| Guys how do you load the .Hex file? I have a PIC loader. Using a boot disc? | |
| You need to provide more information... Normally you load the HEX with a PIC programmer and its associated software, or if you use a bootloader (which is what I assume you meant by "PIC loader") you do it with whatever hardware connection it was designed for (like serial or USB) and its associated software.
__________________ EEgeek.net | |
| Did your PIC chip come pre-loaded with a loader? Did you get pic chip(s) with this disk? EDIT: Also which loader and is it serial or parallel? | |
| We used NOPPP form bobblick.com... I used MPASM as my assembler. When I assemled it there was no error. I loaded it using MPASM and LOAding was a success but there's an option VERIFY. There was an error on verifying the PIC. | |
Either way, if your PIC "programmed successfully" but failed to verify, unless it was code-protected (in which case verification is impossible) that probably means it didn't program successfully after all.
__________________ EEgeek.net | ||
| I got it already. tnx guys NOPPP do really work | |
| How we can do it in Assembly..Help Needed | Ayne | Micro Controllers | 37 | 29th December 2006 06:49 PM |
| Problem when loading hex file | zachtheterrible | Micro Controllers | 12 | 27th February 2006 10:23 PM |
| how would i generate HEX file for multiple assembly files? | belinda_sg | Micro Controllers | 2 | 30th March 2004 08:54 AM |
| How to generate .Hex file using HiTech picc18 | janetsmith2000@yahoo.com | Micro Controllers | 2 | 10th February 2004 12:41 AM |
| Trouble loading .hex onto 16f84a any thoughts? | andthisiswhatremains | Micro Controllers | 0 | 10th October 2003 03:23 PM |
