Hi, I'm trying to adapt the code I found here to run on a 16F876 at 20Mhz. I changed the BASE memory location to 0C. However it still doesn't run and I just get black squares on the top line of the LCD. Putting an LED on RB7 shows it flashing on and off when you first power the PIC up. Can anyone please tell me what else I'd need to change to get it working? I'm using PORTB and the basic m_lcd.asm file just trying to get the example to work! Thanks | |
You might try my tutorial LCD code?, it's tested and working on 14 bit series PIC's from 4MHz to 20MHz.
Hi, Didn't see your code before but I tried the first lot of code from tutorial 3.1. changed the processor lines and the include line to the processor I'm using. also tried changing the config bit as well. Still couldn't get it to work. I'm starting to think its a dud LCD. I'll check my wiring again but can't see anything wrong - after all its not a very complex circuit - and it works fine with some other LED flasher examples I've used. Cheers | |
Have you checked that the contrast is set to something sensible. You should be able to adjust it from fully dark to fully light. Mike. | |
Like Pommie suggests, the contrast is fairly critical - even without the LCD initialised (or even connected to a PIC) as you turn the contrast up you will get a single row of black squares, turn it down and you get nothing. This is a reasonably good indication the LCD is working, when it's powered up, try turning the contrast slowly from end to end.
| | #6 | |
| | #7 |
hi bh, The asm prog you are converting was written to suit a 4mHz osc. The LCD controller is a slow device and requires delays, especially during the initialising sequence. Also the BUSY line [D7] is not used/tested, so delays are required in writing the control commands to the LCD controller. One of the 'slower' control lines is the E-nable.[min cycle time 1uSEc] As you are using 20mHz xtal, I would suggest a starting point in the delays would be to increase them by a factor of 5. Also pad out the 'E-nb' low period with about 5 NOP's. From the start of the program have a delay of about 50 mSec before you start the LCD initialise seq This should give you a working LCD. I assume you have followed prev posts re the contrast pot. Once the LCD is working, you can reduce the delays in increments until you get the optimum speed. If you do optimise it for a particular LCD, if possible try with another LCD of the same type, the 'speeds' do vary. EricG | |
| | #8 | |
I've tried Nigels code as well. No success with that either. Attached is the file as I've written it to the chip. I've tried both a 20MHz and a 4MHz crystal just to see if it works on either. Contrast is setup with a 20k hm: pot to let me adjust it. I can vary it between a completely blank screen to a top row of dark squares. I've tried playing with it and it doesn't magically start working when I change the contrast ![]() I'll try and post a picture of my board later. Cheers | ||
| | #9 |
hi bh, Post the code you are using and I'll try it on my simulator for you. Eric | |
| | #10 |
As I know ,CCS programmer supports Library for LCD (LCD 4 bit) You could use this library .I think it is very useful for you.
__________________ E-DESIGN prestigious and quality http://pg.photos.yahoo.com/ph/giaosu...765scd&.src=ph contact me:giaosucan2000@yahoo.com | |
| | #11 |
Hi, The current code I'm trying to get working is Nigels code as attached in the previous post. I know the PIC and the programmer works, as a basic LED flash routine works, and I've used the LCD with PICAXE circuits successfully before so I'm just guessing its some sort of code issue. I've got the data lines D4-D7 connected to RB0-3 with D4 connected to RB0, D5 to RB1, etc... The control lines are connected with Enable (pin 6) to RB5, RW (pin 5) to RB6 and RS (pin 4) to RB7. Everything seems to have power fine. Both the 4Mhz crystal and the 20Mhz one has the same thing - nothing initialises. I've tried some variations on Nigel's code, eg changing the delays which doesn't seem to have an affect. I'm sure I've got the start of his code setup right (the PORTB, LCD_RS, LCD_RW values, etc). So I'm a little stumped! Thanks | |
| | #12 |
hi bh, Just run Nigel's code thru simulator, runs as expected, no problems. [ignore the 4 line display on my pic, just using prev setting] Check that RB6/RW is really low when you have programmed the PIC, it should be, BUT. Its not used in the prog, it should be tied to 0v. What type of LCD controller is it? Eric Last edited by ericgibbs; 7th July 2008 at 12:19 PM. | |
| | #13 |
Hi All, Not quite sure why but it's suddenly started working. Just flashed the chip with the following code which does a perfect 16 bit counter! Thanks guys for all your help so far! Code: ;LCD text demo - 4 bit mode
