Old 30th January 2007, 06:45 PM   #1
Default Soft-RS232 on 12F675 ~ Not syncning?
Hello all. This is my first post, althought I've been reading this forum quite a bit. Excellent stuff! Anyways, I hope there is someone out there that can help me with my little PIC-Chip.
I'm a novice with PICs, but I have a good project which require RS232. I have managed to to it with a 16F627, but I need ADC on a small footsprint, so I went for the 12F675.
After I rewrote the code to fit the 12F675, I just couldn't get it working. I was banging my head against the wall for weeks, but I just couldn't figure out why.
My suspicion is that I overwrote the OSCCAL values. I'm not sure if I can read the location of that value, since the programmer I'm using (Velleman) is not that good. If I jump to that address, as part of the recommended calibrarion routine, the PIC hangs. I'm pretty sure it's lost, is this what you would expect from an overwritten OSCCAL value? 3F3F, I'm not even sure what that transelates to in Opcode. I've ordered a proper programmer, which should arrive next week
BTW: Two good links to pages regarding OSCCAL:
http://users.tpg.com.au/btkelly/pic/osccal_sync.html
http://www.petesworld.demon.co.uk/ho...PIC/piccal.htm
I'll post my code below for anyone to check. Sorry for the mess, couldn't get the table thing to work. I've written it as simple as possible, with no trixi parts. Is my code ok? Does it do what I want it to do? (Which is to output an ASCII letter every now and then )
list p=12F675 ; list directive to define processor
#include <p12f675.inc> ; processor specific variable definitions
__CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_ON & _WDT_oFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
;***Set up the Constants
COUNT1 equ 20h ; First counter for our delay loops
COUNT2 equ 21h ; Second counter for our delay loops
RS232TX equ 23h ; Variable byte to send on RS232
RS232LC equ 24h ; RS232 Delay Loop counter
RS232BC equ 25h ; RS232 Bit counter (0 to 7)
;***Set up the port & Initialise
bcf STATUS, RP0 ; Bank 0
clrf GPIO ; Init GPIO
movlw 0x7 ; Set GP<2:0> to digital IO? (07h not 0x7)
movwf CMCON ; Disable comparator
bsf STATUS, RP0 ; Bank 1
clrf ANSEL ; Digital IO, disables ADC
; call 0x3ff ; Get Calibation value
; movwf OSCCAL ; Calibrate
movlw B'00100000' ; Set GPIO
movwf TRISIO ; All pins outputs, except GPIO5
MOVLW b'01010101' ; Byte to be sent. Not implemented.
MOVWF RS232TX ;
bcf GPIO,2 ; Clear GPIO2, initialization for RS232
;*** Start of main loop
Effect1
movlw b'00000100' ; Start bit
movwf GPIO ;
call RS232BitDelay ; Wait for 104uS
;*** Start LSB
movlw b'00000100' ; LSB (0)
movwf GPIO ;
movlw b'00000000' ; 1
movwf GPIO ;
movlw b'00000100' ; 2
movwf GPIO ;
movlw b'00000000' ; 3
movwf GPIO ;
movlw b'00000100' ; 4
movwf GPIO ;
movlw b'00000000' ; 5
movwf GPIO ;
movlw b'00000000' ; 6
movwf GPIO ;
movlw b'00000100' ; MSB (7)
movwf GPIO ;
;*** End MSB
movlw b'00000000' ; Stop bit
movwf GPIO ;
call Delay ; The long wait
call Delay ;
goto Effect1 ;
;*** Bit Delay for RS232
RS232BitDelay ; This loop loops for exactly one bit to be
MOVLW 0x18 ; Pushed on an RS232 line 9600,1,N
MOVWF RS232LC
RS232Loop
nop
DECFSZ RS232LC,1
goto RS232Loop
return
;*** Longer wait
Delay
Loop1 decfsz COUNT1,1 ; This second loop keeps the LED
goto Loop1 ; turned off long enough for us to
decfsz COUNT2,1 ; see it turned off
goto Loop1 ;
return
end
;****End of the program****
I'm gonna order a few more of those 12F675, and see if I can't get it working. Any advice on the above would be most appreciated, to recap: Is my code OK, and have I overwritten OSCCAL?
