Old 11th February 2007, 05:08 PM   #1
Question PIC Digital Clock
Hi I need a 16F877A digital clock circuit with DS1307 and 2*16 LCD display with source code Kindly Help
muralibhat is offline
Old 11th February 2007, 05:15 PM   #2
Would you like fries with that?
There must be a ton of them out there. Have you googled?
BeeBop is offline
Old 12th February 2007, 04:07 PM   #3
Yes googled but did not get the specific one which I mentioned
Old 12th February 2007, 04:31 PM   #4
OK, here is one:
http://www.best-microcontroller-proj...-clock-ic.html
It uses another pic, but should be easy to adapt to what you need.
Here is another:
http://www.rentron.com/PicBasic1.htm
There are lots more. Try gooling "16f877 DS1307 project"
BeeBop is offline
Old 17th February 2007, 04:44 PM   #5
Thanks I will Try the links
Old 18th February 2007, 08:46 AM   #6
Y dont u try this one. Its working perfectly.
http://www.hamradioindia.org/circuits/clock.php
http://www.hamradioindia.org/downloa...download&cid=3
pasanrobotics is offline
Old 18th February 2007, 03:59 PM   #7
Thank You The project you have suggested is good but it uses the LED not LCD any way it is simple to shift to LCD
Old 18th February 2007, 04:30 PM   #8
You should try it then. That is where the learning will take place. What language are you using?
BeeBop is offline
Old 18th February 2007, 04:47 PM   #9
When u modified it to LCD plz give us schematics and codes
Old 19th February 2007, 08:28 PM   #10
guys, how about a digital clock using pic16f84a?? do you guys have any suggested sites??? because just like muralibhat i didnt got a specific result of this project using pic16f84a.... pls help!!! coz starting today i only got 10 more days left to do it..
jofp is offline
Old 20th February 2007, 04:00 PM   #11
Of course I use assembly language
Old 20th February 2007, 06:01 PM   #12
Then the best tutorial would be Nigel's:
http://www.winpicprog.co.uk/
Once you work through this, you will be able to make the change.
BeeBop is offline
Old 23rd February 2007, 05:22 PM   #13
Thanks I have dowloaded Hitech Picc LIte compiler just to know the how easy it is programm in C but I cannot install it becos it gives the message that the MPLAB IDE is 6.5 version or higher but My IDE is 6.0 version.
Please help
Old 25th February 2007, 05:36 AM   #14
Then download the latest version from MicroChip:
http://ww1.microchip.com/downloads/e...eDoc/MP750.zip
kchriste is offline
Old 7th March 2007, 02:39 PM   #15
Default Problem in the circuit!
Thaks everyone who cooperated
I have finished the circuit and the program but the clock i.e.DS1307 starts only if I touch anu pins of any IC or positive terminal or ground. I cannot figure out the problem.Please Help
clock, digital, pic
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 02:45 PM
Need Help about my DLD Project..Wanna make Digital clock.. TuTu Electronic Projects Design/Ideas/Reviews 1 14th December 2005 03:03 PM
Help me on basketball's game clock and shot clock! syaw_007 Electronic Projects Design/Ideas/Reviews 1 6th September 2004 10:50 PM
digital clock setting the time mode Jay Duluguin Electronic Projects Design/Ideas/Reviews 0 19th February 2004 11:09 PM
