Old 15th January 2007, 04:00 PM   #1
Question Call Them
How can i call a program that is in another assembly file.
I mean;
Our main program file in which we are working.
main
movlw   .255
movwf   PORTB
Call   delay
movlw   .0
movwf   PORTB
call   delay
Goto $ - 6
End.
Our another file that has libraries(like delay, serial port, etcetc).
delay
movlw   255
movwf   i     ;our variable i
DecFSZ   i, F
Goto $ - 1
return
Now how can i call a delay routine in our main working file???
Ayne is offline
Old 15th January 2007, 04:15 PM   #2
A simple option is to put them in an include file, and add it at the top of the program - but a more complicated (and better?) option is to use the linker - personally I never have, I'd sooner cut and paste my common subroutines in.
Old 15th January 2007, 04:42 PM   #3
Is there any subroutine of delay on any website???
__________________________________________________ _______________
/*Nigel Goodwin likes C complier for microcontrollers*/
/*Nigel Goodwin always use MPLABSIM simulator */
Ayne is offline
Old 15th January 2007, 04:52 PM   #4
Look on the PICList - there's a delay code generator.
Old 15th January 2007, 06:35 PM   #5
Ayne,
When you find the delay code generator, could you post a link to it.
I would like to have that.
mramos1 is offline
Old 15th January 2007, 11:21 PM   #6
Originally Posted by mramos1
Ayne,
Jesus! - you've got almost 1500 posts here, and you can't be bothered to look on the PICList for the blindingly obvious delay code generator?.
Here's the link! http://www.piclist.com/techref/picli...egen/delay.htm
Old 16th January 2007, 12:54 AM   #7
I thought if Ayne needs it and was off to find it, I could ask him for a link.
He does not have to post it. I do not see where it has to do with anything but I will go find it later. I can find the PIClist site and wing the delay code generator part.
I do stuff for others to help them out when they ask, if I can, and it was not like asking a lot.
Sorry.
I tought I would save time on something that I might use (sure I would try it and going full on PIC assembler and out of the BASIC) as well others might want it as well and be able to find it here from a link.
By the tone, I take it PICList should be something I check though I still use BASIC?
mramos1 is offline
Old 16th January 2007, 01:16 AM   #8
Online version:
or
http://www.piclist.com/cgi-bin/delay.exe
EDIT: Never found the Windows version. But that works for me.
mramos1 is offline
Old 16th January 2007, 07:40 AM   #9
Here's a windows version - http://www.mnsi.net/~boucher/picloops.html
gregmcc is offline
Old 16th January 2007, 01:10 PM   #10
Delay X cycles (7-1030) exclusive (11 to 1034 cycles inclusive of call and return)
From Dwayne Reid
;10 bit delay routine providing 1 cycle resolution.  Works with both 12 & 14 bit core PICs.
;Original idea from Mike Harrison.  This version by Dwayne Reid
;enters with upper 8 bits of delay in DELAYU, lower 2 bits in bits 1,0 of DELAYL
;bits 7..2 in DELAYL can be used as flags for whatever purpose desired.
;returns with W destroyed
Delay10bit      ;delay is 10 bit value + 7 cycles ( + call + return, if any)
     incf        DELAYU,F        ;correct for dec & test instead of test & dec
Dly10bLoop
     comf        DELAYL,W        ;invert LSBs
     decfsz      DELAYU,F
       goto      Dly10bLoop      ;coarse delay to closest 4 cycles
     andlw       b'00000011'
     addwf       PCL,F
     nop
     nop
     nop
I want to gernate variable delays in my program
I found this on the PICLIST.
What is the meaning of above line??? For what pupose i can use...Can any one gave me example???
Ayne is offline
Old 16th January 2007, 01:15 PM   #11
Why not use the delay code generator there?, two of us have now posted direct links to it.
Old 16th January 2007, 03:07 PM   #12
cuz i need different delays in my program.
Just like this
movlw .34 ;delay of 34uSec
call delay
above code is just for an example...
But the code generater creat a fix delay.
Ayne is offline
Old 16th January 2007, 03:14 PM   #13
Thank u..... Nigel Goodwin , gregmcc , mramos1....
Ayne is offline
Old 16th January 2007, 03:20 PM   #14
Just like this
What sort of range and resolution do you need?, my tutorials generally include variable delays - using a 1mS resolution (based on the code generator).
Old 17th January 2007, 12:45 AM   #15
Ayne.
You can pick the range of delays times you need, say 1ms to 500ms (1/2 a second). I would make a 1ms delay via the online calc/delay generator.
Then convert it to a subroutine you can CALL. Each time you call it you get about 1ms (there is some overhead).
For 25ms make a loop to call it 25 times.
MPLABS has a stopwatch you can time it with too.
If you need 500ms, you can call another routine that you call 100msec and loop 5 times calling it. And of course 100msec: calls your 1ms subroutine 100 times.
Hope that makes since.
mramos1 is offline
call
PLL WITH PIC AND TSA5511 savnik Micro Controllers 23 26th April 2009 08:50 PM
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
DS1302 with PIC16f877 program RasCreationKing Micro Controllers 28 3rd May 2007 01:03 PM
patgen ppcv Micro Controllers 8 19th January 2005 09:01 AM
ya mari_69 Micro Controllers 4 7th June 2004 02:29 PM