Does anyone know the aproximate frequency-range for the internal oscilator?
Oh, and the project I'm doing with this particular PIC is a circut that samples temperature and moisture, and sends it down RS232. I will actually use this on work. I'll post the whole project when it's done, if anyones interested.
All replies are most welcome. And thanks again everyone for an excellent forum.
johankj is offline
Old 30th January 2007, 08:22 PM   #2
Your code is too horrible to look at!
Check the datasheet for the BCF and BSF instructions, you DON'T access individual pins in that crude fashion on a PIC, only on inferior antique processors!. You also use a loop to send 8 bits!.
You should also check my tutorials, although for the 16F628 they only require very slight changes for the 12F675, and include nice reliable RS232 routines!.
Old 30th January 2007, 08:49 PM   #3
Yeah, sorry for the bad code. I was using BCF and BSF, together with a incremental barrell function (To print the whole ASCII-table). but I thought this was easier to debug (at least for me ), because I think it is a timing error.
(Thanks for the quick reply BTW - And I loop to send 10 bits :P )
johankj is offline
Old 30th January 2007, 08:59 PM   #4
Your suspicioun is correct. If the callibration value is lost, probably you won't have precise timing for any serial routine.
The calibration value is in the last location and is read/written as any other location by the (hardware) programmer. The software can take care of it or you have to write the known value manually, after transferring the code.
Second problem: you can't use the calibration routine when the last location contains 0x3F3F. You need a RETLW (0x34) instruction (with a random calibration value). 0x20 selects the center frequency for example. You may try some values or use a crystal (if you have enough I/O pins).
EDIT: 0x20 = b100000 (only 6 bits are used in the OSCCAL register and they are left justified.
eng1 is offline
Old 30th January 2007, 10:57 PM   #5
h20=b100000=d32 I see.
So I guess I could just move that into OSCCAL, and see if I get lucky.
The data-sheet doesn't say, does anyone know how much a 1 inreases/decreases the frequency? I remember reading somewhere that it was tested to ~0.78% But does Microchip say anything about it.
I just thought of something. I have a Fluke 110 multimeter, which can measure frequencies up to 50kHz = 20uS period. I'll just use it to measure the 104uS period, and then I'll see if it caribrated. I'll just modify the code to go 0101010101... Hopefully the fact that it's a square-wave matter.
4.230 Khz +-0.1% + 231.5 +-0.1% uS on min values (000000xx)
5.730 Khz +-0.1% = 174.5 +-0.1% uS On reset values (100000xx)
7.610 Khz +-0.1% = 131.4 +-0.1% uS On Max values (1111111xx)
Well, I could detect a change, but not as detailed as I hoped. Those values are off.
Neither of them worked, sadly. Well, time to hit the sack. I'll try again tomorrow, maybe lower the frequency or something. I'll guesse I'll be ordering a few more of these, and then learn from my mistake...
johankj is offline
Old 30th January 2007, 11:35 PM   #6
Yes, only 6 bits of the OSCCAL register are used. 0 selects the minimum frequency and 63 the maximum frequency. The 6 bits are left justified in the register, as you wrote (I've added a note to my previous post).
I usually place a delay routine after the calibration... I don't remember if it's necessary, but I think that the oscillator takes some time to become stable.
eng1 is offline
Old 31st January 2007, 03:31 AM   #7
First, build RS232 softcode on a known good stable PIC set to same internal RC frequency as the 12F675. Once working good, copy over to 12F675.
For all my 12F675 projects, I include a power-up configurator for the oscillator. If a push a button or just pull an i/o line high during power-up, PIC will go into config mode. I use a scope to monitor another i/o line which when calibrated should be a solid 4 MHZ wave. This was done because I had crap PIC programmers and had no choice but to reconfigure the PIC oscillator value after each flash.
Basically, the current frequency is show on scope, and if you wish to adjust, just hold down or tap the button till desired frequency is met. Each button tap saves the oscillator into eeprom. What is not seen is that on power up the PIC automatically loads the oscillator value from eeprom and sends it to OSCCAL.
