(permalink) | |||
This could have you guys dumbfounded like I am, or it could just be a simple answer!
Basically I have 2 PIC 18F4520s powered independently from two 12V-mains-sourced 5V regulators. I have the USART serial pins of the two PICs connected to each other along with a common ground line, so both the supplies have a common ground even though they are actually independent. I basically have them talking to each other with PIC-1 waiting for PIC-2 to ask for data, and then PIC-1 transmitting data to PIC-2. This goes on in a loop just for testing purposes. I've got both PICs hooked up to LCDs so I know whats going on. Now heres the peculiar part. I should theoretically be able to power up PIC-1 and then PIC-2 and immediately have PIC-2 asking PIC-1 for data, PIC-1 responding and the loop continuing. But I can't get that to happen. PIC-1 just waits for data even after PIC-2 has powered on and acknowledged that it has asked PIC-1 for data. The ONLY way I can currently get around this is if I power on both PICs (in any order), reload the hex file for PIC-1 first while still having the 12V power connected, and then reload the hex file for PIC-2 using the same process. PIC-1 then correctly receives PIC-2's request and sends data back and the loop continues without a hitch. I'm guessing this is something to do with either the fact that I've got common ground for 2 independent supplies, or something wrong with my code. I plan to eventually have wireless USART using Nigel's tutorials and inverting the signals as opposed to Manchester coding as the communication will be short-range, so the common ground issue will become irrelevant later. I have posted the important bits of my code below: PIC-1 code (master): Quote:
PIC-2 code (slave): Quote:
Any insights would be appreciated! p.s. I'm using the Hi-Tech PICC18 compiler and PICKit2 to load HEX files.
www.myspace.com/crimsonroadmap Last edited by NJ Roadmap; 21st February 2007 at 06:38 PM. |
Why do you have two seperate sets of code for a serial echo routine? The code for both PIC's should be identical you just wire the TX of one to the RX of the other and vice versa. Send char, wait for char with a random timeout delay. If a char isn't received by the time out delay send another char. If you don't have a time out ability in the getch routine all that needs to happen is a single bit transmit or receive error and it will wait forever. There's likley a timeing glitch on the TX/RX line when the PIC's powering on that's keeping the loop from starting when you come up from a cold start. The line could be floating high or load when the PIC starts up in it's natural High Z state. Causing a single bit to be transmitting which starts the getch routine and it just sits there waiting for the next bits which never come.
could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." |
So this is a 3-wire system? Do you have a quickie schematic so that I can take a look at the entire scheme?
"Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein |
Its literally 2 PIC18F4520's on independently-powered boards with each RX pin terminating at the other end at a TX pin (so that makes 2 wires) and the third wire is a ground wire, which is explained below.
The ground's of the two independently-powered boards are linked since the RX and TX levels on each board need to have the same reference, or atleast that's what I think. I haven't actually tried it without the ground pins connected, but will do that tomorrow. update: I have got the PIC sending strings via the USART to the other PIC by sending a character at a time. I am just wondering how I can implement error correction on a hardware USART if I'm just putting an ASCII char in the TXREG and getting an ASCII character out of the RXREG at the other end? update 2: I have just had an idea: what if i convert each character in my string into binary, then add parity to it and then send this character as a 9-bit binary string? Or is there a way to do this more easily?
www.myspace.com/crimsonroadmap |
(permalink) | |||
How fast are you trying to send?, there really shouldn't be any problems doing this!. |
It sounds very much to me like a software issue. I can't tell too much from your code, partly because you describe the two PICs as "PIC-1" and "PIC-2" in the text, and then label both code samples as "PIC-2", though I assume that "master" is PIC-2... And, I don't know the specifics of the getch() routine.