;Nigel Goodwin 2002
LIST p=16F876 ;tell assembler what chip we are using
include "P16F876.inc" ;include the defaults for the chip
ERRORLEVEL 0, -302 ;suppress bank selection messages
__config 0x3D1A ;sets the configuration settings (oscillator type etc.)
cblock 0x20 ;start of general purpose registers
count ;used in looping routines
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
tmp1 ;temporary storage
tmp2
templcd ;temp store for 4 bit mode
templcd2
NumL ;Binary inputs for decimal convert routine
NumH
TenK ;Decimal outputs from convert routine
Thou
Hund
Tens
Ones
endc
LCD_PORT Equ PORTB
LCD_TRIS Equ TRISB
LCD_RS Equ 0x07 ;LCD handshake lines
LCD_RW Equ 0x06
LCD_E Equ 0x05
org 0x0000
goto Start
HEX_Table ADDWF PCL , f
RETLW 0x30
RETLW 0x31
RETLW 0x32
RETLW 0x33
RETLW 0x34
RETLW 0x35
RETLW 0x36
RETLW 0x37
RETLW 0x38
RETLW 0x39
RETLW 0x41
RETLW 0x42
RETLW 0x43
RETLW 0x44
RETLW 0x45
RETLW 0x46
Text addwf PCL, f
retlw '1'
retlw '6'
retlw ' '
retlw 'B'
retlw 'i'
retlw 't'
retlw ' '
retlw 'C'
retlw 'o'
retlw 'u'
retlw 'n'
retlw 't'
retlw 'e'
retlw 'r'
retlw '.'
retlw 0x00
Start ; movlw 0x07
; movwf CMCON ;turn comparators off (make it like a 16F84)
Initialise clrf count
clrf PORTA
clrf PORTB
clrf NumL
clrf NumH
SetPorts bsf STATUS, RP0 ;select bank 1
movlw 0x00 ;make all pins outputs
movwf LCD_TRIS
movwf TRISB
bcf STATUS, RP0 ;select bank 0
call LCD_Init ;setup LCD
clrf count ;set counter register to zero
Message movf count, w ;put counter value in W
call Text ;get a character from the text table
xorlw 0x00 ;is it a zero?
btfsc STATUS, Z
goto NextMessage
call LCD_Char
incf count, f
goto Message
NextMessage movlw d'2'
call LCD_Line2W ;move to 2nd row, third column
call Convert ;convert to decimal
movf TenK, w ;display decimal characters
call LCD_CharD ;using LCD_CharD to convert to ASCII
movf Thou, w
call LCD_CharD
movf Hund, w
call LCD_CharD
movf Tens, w
call LCD_CharD
movf Ones, w
call LCD_CharD
movlw ' ' ;display a 'space'
call LCD_Char
movf NumH, w ;and counter in hexadecimal
call LCD_HEX
movf NumL, w
call LCD_HEX
incfsz NumL, f
goto Next
incf NumH, f
Next call Delay255 ;wait so you can see the digits change
goto NextMessage
;Subroutines and text tables
;LCD routines
;Initialise LCD
LCD_Init call LCD_Busy ;wait for LCD to settle
movlw 0x20 ;Set 4 bit mode
call LCD_Cmd
movlw 0x28 ;Set display shift
call LCD_Cmd
movlw 0x06 ;Set display character mode
call LCD_Cmd
movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd ;Set cursor off
call LCD_Clr ;clear display
retlw 0x00
; command set routine
LCD_Cmd movwf templcd
swapf templcd, w ;send upper nibble
andlw 0x0f ;clear upper 4 bits of W
movwf LCD_PORT
bcf LCD_PORT, LCD_RS ;RS line to 0
call Pulse_e ;Pulse the E line high
movf templcd, w ;send lower nibble
movwf LCD_PORT
call LCD_Busy
retlw 0x00
LCD_CharD addlw 0x30 ;add 0x30 to convert to ASCII
LCD_Char movwf templcd
movwf LCD_PORT
bsf LCD_PORT, LCD_RS ;RS line to 1
movwf LCD_PORT
call LCD_Busy
retlw 0x00
LCD_Line1 movlw 0x80 ;move to 1st row, first column
call LCD_Cmd
retlw 0x00
