I built a 2digit up counter from pic16f84a..when the RB0 button pressed each time the display counts up one by one....it can counts up to 99.... RB0-switch RB1-Rb7 -7 segmants RA0-Digit 2 driving transistor RA1-Digit 1 driving transistor My problem is its counting in a messy way (not in the proper order 1,2,3....). so I changed my Delay when higher delays its counting correctly.but the two displays are blinking.... here I didn't debounce the button(I dont know the debounce codings).I think the delay is too fast for the switch. How to prevent this I need a smooth count when a button is pressed. I have attached the cct & the codings...... | |
Hi, Firstly: hardware. It all looks 'ok', but you could use some resistors on portb (one for each segment/pin) to the segment LED's. From that it appears PORTB is driving the segment LED's directly, which is probably drawing a fair amount of current from the pins. 100-600 ohms should do (depending on your supply voltage), just to limit the current. Ok, software. Again, I just skimmed it. The reason increasing your 'delay' is making the display flash is becase that delay is used between displaying numbers on each display. So if the delay is longer than, say, 40ms, you'll see it flash. I don't tihnk the delay time is the problem, reduce it to a value where you cannot percieve flashing. Now...what happens if you HOLD the button down? I'll tell you what..every time it checks the button..its pressed, so it increments the counter, meaning your counter will count VERY quickly. Releasing the button it would stop at a seemingly random number. You need a way to check that the button has been released so that it only increments by 1, every time the button is pressed THEN released. THis can be done with a simple 'flag'...a single bit of a register. I often include a 'TEMP' register for this exact reason. As for 'debouncing' I usually just check if a button is pressed, if it is, wait 20ms, then check again. If its not pressed the second time, then its a false trigger, if it is still pressed then the user has in fact pressed it. Releasing the button usually doesn't cause me any problems, but another small delay can't hurt. A quick bit of debouncing code: PRESS BTFSC PORTB,0 ;Button Pressed GOTO LOOP ;Back to Loop (we checked if its 0, its not) ; its a 0, its pressed CALL DELAY1 ; call a delay, just used 'delay1' here as a reference. BTFSC PORTB,0 ;Button Pressed GOTO LOOP ;Back to Loop (false alarm!) ; it is still pressed, so now you do what you want to do COUNTUP ...... As I said, 20ms is just a rough guide, you might get away with a lower value, you might need a higher value. Remeber this is NOT the same delay as is used for displaying the digits, although you could try it. So...just to recap..add a flag, thats set when the button is pressed, and cleared when the button isn't pressed. Your 'check button routine' sohuld check this flag...if its set, then the button is still held down from the last time it incremented...and so should be ignored...back to the loop. If its clear then its a 'new button press', so you go through your debounce routine, if its sitll pressed, then set the flag, do your COUNTUP routine, and back to the loop. My two cents. Blueteeth
__________________ Inconsistency is the key to flexibility! Last edited by Blueteeth; 14th December 2006 at 04:17 AM. | |
| | #3 | |
Ya.. I didn't mentioned the portB output resisters Bcuz to reduce my drawing.already I have 220 ohm resisters with port B......I must try ur Debounce codings u gave to my SW1.I'll change the DELAY1 & see. | ||
Don't forget to check if the button has been released! Even with the debounce routine, it'll do that same thing, I only included that bit because you said you didn't know how to 'debounce' in code. Read over it, if needds be, if I get round to it I'll post another 'button check' code snippet, with a flag, so it only increments when the button is pressed, NOT continuously when the button is held down.
