Old 28th January 2007, 11:45 AM   (permalink)
Default Testing for transition 255 to 0
Micro: 18F Microchip family.
Given a common register, to detect the transition from 0 to 255 (DECF), what can I test? Is it any trick other than looking for the value 255 in the byte?
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
atferrari is offline
Old 28th January 2007, 12:06 PM   (permalink)
Try looking at the flags register!.
Nigel Goodwin is online now
Old 28th January 2007, 01:04 PM   (permalink)
Going from 255 to 0 sets C but the opposite has not a single flag set, only for the case. At least, simulation shows that.
Agustín Tomás
Old 28th January 2007, 01:23 PM   (permalink)
Doesn't it set the overflow flag?
Pommie is offline
Old 28th January 2007, 01:56 PM   (permalink)
The DECF instruction on a reg with a value of zero to 255 sets the Negative flag (Status reg bit 4)
picasm is offline
Old 28th January 2007, 02:37 PM   (permalink)
Wouldn't it also clear the Zero flag bit? Yep, the DECF instructions affects a whole bunch of STATUS bits. Check out the instruction set summary.
Mike
Mike, K8LH is offline
Old 28th January 2007, 02:41 PM   (permalink)
Yes, but you would have to check that it was set BEFORE you did the DECF, because it would be clear in all cases except one.
Old 28th January 2007, 02:46 PM   (permalink)
I wonder if the OP is trying to avoid decrementing a register if its value is 0? If that's the case, most of us recommend testing for that condition before performing the decrement operation. Isn't that right guys?
Mike
Old 28th January 2007, 02:53 PM   (permalink)
If that was the case, then yes!.
Old 28th January 2007, 02:57 PM   (permalink)
Mike
Yes, For that situation I have used:
tstfsz reg ; skip if the reg has already reached zero
decf reg,f
If he wants to test if a reg has reached 255, then he could use:
DECF reg,f
BN destination ; Branch if negative
picasm is offline
Old 28th January 2007, 03:42 PM   (permalink)
How about
decf file,F
incfsnz file,W ; check if file was zero before the decrement
goto WasZero
Or OV=1 and N=1 gives the same thing.
Checking Z=0 will give all numbers except zero.
Checking N=1 will give all numbers from 0x80 to 0xff.
Checking just OV will give 255 and 127.
Someone with more knowledge about 18 code, does the Carry flag act as a borrow and is therefore reset only if there is a transition from 0 to 255? This would seem likely to me.
Pommie is offline
Sytem Testing -=GST=- Nemisis (cs/cz) Electronic Projects Design/Ideas/Reviews 3 3rd April 2006 02:00 PM
know about testing tools arun_dexter General Electronics Chat 1 15th May 2005 07:55 AM
testing a thermocouple evandude General Electronics Chat 8 29th October 2004 05:25 PM
Capacitor testing zachtheterrible General Electronics Chat 9 31st May 2004 07:21 AM
Testing any Monitor Without PC xpacer General Electronics Chat 6 13th July 2003 09:55 AM
