| Assembly, For PICs Is there any software for gernating the code for addition??? Thanks. Last edited by Ayne; 22nd January 2007 at 06:29 PM. | |
| u can create it..using XOR,OR and AND operations of the PIC..check any digital logic book..
__________________ rabusanad.tripod.com | |
| You should really try to be a little more clear with your questions. What do you mean by "generating the code for addition"? The PIC has addition instructions, like ADDLW and ADDWF. What more do you need?
__________________ EEgeek.net | |
there is any program that produce assembly codes for addition and for subtrection. For example we gave it two variable A, B. A and B are both 16 bit wide. it adds two varibles and the result will store in third varible C. C = A + B in shot we can say that there is any program that produces the assembly codes for C = A + B Infact it is always difficult to write program every time with different variable names. And with different data width. Hope u can understand. | ||
| Microchips site has an app notes section with math routines
__________________ Bill Home of the Firefly PIC Tutor Inchworm ICD2 http://www.blueroomelectronics.com | |
To make it easy, I'll post it agin!. Code: ;16 bit Maths subroutines
Sub16:
COMF Acc2H, f ; Take two's complement
COMF Acc2L, f ; of Acc2. If zero, Acc2L
INCF Acc2L, f
BTFSC STATUS, Z ; overflowed, so carry
INCF Acc2H, f ; into Acc2H.
Add16:
BCF Flags, OverFlow ; clear overflow flag
MOVF Acc2L, w ; Add the LSBs. If carry,
ADDWF Acc1L, f
BTFSC STATUS, C ; increment MSB of sum.
INCF Acc1H, f
MOVF Acc2H, w ; Add the MSBs
ADDWF Acc1H, f
BTFSC STATUS, C ; check for sum overflow
BSF Flags, OverFlow ; set overflow flag
MOVF Acc1L, w ; return lobyte in W
RETURN
Mult16:
CLRF Acc3H ; Clear product to make
CLRF Acc3L ; way for new calculation.
MOVLW d'16' ; Number of bits to calc.
MOVWF tmp1
Multiply_loop
BCF STATUS, C
RLF Acc3L, f ; Shift product left.
RLF Acc3H, f
BCF STATUS, C
RLF Acc1L, f ; Shift multiplicand left.
RLF Acc1H, f
BTFSS STATUS, C ; If carry, add multiplier
GOTO Multiply_skip
MOVF Acc2L, w ; to the product. Else skip.
ADDWF Acc3L, f
BTFSC STATUS, C ; 16-bit addition: prod+mulp
INCF Acc3H, f
MOVF Acc2H, w
ADDWF Acc3H, f
Multiply_skip
DECFSZ tmp1
GOTO Multiply_loop
MOVF Acc3H, w
MOVWF Acc1H ; return answer in Acc1
MOVF Acc3L, w
MOVWF Acc1L ; with lobyte in W
RETURN
DIV16: MOVF Acc2H, w ; Check for division by 0.
IORWF Acc2L, w
BTFSC STATUS, Z
RETLW d'255' ; Error code= 255: return.
MOVLW d'1' ; Otherwise, initialize variables
MOVWF tmp1
CLRF tmp2 ; index for the division.
CLRF Acc3H
CLRF Acc3L
Divide_sh_loop BTFSC Acc2H, d'7' ; Shift divisor left
GOTO Divide_d1
BCF STATUS, C ; until msb is in
RLF Acc2L, f ; Acc2H.7.
RLF Acc2H, f ; tmp1 = no. of shifts+1.
INCF tmp1
GOTO Divide_sh_loop
Divide_d1 BCF STATUS, C
RLF Acc3L, f ; Shift quotient left.
RLF Acc3H, f
MOVF Acc2L,w ; top = top - btm.
SUBWF Acc1L, f
BTFSC STATUS, C ; If top - btm < 0 then
GOTO Divide_d2
MOVLW d'1' ; top = top + btm
SUBWF Acc1H, f
BTFSC STATUS, C ; The idea is to do the
GOTO Divide_d2
INCF Acc1H, f ; the subtraction and comparison
MOVF Acc2L, w ; (top > btm?) in one step.
ADDWF Acc1L, f
goto Divide_reentr ; Then, if btm > top, undo <Microchip instruction>
Divide_d2 MOVF Acc2H, w ; the subtraction by adding
SUBWF Acc1H, f
BTFSS STATUS, C ; top and btm back together
goto Divide_less ; <Microchip instruction>
BSF Acc3L, d'0'
Divide_reentr
BCF STATUS, C
RRF Acc2H, f
RRF Acc2L, f
DECFSZ tmp1
GOTO Divide_d1
MOVF Acc3H, w
MOVF Acc3L, w
RETURN
Divide_less MOVF Acc2L, w ; btm > top, so
ADDWF Acc1L, f
BTFSC STATUS, C ; undo the subtraction by
INCF Acc1H, f ; adding them back together.
