Old 15th January 2007, 11:04 PM   #1
Default ADC conversion on Olimex board
Hi friends i have to convert analog voltage and read the conversion value on the output port through digiview,
i have written the code but i think its not working can any one help me out
i am giving dc voltage of 2v as input to adc pin.
here is the code
#include <avr/io.h>
#include <avr/iom128.h>
#include <avr/signal.h>
#include <avr/delay.h>
unsigned char data[];
unsigned char counter;
unsigned char i;
void data_send(void);
void init(void);
void delay_loop(unsigned char);
#define adc_data;
/* ADC interrupt service routine*/
SIGNAL(SIG_ADC)
adc_data=((2*256)/5)
data[0]=adc_data;
//data[0]=ADCH;
data_send(); // send packet data
ADCSRA= 0x00; // disable ADC
void delay_loop1(unsigned long us)
{for(;us>0;us--)
{asm("nop");}
void init(void)
PORTA=0xFF;
ADMUX= 0xE0; // Vref (1.1v) internal , channel pB3 of ADC
ADCSRA= 0xC7; // enable ADC ; start conv.
counter=0; // initial value
for(i=0;i<8;i++)
if(data[0] & (01<<i))
{ PORTA= 0X40;
delay_loop1(1000000);
else
PORTA = 0x00;
void main()
init();
ADCSRA= 0xEF; // enable ADC ; start conv.
sei(); // interrupt enable
while(1);
kaleem is offline
Old 16th January 2007, 11:17 AM   #2
I found something strange in your code
and you wrote:
"i am giving dc voltage of 2v as input to adc pin."
So, how can you measure 2V with 1.1V ref voltage??
And further:
1) Why continously initialising ADMUX with 0xE0? You did it once in "init" that should be enough?
2) What's the purpose of adc_data? It's continously set to 102(.4) due to your formula without any variable in it
3) Since you then transfer the variable data[0], also filled with adc_data, I expect that you will see a condtant value on your serial port...
mcs51mc is offline
Old 16th January 2007, 11:53 AM   #3
Default Reply to ADC conversion
hello my friend, i am sorry i have written 1.1 v as internal reference by mistake actually i am using 2.56 v as internal voltage to ADC pin.
i am very confused whether the adc conversion would go into effect without adc_data,in this function i am defining the formula for ADC i.e ADC=((Vin*256)/2.56).
I have to view the conversion on a digiview device.
further more comments and suggestions are higly appreciated.
thank you.
kaleem is offline
adc, board, conversion, olimex
Home made PCB's markland556 General Electronics Chat 27 22nd February 2008 03:31 PM
LED Message Board!!! c3cube Micro Controllers 2 10th February 2006 09:06 AM
Pic Development Board bryan1 Micro Controllers 27 12th November 2005 09:59 AM
how do you get perfect pcbs? monkeytree General Electronics Chat 26 26th April 2005 06:07 PM
Developer board for car application turbo97se Micro Controllers 2 5th January 2004 04:57 PM
