Old 4th February 2007, 10:37 AM   (permalink)
Default Laser Beam Tachometer With Pic
Hi friends;
I want to buit laser beam contactless tachometer. any one have source code,schematic,or other related material about it. Please share it.
THANKS IN ADVANCE
iftikhar ahmed is offline   Reply With Quote
Old 4th February 2007, 01:51 PM   (permalink)
I also want to ask some thing from experts..
sensor --- ? ---- microcontroller.
What we use in between sensor and microcontroller??? opamp???
basic idea i know
1. there will be a light source.
2. a reflector on rotating shaft(or may be something other), that will reflect light coming from source.
3. a opto sensor for sensing reflected light, photodiode cuz it is only available in our local market.
4. some circuitry that take input from sensor and convert it into reasonable singnal that can be use with microcontroller. but i don't know much about this part. explanation needed.
5. A microcontroller, it will count input pulses coming from sensor for a given time and convert it into Round/Minute, and will display on our desired display.
Am i right if not then plz guide me.
thanks.
Ayne is offline   Reply With Quote
Old 5th February 2007, 10:42 AM   (permalink)
Thanks Ayne
I think the idea is correct.But the broblem is that how i get reflected light that give one pulse per revuolution. What about this laser reflecting material.
Old 5th February 2007, 11:09 AM   (permalink)
What do you want to measure the speed of?
Model aircraft fliers use a contactless RPM meter which simply counts light pulses caused by the shadow of the propeller.
Other sensors will work with simple black and white paint. Have a look at this page. It describes a line following robot but the circuitry for detecting light/dark is the same.
Pommie is online now   Reply With Quote
Old 5th February 2007, 01:53 PM   (permalink)
thanks mike.
I want to meseure speed of motor shaft with contactless method by using pic
Old 5th February 2007, 02:26 PM   (permalink)
You can buy self adhesive reflective strip, clean the shaft and adhere the strip along the shaft.
If you want to improvise, use a piece of aluminium kitchen foil.
Depending on the diameter of the shaft and the distance you want to space your detector away from the reflector, you can buy small red or clear reflectors from a local cycle/car shop.
If your shaft rotational speed isn't to high, you can use a small linear permanent magnet on the shaft, operating a reed switch.
Just have a simple RC filter on a +5v system.
Regards
EricG
Old 6th February 2007, 12:27 PM   (permalink)
thanks, EricG
Old 10th February 2007, 01:38 PM   (permalink)
Default Encyclopedia of Electronics Circuits, Volume 5 by Rudolf F. Graf, William Sheets
I need Encyclopedia of Electronics Circuits, Volume 5, Any one .please share it to me.
THANKS in advance
Beginner Laser or IR beam alarm system zachtheterrible Electronic Projects 81 23rd August 2008 04:48 AM
Creating a laser beam like in the movies NJ Roadmap General Electronics Chat 17 2nd March 2007 02:59 PM
holographic 3d display systems Sim General Electronics Chat 20 19th July 2004 12:31 PM
Does this work? Laser break beam sensor and delay timer RuaRi Electronic Projects Design/Ideas/Reviews 5 6th May 2004 04:39 PM
laser seeking robot Syntax Electronic Projects Design/Ideas/Reviews 3 13th May 2003 03:50 AM
