Old 7th January 2007, 10:15 AM   (permalink)
Default About Bill Sherman's PIC-Key
hello all,
I think I'll build this PIC-Key, that I believe some of you may know:
http://home.comcast.net/%7Ebotronics/pickey.html
Now therearea few technical question I have to ask:
1) I want to use the PIC-Key with PIC12F675 - means 8 pins. but the example in the page is for one with 40 pins!
it uses only 5 of them: 5V, MCRL, GND, B.6, B.7.
I have no idea where to connect these two last connections, to B6 and B7.
I also don't know how (should I connect it directly to the pins? should I use resistors caps etc?)
2) In this circuit (http://home.comcast.net/%7Ebotronics/pickeylay.gif) that explains the connections between the PIC-Key and the MicroPic itself, there's one diode (D1) and one Crystal with no values. How do I choose the right Diode and Crystal to this circuit?
lot of thanks.
chui is offline
Old 7th January 2007, 01:50 PM   (permalink)
When I program pics, I have VPP, VDD, GND, DATA and CLOCK (CLK). I use the ICD which has a programmer that used these signals.
If that what you are asking? Look at the 877 datasheets and see which is data and which is clock, then match them to the 675. Assuming this is an ICSP, and not something that does serial programming via a bootloader.
EDIT: Datasheet will tell you the crystal and caps you need. I would think any small signal diode 1N4148 would work. Also, depending on the PIC you can use the internal oscillator?
Disclaimer, I am not up on the JDK (or whatever unit they mentioned on the page). Just tring to help.
mramos1 is offline
Old 7th January 2007, 02:44 PM   (permalink)
The 877 doesn't have an internal oscillator, the crystal can be any value up to 20MHz - usual values are either 20MHz or 4MHz. As you say, a 1N4148 will be fine, as will pretty well any silicon diode.
Nigel Goodwin is online now
Old 8th January 2007, 06:58 PM   (permalink)
Well, I don't sure where to find the information about the oscillator. I did search.
if, any of you can tell me what should I look after, I'll be happy, AND I would be able to start the building of the circuit by tomorrow!
http://ww1.microchip.com/downloads/e...Doc/41190c.pdf
really. thanks.
chui is offline
Old 9th January 2007, 01:09 AM   (permalink)
You should connect B.7 to GP0 and B.6 to GP1.
The 12F675 has an internal oscillator that can be used. It's detailed on page 52 of the data sheet.
As a starting point for a project I would suggest using the template supplied by microchip. You will find this in
C:\Program Files\Microchip\MPASM Suite\Template\Code\f675temp.asm
This file is setup to use the internal oscillator.
HTH
Edit, You don't mention a power supply. This circuit needs a separate 5V regulated supply to work.
Pommie is offline
Old 9th January 2007, 01:57 PM   (permalink)
Great.
Thanks for the note, and for the rest. I hope it will go well.
chui is offline
Project to lower my AC bill mramos1 Electronic Projects Design/Ideas/Reviews 20 21st August 2006 04:14 PM
friends of bill wilson tom muleady Chit-Chat 8 7th August 2006 07:21 PM
Bill Gates tansis Chit-Chat 20 1st August 2005 06:32 PM
color sensor...i'd my ckt to detect different money bill jamescruz General Electronics Chat 2 7th August 2003 04:48 PM
