+ Reply to Thread
Page 5 of 5
First 1 2 3 4 5
Results 61 to 70 of 70
Thread: Inchworm project started
  1. #61
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,452
    Blog Entries
    11
    Quote Originally Posted by blueroomelectronics
    It also needs power, some people don't hook up a wall wart to it and wonder why it doesn't work...
    The power and gnd come through the ICSP cable.
    Why does it not work ?
  2. #62
    williB Good williB Good
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
    i did not notice any activity on pin 8 or pin 13 when i just scoped the max232 chip
    this is R1in and R2in
    i think you are right about the com port problem , any other sugestions?
    note this is the same cable i used last night to test the serial port communications with my meter , the meter has rs232 communication capability.
    and it worked
    the signal may go by so quickly that i did not see it , but it isnt likely.the beam didnt budge.
    to sum up :
    a working cable
    a working com port
    yet no detectable signal, from the com port,
  3. #63
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,656
    Blog Entries
    5
    Quote Originally Posted by 3v0
    Opps my bad, yes it can be powered from the target too...
    Bill
    Smart Kits build Smart People
  4. #64
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,656
    Blog Entries
    5
    Quote Originally Posted by williB
    and it worked
    to sum up :
    a working cable
    a working com port
    Is this a USB to RS232 or a true RS232 port?
    Bill
  5. #65
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
    its a true rs232 port
  6. #66
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
    pin 8 holds fast at minus 12V
    pin 13 at plus 12V
  7. #67
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
    i have switched to com 1
    Ran a terminal program ( from mikropsacal)
    set the flow control to NONE (in the device manager for windows) and got a signal when i transferred a file
    so the port seems to be working.
  8. #68
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
    i got a blip from pin 12 ! on the max 232 chip.when i try to connect.
    which is R2 out , which goes to pin 26 ,the recieve line on the 877
    so i'm gonna assume the com port is working.
  9. #69
    Join Date
    Aug 2004
    Location
    New Jersey
    Posts
    2,226
    Default success!
    i had a bad crystal!
  10. #70
    3v0
    3v0 is offline
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,452
    Blog Entries
    11
    You have it workng, contrats.
    FWII the easyest way to test the rs232 is with a loop back type test. Remove the PIC and jumper the TX and RX pins at the processor socket Then connect to the Inchworm with any terminal program. If you can see what you type the MAX232 is working. When you remove the jumper you should not see what you type.
+ Reply to Thread
Page 5 of 5
First 1 2 3 4 5
  1. FINAL YEAR PROJECT!
    By erique82 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th April 2007, 11:09 AM
  2. Inchworm ICD2 Getting Started Trouble
    By GRC in forum Micro Controllers
    Latest: 23rd December 2006, 10:15 PM
  3. Replies: 3
    Latest: 30th November 2006, 03:45 AM
  4. Need help getting started with IR project
    By Promocom in forum Micro Controllers
    Latest: 15th February 2006, 09:17 AM
  5. I need a project idea based on my strength or interest. :)
    By janetsmith2000@yahoo.com in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th November 2003, 10:33 AM
Tags for this Thread
