how to beleive the specs and supported devices listed especially ones like 16C54 with a programmer like pic-pg2 ( it is OLIMEX type and suitable for icsp and mostly one lands into Vpp problems-- it may not support modern PCs and Laptops with low voltage com and USB ports unless the Vcc and Vpp are suitably processed and ensured.
| Well I started my comp and fired up ic-prog and now its back to not working. I think the program cant find the drivers, any ideas? | |
I would rather people start with an ICD2 clone which gives them a very good programmer. Just as important is the debugger support that the ICD2 provides. That is my opinion. But there are people that want to use simple programmers. It can be difficult for them to sort through all the problems you mentioned above on a scratch built in addition to possible wiring/build errors. The purchased unit cuts out the hunt for wiring errors. Makes it a bit easier to get started. 3v0 | ||
| Got it back up and running. Anyone know of a simple project I can do to test out the pic? (no LCD) | |
| Bryan76 If u r using Windows XP then ICprog not run on Windows xp. Infact it runs, but not work correctly. First of all send any hex into pic using programmer and load it again. if it loads correctly then go to next step(making some project). Last edited by Ayne; 2nd February 2007 at 07:19 PM. | |
| You install some addtional drives with ICProg??? infact when i start with ICprog, it was not working on Windows XP. But it worked right on Windows 98. | |
| Which language u want to use for Programing??? www.mikroe.com Good compliers are there of both C and Basic language. and they are free but limited to 2k program memory. it is enough memory for newb. Basic is easy make ur first program ur self, u will be more happy. | |
| ICProg works under XP fine, although as with any program that directly accesses the hardware you need a driver DLL to allow it to do so. Access under Win98 is easier, because their's no restriction on direct access. | |
| when i open in XP a message box show "Privileged instruction" can i solve this problem if yes then how? | |
__________________ Len | ||
| Well I have ran into a wall on this project. The pic programmer is working, but for the life of me I cant figure out how to load a hex file. I have used visual and C+ before and am not all that new to programming. 1. I am using the JDM Programmer along with ic-prog, the chip is the pic16f84a. 2. What compiler can I use for this programmer? | |
| programmer! | 4electros | Micro Controllers | 8 | 12th November 2007 08:48 PM |
| PIC Programmer using C | burg | General Electronics Chat | 2 | 24th January 2007 08:27 AM |
| PIC programmer & WinPicProg: my findings | eblc1388 | Micro Controllers | 5 | 27th August 2005 12:13 PM |
| PIC Programmer through COM and ICSP (JDM ??) | test1 | Micro Controllers | 6 | 12th October 2004 09:06 AM |
