Old 4th February 2007, 12:11 PM   (permalink)
_ab
Default file conversion
Dear friends....
How can i convert this file alarm.src to alarm.hex???I cant create it using the mpasmwin.I also tried to contact the publisher by e-mail but his e-mail is no longer valid.(its from the elektor magazine october 1998)
Thanks a lot Panagiotis
_ab is offline   Reply With Quote
Old 4th February 2007, 12:27 PM   (permalink)
I would suggest it's the antique obscure Parallax assembler, there's also a converter to normal assembler available on the net.
There's a DOS converter at http://www.tech-tools.com/files/cvasm16.zip
Old 4th February 2007, 01:24 PM   (permalink)
The Parapic converter which converts Parallax syntax into PIC assembly from Tony Nixon is no where to be found on the internet now. Perhaps someone might have an old copy on their harddisk.
The CVASM is an assembler instead but it fits the requirement of the OP perfectly.
L.Chung
eblc1388 is offline   Reply With Quote
Old 5th February 2007, 01:47 PM   (permalink)
_ab
Well i tried, but it seems that it is not assembling with the right way.... :-(
I did what you see in my attachment but when i put it into the socket the circuit was not responded as it suppose to.....What else should i do???
Thanks Again Panagiotis
Old 5th February 2007, 02:45 PM   (permalink)
Originally Posted by _ab
...but when i put it into the socket the circuit was not responded as it suppose to.....What else should i do???
Nobody understands what is happening here. What is placed into the socket of what?
Your attachment showed the successful result of assembling a file and created an output file.
Did you programmed it into a PIC? What PIC? Have you setup the correct configuration option on the PIC to use the correct crystal?
The code inside the ALARM.SRC file includes codes for USART so it could be for connection to a PC serial port. Have you connected up the cable and is there anything else happening in Hyperterminal?
L.Chung
Old 5th February 2007, 03:19 PM   (permalink)
_ab
The alarm circuit uses a pic16f84 proceccor and it can communicate with the pc using the hyper terminal for entering the "exit time" and some similar functions.When i said that i put it in the socket i meant to his 18 pin base.I successfully programmed the pic16f84chip with ic-prog and plms ozipic er programmer but i am suspicious if the assembler made errors on assembling.....Is it possible???.Also when i press the button connect from the hyper terminal i don't see any connection establishing between the pic and the pc using the com1.
Old 5th February 2007, 03:36 PM   (permalink)
..but i am suspicious if the assembler made errors on assembling.....Is it possible???
Please check for other hardware problems. Assembler error is highly unlikely in this case.
L.Chung
Old 5th February 2007, 06:22 PM   (permalink)
_ab
I will check it out and i will tell you my results.....Thanks again for answering me
I appriciate your concern........
How we can do it in Assembly..Help Needed Ayne Micro Controllers 37 29th December 2006 05:49 PM
Windows Overwritting Problem- File Names dknguyen Chit-Chat 5 28th December 2006 02:00 AM
USB to RS232 conversion chintan_jagani Electronic Projects Design/Ideas/Reviews 8 12th October 2006 03:21 AM
Sound file abees81 Electronic Projects Design/Ideas/Reviews 11 28th August 2006 02:05 PM
how would i generate HEX file for multiple assembly files? belinda_sg Micro Controllers 2 30th March 2004 07:53 AM