But, if the getch() routine is blocking (ie - it doesn't return until something is received), then all it would take is for the slave PIC to miss the "request" character a single time, and then both PICs would sit there in the 'getch()' routine waiting for data, stuck. This is a very poor setup - although if you're powering them up in the order you describe, in theory the slave shouldn't be missing that request, it would be significantly more robust to implement a better scheme where some kind of a timeout is used so that things don't get kicked into an infinite loop. And, if you're planning to actually have the slave DO anything other than constantly sit waiting for the master to request data, you're probably going to want to make use of the USART interrupt so it just jumps to an ISR any time data comes in, handles it, and jumps back to the main program. This could also work well on the master, allowing it to send a request, and go do other things until the response arrives.
EEgeek.net |
(permalink) | ||||
(the 9th bit of transmit data). I know simple parity error-checking isn't very useful as theres still a chance that 2 bits may be wrong and hence parity would not be able to detect it, but is there a better solution? Quote:
good luck with it
Need Help? Press F1 If that doesn\'t help you, ask me... I might know better. |
(permalink) | |||
Also with respect to RF, I am using a RX module and a TX module at each end but they will both be operating at 433MHZ so I am planning to use a half-duplex process as follows. Please let me know if you think this will work:
Note: Master PIC will idle in TX mode and Slave PIC in RX mode 1. Master polls slave for data (some sort of query character(s)) and then switches to RX mode 2. Slave receives polling query and switches to TX mode 3. Slave sends sensor data to Master (preset number of characters) and switches to RX mode 4. Master receives preset number of characters and then switches back to TX mode I expect the polling interval (step 1) to be about 5 mins as none of the sensor data is critical to the master and all control is done on the slave. The master is literally a dumb-terminal for data display and some user inputs which need to be transmitted to the slave. If this data is to be transmitted to the slave I plan to implement the following process, very similar to the above process for sensor data polling: Note: Master PIC will idle in TX mode and Slave PIC in RX mode 1. Master send slave heads-up that it is sending user inputs (some sort of 'heads-up' characters) and switches to RX mode, waiting for ACK data 2. Slave receives 'heads-up' data and switches to TX mode 3. Slave sends ACK data and switches to RX mode 4. Master receives ACK data and then switches back to TX mode 5. Master sends user inputs (preset number of characters) to slave and STAYS in TX mode 6. Slave receives user inputs and STAYS in RX mode I guess I could implement some sort of ACK packet sending at every step of the process. Can anyone see any flaws in the above processes?
Major flaw is the RF link, as your UART is waiting for a start bit, then if the signal drops too weak it will generate false start bits, and false data. This is another advantage of the Manchester coding.
AM modules may not be as bad as FM though?, as with FM you get the white noise when the signal drops. The modules I used have a signal strength output on an extra pin, you could monitor that, and only enable the UART if the signal is strong enough. |
This module doesn't have a singal strength pin unfortunaltely. I chose AM because they were cheaper than the comparable FM module from the same company. It turns out that it may actually be better than FM for this application! The module outputs 3.6V for a high and 0.6V for a low. Will 3.6V be enough for the USART to detect a high?
Link to RF Solutions AM-HRR30-433 datasheet: http://www.farnell.com/datasheets/61126.pdf
I am planning to use ZTX653 NPNs for the signal inversion and planning to transmit and receive at 300bps to start off with to reduce chances of errors. Hopefully this will work tomorrow!
Heres a link where I'm getting my info for the transistor inverters:
http://www.kpsec.freeuk.com/trancirc.htm Quote:
p.s. Thanks for the help so far!
www.myspace.com/crimsonroadmap Last edited by NJ Roadmap; 21st February 2007 at 09:28 PM. |
| 18f452 usart (rs232) and pic | BOBKA | Micro Controllers | 5 | 20th February 2007 05:17 AM |
| PIC USART: Help Please | mortuzahasan | Micro Controllers | 2 | 11th February 2007 06:28 PM |
| Newcomers, please read! (PIC regarded) Upd. 0xD | Jay.slovak | Micro Controllers | 0 | 17th April 2005 01:04 PM |