LCD_Line2 movlw 0xc0 ;move to 2nd row, first column
call LCD_Cmd
retlw 0x00
LCD_Line1W addlw 0x80 ;move to 1st row, column W
call LCD_Cmd
retlw 0x00
LCD_Line2W addlw 0xc0 ;move to 2nd row, column W
call LCD_Cmd
retlw 0x00
LCD_CurOn movlw 0x0d ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_CurOff movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_Clr movlw 0x01 ;Clear display
call LCD_Cmd
retlw 0x00
LCD_HEX movwf tmp1
swapf tmp1, w
andlw 0x0f
call HEX_Table
call LCD_Char
movf tmp1, w
andlw 0x0f
call HEX_Table
call LCD_Char
retlw 0x00
Delay255 movlw 0xff ;delay 255 mS
goto d0
Delay100 movlw d'100' ;delay 100mS
goto d0
Delay50 movlw d'50' ;delay 50mS
goto d0
Delay20 movlw d'20' ;delay 20mS
goto d0
Delay5 movlw 0x05 ;delay 5.000 ms (4 MHz clock)
d0 movwf count1
d1 movlw 0xC7 ;delay 1mS
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
Pulse_e bsf LCD_PORT, LCD_E
nop
bcf LCD_PORT, LCD_E
retlw 0x00
LCD_Busy
bsf STATUS, RP0 ;set bank 1
movlw 0x0f ;set Port for input
movwf LCD_TRIS
bcf STATUS, RP0 ;set bank 0
bcf LCD_PORT, LCD_RS ;set LCD for command mode
bsf LCD_PORT, LCD_RW ;setup to read busy flag
bsf LCD_PORT, LCD_E
swapf LCD_PORT, w ;read upper nibble (busy flag)
bcf LCD_PORT, LCD_E
movwf templcd2
bsf LCD_PORT, LCD_E ;dummy read of lower nibble
bcf LCD_PORT, LCD_E
btfsc templcd2, 7 ;check busy flag, high = busy
goto LCD_Busy ;if busy check again
bcf LCD_PORT, LCD_RW
movlw 0x00 ;set Port for output
movwf LCD_TRIS
return
;end of LCD routines
;This routine downloaded from http://www.piclist.com
Convert: ; Takes number in NumH:NumL
; Returns decimal in
; TenK:Thou:Hund:Tens:Ones
swapf NumH, w
iorlw B'11110000'
movwf Thou
addwf Thou,f
addlw 0XE2
movwf Hund
addlw 0X32
movwf Ones
movf NumH,w
andlw 0X0F
addwf Hund,f
addwf Hund,f
addwf Ones,f
addlw 0XE9
movwf Tens
addwf Tens,f
addwf Tens,f
swapf NumL,w
andlw 0X0F
addwf Tens,f
addwf Ones,f
rlf Tens,f
rlf Ones,f
comf Ones,f
rlf Ones,f
movf NumL,w
andlw 0X0F
addwf Ones,f
rlf Thou,f
movlw 0X07
movwf TenK
; At this point, the original number is
; equal to
; TenK*10000+Thou*1000+Hund*100+Tens*10+Ones
; if those entities are regarded as two's
; complement binary. To be precise, all of
; them are negative except TenK. Now the number
; needs to be normalized, but this can all be
; done with simple byte arithmetic.
movlw 0X0A ; Ten
Lb1:
addwf Ones,f
decf Tens,f
btfss 3,0
goto Lb1
Lb2:
addwf Tens,f
decf Hund,f
btfss 3,0
goto Lb2
Lb3:
addwf Hund,f
decf Thou,f
btfss 3,0
goto Lb3
Lb4:
addwf Thou,f
decf TenK,f
btfss 3,0
goto Lb4
retlw 0x00
end
| adapting, code, lcd |
| Need PIC16F84A Cool Project | Agent 009 | Micro Controllers | 158 | 11th March 2007 07:15 AM |
| Need some help with a code provided by ATMEL | ikalogic | Micro Controllers | 1 | 23rd January 2007 03:46 PM |
| Code not working..help | Electrix | Micro Controllers | 15 | 26th September 2005 12:12 PM |
| Tough assembly program for the PIC16F84 | asmpic | Micro Controllers | 34 | 3rd December 2004 07:50 PM |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 03:55 AM |
