Can anyone help me. I have made a circuit with a 16f84 and a matrix 4x3 keypad.The idea is to type a secret code in to trigger a relay as a door opener. I have also made a IR circuit with a 16f84. Igot the scemetics and ASM / HEX codes from various internet sites. Im still in the learning stages of electronics,and have been trying to find a way to combine the two circuits. The end result i want ,is to replace the matrix keypad with a IR sensor and tip the secret number from a remote control. I also want to put a 2 minute delay through an interruppt.I managed this with 2 555 timers, but want to keep it compact .I dont want to use extra ICs if it can all be done on a single PIC.
I have recently learnt that the 16f628 has more I/O ports (16)and a built in quarz. would this be a better choice ,??? Would 13 I/O be enough with the 16f84??? |
16F628A is newer than the 16F84, but if you have the 16F84 then you may as well use that. You should have enough IO using either chip especially if you eliminate the keypad.
--- The days of the digital watch are numbered. --- |
But it is easy to have a fast interrupt adding counts to other registers and such would allow the programmer to test the resulting count and use it to emulate very very long interrupt like days, weeks or months.
L.Chung |
If you want to re-program the PIC for other applications, then get a PIC16F628A. If not, a the 12F629 seems an interisting option to me. |
L.Chung |
LOL
Thank you eblc1388 |