File Type: txt oscillator-config.txt (702 Bytes, 55 views)
donniedj is offline
Old 31st January 2007, 10:59 AM   #8
I bought a bunch of 12F629's a while ago, before i did any programming i read every chip and noted the oscal value for each chip. This saved me alot of hassle later on, i suggest you do the same.
SYE is offline
Old 31st January 2007, 01:26 PM   #9
But its the most significant 6 bits, right? Yeah, left justefied, I saw the it in your other post now.
My next question would be if there is any harm, or a minimum grace period in repeatedly writing to the OSCCAL register. I guesse not.
That is a good idea. I'm gonna use i variation on that, since I don't have a scope (yet), a reliable frequency counter, or another factory calibrated 12F675 (yet). I'll do a frequency sweep to see when the RS232 syncs, and then just use that frequency.
Yeah, like I said, I've learnt my lesson.
I'm gonna write a small program that does what I said tonight, I'll post the results.
johankj is offline
Old 31st January 2007, 10:28 PM   #10
Success!!!
I wrote a program that is a vertion of donnidj's idea, but simpler. It starts OSCCAL at zero on reset, then writes an 'A' on RS232. It then adds 'one' to the OSCCAL value, pauses, and returns to the loop.
Here's what it looks like in the terminal, copied and pasted to Notepad to easier see where OSCCAL 'loops':
Interestingly, the rs232 seems quite robust, syncing for OSCCAL values about 14 values apart. I went for the middle one, of course.
Now where did I write down that OSCCAL value?
Thanks everyone for suggestions and help.
johankj is offline
Old 1st February 2007, 02:28 AM   #11
I needed near perfect 1 microsecon instruction cycles because I was measuring high velocity projectiles in my chronograph. Now the RS232 is robust because it has a high tolerance, both the PIC and the PC. Alot of PC's and devices's rs232 clocks are far from being at center frequency of their baudrates. Get a good Digital scope and take a look at a sweep of baud rates transmitted out of your PC. You will wonder how two devices even communicate with the level or error in timing it produces. RS232 has gotten away with this large tolerance because the baud rates are multiples of each other as oppossed to being small increases next to each other like 9.6K, 9.7K, 9.8K...
Please make this lesson's check out to "donniedj". Thank you
donniedj is offline
Old 1st February 2007, 08:51 AM   #12
You won't be able to find the value when you need it, unless....
You inscribed it on the underside of the chip using a sharp pin.
This is the first thing I do when I got the new chip.
L.Chung
eblc1388 is offline
Old 1st February 2007, 09:39 AM   #13
If you think about how RS232 receive works then it is reasonable to assume that it should tolerate ±5% timing error. When a start bit is received the hardware (or software) waits 1½ bit times until sampling for the next bit and then 1 bit time between subsequent samples. For the receiver to read the last bit incorrectly the time has to have moved by a ½ bit after 8 (or 9) bits. Thats 1 in 16 or about 6%.
It makes you realise that the 1% internal clock is easily accurate enough for RS232 at any speed the hardware supports.
BTW, well done on finding an elegant and simple method to recalculate the OSCAL value.
Pommie is offline
Old 1st February 2007, 10:15 AM   #14
Actually not, you wait half a bit time, and confirm you're still in the start bit, then wait one bit time and read the first bit. This helps to prevent false triggering.
Obviously for the timing question though it makes no difference at all.
Old 2nd February 2007, 12:07 AM   #15
Here is Microchip's application note on how to auto-recalibrate the internal oscillator on PIC12F6XX chips in the event that it is lost.
http://ww1.microchip.com/downloads/e...tes/00250a.pdf
You can get the source code by searching the Microchip site for an250.zip.
TekNoir is offline
softrs232, syncning
PCMCIA to RS232 for ICD2 clone clockdoctor Micro Controllers 6 7th April 2008 11:10 PM
Cannot read 12F675 with ICSP dprischak Micro Controllers 4 1st June 2006 03:37 AM
RS232 buffer TDY General Electronics Chat 3 18th March 2005 09:36 PM
rs232 to rs232 data logger with 1meg buffer -help needed ccaammaaccaazzii Electronic Projects Design/Ideas/Reviews 11 20th October 2004 10:43 PM
I²C and RS232 on the same PIC l30 Micro Controllers 2 3rd July 2004 04:14 AM
