELAY ;
RETURN
;******BACKWARD......RIGHT**********
STOP MOVLW B'00001010'
MOVWF PORTB
MOVLW H'EE'
MOVWF COUNT1
DECFSZ COUNT1,1
MOVLW H'EE'
MOVWF COUNT2
DECFSZ COUNT2,1
GOTO STOP
CALL RIGHT
DELAY MOVLW H'EE' ;RESET ALL COUNTER VARIABLES
MOVWF COUNT1
MOVLW H'99'
MOVWF COUNT2
LOOP1 CLRWDT ;RESET THE WATCHDOG TIMER
DECFSZ COUNT1,1 ;this is a delay loop
GOTO LOOP1 ;tuned to make Cerberes
DECFSZ COUNT2,1 ;turn about 90 degrees
GOTO LOOP1
RETURN
END;
I modified the program cerbres robot. and I used LDR as my sensor.Is the program ok?
paparts is offline
Old 2nd March 2007, 04:31 AM   (permalink)
You have too much sensors connected.
You paste the code inside the rap tags in the advanced mode.rap tags ????? # radio button.So its easy to read.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 2nd March 2007, 08:07 AM   (permalink)
Eww, assembler hehe
Spency.
PIC Micro's - Your mind is the limit
PIC's and interfacing with other devices - a PIC Basic Guide @ digital-diy.net
gramo is offline
program for writing and testing circuits luca-deltodesco General Electronics Chat 3 13th August 2006 11:17 AM
little help with my program please - simple count loop kud0s Micro Controllers 5 7th July 2005 10:40 PM
Tough assembly program for the PIC16F84 asmpic Micro Controllers 34 3rd December 2004 07:50 PM
PicBasic Keypad program Sora Micro Controllers 0 20th April 2004 08:02 PM
Program Verify on JMD with ic-prog monkeyxp Micro Controllers 2 2nd November 2003 12:56 PM
