| Another source is old VCR's, most of them have one for the timer. | |
| if you try (as some one said, whenthere is a will there is a way) , you will get it , as Nigel rightly said, from old and condemned casio digital watches. and few other sources of scrap. also you can't just say that thereare no watch repairers and electronic repairers-- components are generally available-- only you have to trace for them . please don't start with negative--
| Ha ha. Finnaly I found one from old watch. Now I'm goona solder it. Thanks all..... | |
| | (permalink) | ||
| Have the Picstart PlusB. Can give it for free but you should pay your ticket to my place :-))
__________________ Agustín Tomás In theory, there is no difference between theory and practice. In practice, however, there is. | |
| Hi Agustín Tomás, Nice Joke sir From Srilanka to Argentina-- for a programmer. fine sir perhaps you can help him make a programmer sitting at his home and with your support thro internet and this great forum electro-tech-online
__________________ Regards, Sarma. Last edited by mvs sarma; 7th July 2008 at 01:12 PM. | ||
| Hey my cct is not working properly. After I power up ( 2.4V )all the segments r going mad. I cant explain that. | |
you can always explain- like the 'a,b,c,d,...g' segments glowing ina sequecnce didigit after digit etc- - see the manufacturing self test explined in 00615 document try giving 5volts then - if possible increase sigment resistors to 100 ohms at 5volts then try and record your observations
Hi, did you try with 5V. perhaps you may have to put 1K series resistor with crystal as otherwise it will get overloaded. i have put the working clock photos for your appreciation and you can make it also work. please check loose connections if solderless bredboard. dry joints if soldered on general purpose board.
| PIC Programmer through COM and ICSP (JDM ??) | test1 | Micro Controllers | 6 | 12th October 2004 09:06 AM |
| Simple serial programmer with external supply? | amady | Micro Controllers | 2 | 4th October 2004 09:47 AM |
| simple pic programmer problem! | Thunder_scream | Micro Controllers | 30 | 20th July 2004 12:24 PM |
| Zilog Z8 Encore simple setup | DirtyLude | Micro Controllers | 9 | 17th February 2004 02:13 PM |
| Devolpment board or simple programmer? | Electron Junkie | Micro Controllers | 2 | 30th November 2003 11:28 AM |