MOVF Acc2H, w
ADDWF Acc1H, f
goto Divide_reentr ; <Microchip instruction>
SHIFTR: MOVWF Acc2L
_LoopR BCF STATUS, C
RRF Acc1H, F
RRF Acc1L, F
DECFSZ Acc2L
GOTO _LoopR
MOVF Acc1L, W
RETURN
SHIFTL: MOVWF Acc2L
_LoopL BCF STATUS, C
RLF Acc1L, F
RLF Acc1H, F
DECFSZ Acc2L
GOTO _LoopL
MOVF Acc1L, W
RETURN Last edited by Nigel Goodwin; 23rd January 2007 at 02:32 PM. | ||
| What you're asking for is a program that converts a simple mathematical expression into assembly language using 8-bit math... This is pretty much what a higher-level language compiler would do for you (C, BASIC, etc)... The math routines Nigel posted seem simple enough; if you think it's too much work to simply copy-paste those routines into your program and use them, then why are you even using assembly language?
This is that code in my compiler: Code: Device 16F628 Define PortB=%00000000 Dim A, C, B B=2000 C=2500 A=B+C Code: ; WinPicProg BASIC Compiler Version1.91
; Device 16F628
LIST P=16F628, W=2, X=ON, R=DEC
#INCLUDE P16F628.INC
__CONFIG 0x3D18
;Flags register bit definitions
LEADZ EQU 0x00 ;set to show leading zeros
OverFlow EQU 0x01 ;set for add/sub overflow
Lo EQU 0x05 ;set for I2C normal addressing
Hi EQU 0x06 ;set for I2C extended addressing
Err EQU 0x07 ;set for I2C error
;Pre-defined variables
TEMP1 EQU 32
TEMP2 EQU 33
RESTORE EQU 34
TEMP1_DU EQU 35
TEMP2_DU EQU 36
RESTORE_DU EQU 37
W_DU EQU 38
STATUS_DU EQU 39
Bit_Cntr EQU 40
Xmit_Byte EQU 41
Rcv_Byte EQU 42
LCD_DAT1 EQU 43
Delay_Count EQU 44
_N EQU 44
LCD_DAT2 EQU 45
LCD_DAT3 EQU 46
TEMP_LCD EQU 47
TEMP_LCD2 EQU 48
DELAY1 EQU 49
state EQU 50
pin EQU 51
hiRnd EQU 52
lowRnd EQU 53
Acc1L EQU 54
Acc1H EQU 55
Acc2L EQU 56
Acc2H EQU 57
Acc3L EQU 58
Acc3H EQU 59
Flags EQU 60
TenK EQU 61
Thou EQU 62
Hund EQU 63
Tens EQU 64
Ones EQU 65
Adr_Lo EQU 66
Adr_Hi EQU 67
Chip_Adr EQU 68
Data_Page EQU 69
ORG 0x0000
GOTO _START1
ORG 0x0010
#INCLUDE MATHS.INC
_START1
CLRF RESTORE
CLRF Flags
BCF Flags, LEADZ
MOVLW 0x07
MOVWF CMCON ;turn comparators off (make it like a 16F84)
; Define PortB=%00000000
BANKSEL TRISB
MOVLW 0
MOVWF TRISB
BANKSEL PORTB
; Dim A, C, B
VAR2 EQU 70;A
VAR4 EQU 72;C
VAR6 EQU 74;B
; B=2000
MOVLW 7
MOVWF VAR6+1
MOVLW 208
MOVWF VAR6
; C=2500
MOVLW 9
MOVWF VAR4+1
MOVLW 196
MOVWF VAR4
; A=B+C
MOVF VAR6,W
MOVWF Acc1L
MOVF VAR6+1,W
MOVWF Acc1H
MOVF VAR4,W
MOVWF Acc2L
MOVF VAR4+1,W
MOVWF Acc2H
CALL _Add16
MOVF Acc1L, W
MOVWF VAR2
MOVF Acc1H, W
MOVWF VAR2+1
#INCLUDE HANDLERS.INC
END
;Number of variables used:74 out of 127 | ||
| Binary Addition Carry Bits | oticon6 | Datasheet/Parts Requests | 1 | 11th October 2006 04:21 AM |
| how to add two binary inputs? | aerial | Micro Controllers | 3 | 17th August 2006 11:15 AM |
| displaying binary | hazic | Electronic Projects Design/Ideas/Reviews | 8 | 17th October 2004 05:43 AM |
| 8 bit binary to BCD conversion | Spectacular Butter | General Electronics Chat | 1 | 11th March 2004 09:50 AM |
| Binary counter | Slashdot | Micro Controllers | 18 | 22nd September 2003 10:22 PM |
