| Hi Guys! I have just programed my PWM code into PIC16F873A...was wondering if I just connect +5V to VDD, Ground my Vss, I should expect a square wave(PWM) at CCP1 pin?? or do i have to connect some circuity? below is my C code. #pragma chip PIC16F873A #include "math24f.h" void int_pwm(void) { int duty; CCP1CON = 0; TMR2 = 0; TRISC.2 = 0; PORTC.2 = 0; PIE1.1 = 0; PIE1.2 = 0; PR2 = bin(00111110); CCP1CON.5 = 0; CCP1CON.4 = 0; duty = bin(00011111); CCPR1L = bin(00011111); T2CON = bin(00000000); CCP1CON = bin(00001100); } void main(void) { int_pwm(); T2CON.2 = 1; while(1); } Pls kindly advise.... thank for inputs | |
| I haven't looked carefully at your code yet, but can't you just simulate it? or does whatever compiler package you're using not allow that? From your code it looks to me like you might be using CC5x, which I've heard will allow simulation from within MPLAB... I would also recommend BoostC to you, which has an IDE and also integrates with MPLAB, either one of which allows you to run simulations before you worry about trying it out on a real PIC. The PWM module doesn't require any external circuitry to operate, so as long as your code is correct you should see an output...
__________________ EEgeek.net | |
| and make sure your setting are good for the osc speed you're using. Same for your config fuses. i don't know if this software may help you, but anyways... http://mister-e.org/pages/utilitiespag.html
__________________ Steve | |
| 8bit shift register with latch style setup? | bh00 | Electronic Projects Design/Ideas/Reviews | 15 | 18th May 2006 05:53 AM |
| LED transistor matrix setup idea | bh00 | General Electronics Chat | 2 | 10th May 2006 10:38 AM |
| back to step 1. i need a first setup | DanD | Micro Controllers | 15 | 27th April 2006 09:07 AM |
| my 8051 setup needs an opinion | mstechca | General Electronics Chat | 13 | 19th April 2006 04:12 PM |
| What's the most basic setup for tuning pipes? | atferrari | Electronic Projects Design/Ideas/Reviews | 6 | 30th November 2004 10:05 PM |
