Old 7th January 2007, 11:05 AM   #1
Default compare a value to a table
Hi All
Need your help
- using PICBASIC PRO (pic simulator IDE 6.2 compiler)
- i input an analog value ranging from 0-2.5V and i converted it to digital 10bit
MY PROBLEM is :
what i need to do for example :
if the digital value is 0000010101 output 2%
if the digital value is 0000011011 output 2.2%
should i place the 2% .... in an array table and compare them,
if yes how this can be done?
Please help
pouchito is offline
Old 7th January 2007, 11:32 AM   #2
How many values do you need?.
Old 7th January 2007, 11:57 AM   #3
i minimize it to 128 values
pouchito is offline
Old 7th January 2007, 12:02 PM   #4
Is it a linear progression?.
Old 7th January 2007, 12:08 PM   #5
not 100% linear
i.e: in some cases, for different input values, we can get same % results
ex: for 0000001010 ==> 2%
for 0000001011 ==> 2%
for 0000001100 ==> 2%
for 0000001101 ==> 2.1%
for 0000001110 ==> 2.2%
for 0000001111 ==> 2.3%
for 0000010000 ==> 2.3%
for 0000010001 ==> 2.3%
pouchito is offline
Old 7th January 2007, 12:21 PM   #6
If it's not linear you need a table then! - unless you can produce a formula that fits it?.
Old 7th January 2007, 12:31 PM   #7
how to do a table ?
pouchito is offline
Old 7th January 2007, 02:35 PM   #8
I don't use PICBASIC, so I can't help you with that, in assembler you use a series of RETLW's.
Can you define a single dimensional array in your BASIC?.
EDIT:
Quick rethink! - does your BASIC support the DATA statement?, this is an example from the PIC BASIC compiler version of WinPicProg I was working on.
DATA 45, 255, 0, "H", "e", "l", "l", "o" - store 8 bytes of data.
READ A - read the first three bytes of data to three variables.
READ B
READ C
RESTORE 4 - reset the read point to 4th byte
FOR X=1 TO 5 - print a stored string.
    READ A
    PRINT CHR$(A)
NEXT X
Old 7th January 2007, 02:50 PM   #9
unfortunately , it does not support this
pouchito is offline
compare, table
PIC: Table lookup across page boundary eblc1388 Micro Controllers 11 16th August 2005 03:43 PM
18F Lookup Table Cose Snippet [ASM] pittuck Micro Controllers 0 14th December 2004 08:40 AM
PIC 16F873 resetting by itself? nclark Micro Controllers 10 30th June 2004 10:30 PM
truth table vs lookup table alamy Micro Controllers 14 16th June 2004 08:48 PM
Lookup table for LCD and 7 segment display patricktran Micro Controllers 3 23rd April 2004 02:43 PM
