Old 26th February 2007, 10:08 AM   (permalink)
Default i need a micro controller for signal processing
pls:
i am beginner with signal processing micro controller .
i need a micro controller for signal processing, what kind can i use .
frequency signal above 100Mhz
kasser is offline   Reply With Quote
Old 26th February 2007, 10:38 AM   (permalink)
MicroChip make a range of DSP's, but 100MHz if far too high for such devices - perhaps you'd better tell us what you're trying to do?.
Old 27th February 2007, 09:52 AM   (permalink)
i want to work with IF frequency ,am-fm radio signals.
Old 27th February 2007, 09:58 AM   (permalink)
Very different frequencies, FM is normally 10.7MHz, and AM 455KHz - but what do you want to do with it?.
Old 27th February 2007, 10:05 AM   (permalink)
Are you planning to build digital filters at IF?
tanmaysathe is offline   Reply With Quote
Old 27th February 2007, 10:09 AM   (permalink)
first:i want to replace low frequency analog part with digital part.
Old 27th February 2007, 10:12 AM   (permalink)
yes ,that denote low pass digital filters
Old 27th February 2007, 10:17 AM   (permalink)
therefore i want high speed microcontroller
Old 27th February 2007, 10:18 AM   (permalink)
The signals from the mixer are tiny, so you need to amplify them considerably anyway, and you would normally band-pass filter them during this amplification, using ceramic filters (or historically IF transformers). Attempting to use just a wideband amplifer is going to reduce performance considerably, probably to the extent it wouldn't work?.
Once you've got the amplified IF signals you could presumably then use a DSP to demodulate them? - but you're replacing a simple cheap part of the circuit with a much more complicated and expensive part.
Old 27th February 2007, 10:44 AM   (permalink)
thank you NIGEL:
that all right ,but the size becoms littler and changing its content is easir.
so i want to work with DSP.
Old 27th February 2007, 11:39 AM   (permalink)
thank you NIGEL:
Like I said above, check the dsPIC from MicroChip - now you've dropped your original requirement from 100MHz things become a lot more possible!.
Old 27th February 2007, 03:40 PM   (permalink)
FPGA's are useful for digital 'software defined' radios. Wikipedia's entry has tons of information about it, including several active projects. They're basically high speed ADC's and DAC's hooked directly to an FPGA.
http://en.wikipedia.org/wiki/Software-defined_radio
straight answer, har har."
Old 28th February 2007, 07:51 AM   (permalink)
thank you for all
Old 28th February 2007, 07:58 AM   (permalink)
Default yes i want to build digital filters at LF,IF.
Old 2nd March 2007, 10:18 AM   (permalink)
Filters you said?
Check this one http://www.latticesemi.com/products/...isppac8081.cfm
mcs51mc is offline   Reply With Quote
Good Beginner Micro Controller psecody Micro Controllers 54 29th January 2007 01:58 PM
PC---> Micro Controller ---> Devices HELP firekiller51 Micro Controllers 1 25th October 2006 06:19 PM
micro controller Emeka Chit-Chat 1 9th December 2005 04:13 AM
micro controller projects melodzky Micro Controllers 3 4th July 2005 07:41 AM
Micro Controller Switcher Help Fuad General Electronics Chat 3 25th May 2003 07:47 AM
