Nice fully compact design.All with familliar parts.
PORTA drivng the common of the segments directly???????and the rows also same.It can cause load more current through the PIC pin even when its in multiplexing mode. Thankx for sharing..... Last edited by Gayan Soyza; 14th February 2007 at 02:25 AM. |
It is possible with some fancy programming to light only one segment at a time. It's done here with the super probe.
http://members.cox.net/berniekm/super.html |
Is there any different of connecting the 7-segment display directly to the output port without any current limiting resistor as compared to drive the 7-segment display with transistor plus current limiting resistor? Since the output current of the PIC's is only 25 mA, it won't burn the LED right?
Superman returns..
I think that what the manufacturers mean is that it must absolutely never exceed 25mA (or about 200mA combined for all ports) - but it is taken by users to mean that it is automatically current limited so that you do not need resistors - which is wrong. As I see it, the only way that you can get away with exceeding the 25mA limit is to use multiplexing to reduce the average port current, which is ok as long as your multiplex software does not latch-up due to some software error. |
In regards to the Mondo SuperProbe not using limiting resistors. The author points out that SuperProbe is a study in doing the most with the fewest parts. Possibly because it had to fit in an existing probe case.
| Problem with LCD code? | spondootre | Micro Controllers | 15 | 29th April 2008 09:15 AM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 09:23 AM |
| Help me on basketball's game clock and shot clock! | syaw_007 | Electronic Projects Design/Ideas/Reviews | 1 | 6th September 2004 09:50 PM |
| Need A Simple Alarm Clock Circuit | Handiplus | Electronic Projects Design/Ideas/Reviews | 0 | 29th March 2004 02:01 PM |
| PIC 16F84A Clock Questions | aevans17 | Micro Controllers | 2 | 8th January 2004 07:53 AM |
