+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 17 of 17
Thread: Call Them
  1. #16
    Ayne Newbie
    Join Date
    Apr 2006
    Location
    Multan, Pakistan.
    Posts
    416
    Thanks mramos1.
    Is there any 16-16 bit multiplication program offline......
    16-16 bit multiplication is available on piclist but i can use only it online.
    I want to download 16-16 bit multiplication(for windows) program to use it later ...
  2. #17
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,775
    There are plenty of multiplication examples about - and the PICList isn't restricted in any way, simply cut and paste the code off the screen?.
    If you like I can post the maths routines I always use?, they are about to appear in my next tutorial (interfacing a Dallas DS1620 temperature sensor).
    Quick edit, here are the routines I use!.
    ;16 bit Maths subroutines
    Sub16:
           		COMF   Acc2H, f       		; Take two's complement
    		COMF   Acc2L, f       		; of Acc2. If zero, Acc2L
    		INCF   Acc2L, f
    		BTFSC  STATUS, Z   		; overflowed, so carry
    		INCF   Acc2H, f       		; into Acc2H.
    Add16:
           		BCF    Flags, OverFlow 		; clear overflow flag
    		MOVF   Acc2L, w    		; Add the LSBs. If carry,
    		ADDWF  Acc1L, f
    		BTFSC  STATUS, C   		; increment MSB of sum.
    		INCF   Acc1H, f
    		MOVF   Acc2H, w   		; Add the MSBs
    		ADDWF  Acc1H, f
    		BTFSC  STATUS, C   		; check for sum overflow
    		BSF    Flags, OverFlow 		; set overflow flag
    		MOVF   Acc1L, w    		; return lobyte in W
    		RETURN
    Mult16:
    		CLRF   Acc3H          		; Clear product to make
    		CLRF   Acc3L         		; way for new calculation.
    		MOVLW  d'16'        		; Number of bits to calc.
    		MOVWF  tmp1
    Multiply_loop
    		BCF    STATUS, C
    		RLF    Acc3L, f        		; Shift product left.
    		RLF    Acc3H, f
    		BCF    STATUS, C
    		RLF    Acc1L, f        		; Shift multiplicand left.
    		RLF    Acc1H, f
    		BTFSS  STATUS, C    		; If carry, add multiplier
    		GOTO   Multiply_skip
    		MOVF   Acc2L, w      		; to the product. Else skip.
    		ADDWF  Acc3L, f
    		BTFSC  STATUS, C    		; 16-bit addition: prod+mulp
    		INCF   Acc3H, f
    		MOVF   Acc2H, w
    		ADDWF  Acc3H, f
    Multiply_skip
    		DECFSZ tmp1
    		GOTO   Multiply_loop
    		MOVF   Acc3H, w
    		MOVWF  Acc1H        		; return answer in Acc1
    		MOVF   Acc3L, w
    		MOVWF  Acc1L        		; with lobyte in W
    		RETURN
    DIV16:          MOVF    Acc2H, w                ; Check for division by 0.
    		IORWF   Acc2L, w
    		BTFSC   STATUS, Z
    		RETLW   d'255'        		; Error code= 255: return.
    		MOVLW   d'1'          		; Otherwise, initialize variables
    		MOVWF   tmp1
    		CLRF    tmp2         		; index for the division.
    		CLRF    Acc3H
    		CLRF    Acc3L
    Divide_sh_loop  BTFSC   Acc2H, d'7'   		; Shift divisor left
    		GOTO    Divide_d1
    		BCF     STATUS, C     		; until msb is in
    		RLF     Acc2L, f         	; Acc2H.7.
    		RLF     Acc2H, f         	; tmp1 = no. of shifts+1.
    		INCF    tmp1
    		GOTO    Divide_sh_loop
    Divide_d1       BCF     STATUS, C
    		RLF     Acc3L, f          	; Shift quotient left.
    		RLF     Acc3H, f
    		MOVF    Acc2L,w       		; top = top - btm.
    		SUBWF   Acc1L, f
    		BTFSC   STATUS, C     		; If top - btm < 0 then
    		GOTO    Divide_d2
    		MOVLW   d'1'          		; top = top + btm
    		SUBWF   Acc1H, f
    		BTFSC   STATUS, C     		; The idea is to do the
    		GOTO    Divide_d2
    		INCF    Acc1H, f         	; the subtraction and comparison
    		MOVF    Acc2L, w      		; (top > btm?) in one step.
    		ADDWF   Acc1L, f
    		goto    Divide_reentr 		; Then, if btm > top, undo <Microchip instruction>
    Divide_d2       MOVF    Acc2H, w      		; the subtraction by adding
    		SUBWF   Acc1H, f
    		BTFSS   STATUS, C     		; top and btm back together
    		goto    Divide_less   		; <Microchip instruction>
    		BSF     Acc3L,  d'0'
    Divide_reentr
    		BCF     STATUS, C
    		RRF     Acc2H, f
    		RRF     Acc2L, f
    		DECFSZ  tmp1
    		GOTO    Divide_d1
    		MOVF    Acc3H, w
    		MOVF    Acc3L, w
    		RETURN
    Divide_less     MOVF    Acc2L, w      		; btm > top, so
    		ADDWF   Acc1L, f
    		BTFSC   STATUS, C     		; undo the subtraction by
    		INCF    Acc1H, f         	; adding them back together.
    		MOVF    Acc2H, w
    		ADDWF   Acc1H, f
    		goto    Divide_reentr 		; <Microchip instruction>
    SHIFTR:         MOVWF    Acc2L
    _LoopR          BCF      STATUS, C
    		RRF      Acc1H, F
    		RRF      Acc1L, F
    		DECFSZ   Acc2L
    		GOTO     _LoopR
    		MOVF     Acc1L, W
    		RETURN
    SHIFTL:         MOVWF    Acc2L
    _LoopL          BCF      STATUS, C
    		RLF      Acc1L, F
    		RLF      Acc1H, F
    		DECFSZ   Acc2L
    		GOTO     _LoopL
    		MOVF     Acc1L, W
    		RETURN
+ Reply to Thread
Page 2 of 2
First 1 2
  1. PLL WITH PIC AND TSA5511
    By savnik in forum Micro Controllers
    Latest: 26th April 2009, 07:50 PM
  2. Problem with LCD code?
    By spondootre in forum Micro Controllers
    Latest: 29th April 2008, 09:15 AM
  3. DS1302 with PIC16f877 program
    By RasCreationKing in forum Micro Controllers
    Latest: 3rd May 2007, 12:03 PM
  4. patgen
    By ppcv in forum Micro Controllers
    Latest: 19th January 2005, 08:01 AM
  5. ya
    By mari_69 in forum Micro Controllers
    Latest: 7th June 2004, 01:29 PM
Tags for this Thread