__________________ Inconsistency is the key to flexibility! | |
I already add a flag... In this method I added a small debounce method to give a correct counting in my 2digit display.the button debounce really worked well by giving a correct counting.but the problem is its displaying the output when u release the button.when u long press the button the display is going off and when u release only its displaying. how to prevent this I need to display the output when u press the button with a correct counting. | |
| | #6 |
Good call with the 'txt' file pseudo code...saves us having to wade though lots of code And means I can see what you're doing without including the code thats working fine.Hmm it seems you are not debouncing the button. In order to debounce a button, it must be checked twice. Once, then a small delay, then again to see if its still pressed or if its a false trigger. In your routine, you are indeed checking the flag, but only checking the button once. The debounce routine is simply used in place of 'btfsc PORTA,4'. It is just used to 'read' a buttons state twice, with a delay inbetween to make sure its on, or off. The reason your display is going off when you hold the button down is because it never gets to the 'Stay' subroutine, which if I'm not mistaken you use to display the digits. I don't like to complicate what should be a fairly straight forward problem, but, if you tihnk about it, with reading a button (debounced or otherwise) there are only two posibilities. On, or Off. But...when we add our flag, theres four posibilities: Flag Button 0 0 - (1) displaying the digits, key isn't pressed 0 1 - (2) new key press (flag =0, wasn't pressed before) 1 0 - (3) key released (flag = 1, WAS pressed, but now its not) 1 1 - (4) key was pressed before, and is STILL pressed. So, for (1) we go to the 'stay routine' and clear flag. (2) we go to the 'Countup' routine and set flag. (3) we go to the 'stay routine', and clear flag and (4) we go to the 'stay routine', with the flag still set. So, as you can see, we only go to the 'coutup' routine when the flag is 0 and the button (after debouncing) is 1. Because the flag represents the buttons previous state, last time it was checked, we can say that we only do something other than go to 'stay' if the button has gone from 0 to 1. Not 1 to 0. I modified your little txt file Try and work out what I did, and WHY I did it. Thats the problem with loops, its easy to lose track of where the program is going under certain conditions.GOod Luck Blueteeth
| | #7 | |
Thankx a lot.. | ||
| | #8 |
Hi, I saw there is two transistors are attached,what if we don't attach transistor with Port A0 and Port A1, is there any other way to join these segment display to the PIC because lecturer didn't give us transistors. Thanks | |
| | #9 | |
BTW its not a good idea to drive them without transistors.The display will be very dim. | ||
| | #10 |
There are four button states of which I usually only worry about the "new press" state and ignore the "still pressed", "still released", and "new release" states. Use a switch state latch or memory or flip-flop, what ever you'd like to call it, and some simple logic (example below). If you're using a long enough delay (the display delay) between sampling switches you probably don't need a debounce delay within the "press" routine. Regards, Mike Code: LOOP clrf PORTB ; blank the display
movlw b'00000011' ;
xorwf PORTA,F ; flip digit select bits
movf DIGIT1,W ;
btfss PORTA,1 ; display 1? yes, skip, else
movf DIGIT2,W ;
call TABLE ; get segment data
movwf PORTB ; display new digit
call Delay ;
PRESS comf PORTB,W ; sample active low switch
andlw b'00000001' ; filter out all but the RB0 switch bit
xorwf swlatch,W ; changes (press or release)
xorwf swlatch,F ; update switch state latch
andlw swlatch,W ; filter out "new release" bits
skpnz ; a "new press"? yes, skip, else
goto LOOP ; go back to display loop
COUNTUP
| | #11 |
I probably should have explained that switch state logic. Here's a quick summary of the four states we can detect when using a memory or latch. Consider the fresh sample as the "new" bit and the latch or memory as the "old" bit. Code: new^old result (changes) 0 ^ 0 0 still released 0 ^ 1 1 new release 1 ^ 0 1 new press 1 ^ 1 0 still pressed The exciting part about those few lines of code is that they can process up to 8 switches in parallel. Good luck. Mike | |
| | #12 |
Mike thats a really nice method.DId you see this threads date quite old now I can understand much better than early days I'm going to study it ASAP.Thanks for the unseen examples sir.......... | |
| | #13 |
Here is a routine that incorporates a flag file to keep track of the condition of the push-button: (delete the last CALL Delay instruction.) Last edited by colin55; 27th April 2009 at 08:12 AM. | |
| | #14 |
Hi Gayan, I'm sorry. I didn't see the original thread date. Take care. Mike | |
| | #15 |
Thanks everyone and specialy Gayan for your quick reply its really appreciable. ![]() Here is my coding for my program,actually I need to make a 2x7 segment display which can count from 0-99 in a random like lottery machine display.Please check my coding correct it if is possible.I have also some problems in making this circuit on breadboard. Please reply me soon | |
| 16f84a, counter, digit, pic |
| Input Counter Pic16F84A (Code problems) | loco | Micro Controllers | 4 | 26th September 2006 02:19 PM |
| Migrating 16c57 to 16F57 | j_norrie | Micro Controllers | 6 | 31st July 2006 04:03 PM |
| Problem with PIC 16F84A counter | Ivanho | Micro Controllers | 5 | 28th October 2005 06:29 AM |
| [help] Power consumption issue on bullet counter project * | Lanzer | Electronic Projects Design/Ideas/Reviews | 13 | 26th August 2005 07:06 AM |
| Crude assembly counter | Mark Lazarides | Micro Controllers | 5 | 28th February 2004 08:22 PM |
