Tools | Display Modes |
#2 (permalink) | |
Please check edSim-51: http://edsim51.com/
Microcontroller Programming Forums: http://forum.mcuprogramming.com Answer to your questions! --- Microcontroller Programming Blog: http://mcu-programming.blogspot.com uC - News, Resources and Tutorials Last edited by sci-3d; 8th December 2006 at 03:16 AM. |
#7 (permalink) |
http://www.drpaulcarter.com/pcasm/
Well, start programming!!!! If it is due next week, then you have a week to learn assembly, and then make(and debug) a complete calculator program...
There is no "I" in "team", unless Apple makes it... Then it would be iTeam. |
#8 (permalink) |
Also we don't mind helping but we won't do all the work for you.
I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. |
#9 (permalink) |
http://www.pjrc.com/tech/8051/
scroll down towards the bottom. There is a bunch of sample code at the bottom. There is also a pretty cool development board, too(didn't look at it much, though).
#10 (permalink) |
************ LABCENTER ELECTRONICS ************ ************ Proteus VSM Sample Design Code ************ ************ Integer Calculator ( 2K Code Limit) ************ ************************************************** *****************************/ #include <intrins.h> #include <reg51.h> #include "calc.h" //Variables static data LONG lvalue; static data LONG rvalue; static data CHAR currtoken; static data CHAR lasttoken; static data CHAR lastpress; static xdata CHAR outputbuffer[MAX_DISPLAY_CHAR]; VOID main (VOID) //Initialise our variables and call the //Assembly routine to initialise the LCD display. { lvalue = 0; rvalue = 0; currtoken = '='; lasttoken = '0'; initialise(); // Initialize the LCD calc_output(OK); calc_evaluate(); } VOID calc_evaluate() { CHAR data key; INT data i; CHAR xdata number[MAX_DISPLAY_CHAR]; CHAR xdata *bufferptr; // Clear the buffer before we start. for (i = 0; i <= MAX_DISPLAY_CHAR; i++) { number[i] = ' '; } bufferptr = number; for (; { key = calc_getkey(); if (calc_testkey(key)) // Key test positive for digit so we read it into the // buffer and then write the buffer to the screen/LCD. // Size limit the number of digits - allow for termination // and possible negative results. { if (bufferptr != &number[MAX_DISPLAY_CHAR - 2]) { *bufferptr = key; calc_display(number); bufferptr++; } } else // Key is an operator so pass it to the function handlers. // If we are just after startup or cancel then assign to lvalue // otherwise assign to rvalue. { //Assign the value. if (lasttoken == '0') { lvalue = calc_asciidec (number);} else { rvalue = calc_asciidec (number);} //Clear the number buffer. bufferptr = number; for (i = 0;i <= MAX_DISPLAY_CHAR; i++) { number[i] = ' '; } //Process the Operator. currtoken = key; if (currtoken == 'C') { calc_opfunctions(currtoken); } else { calc_opfunctions(lasttoken); } // Clear the outputbuffer for reuse on next operation. for (i = 0;i <= MAX_DISPLAY_CHAR;i++) { outputbuffer[i] = ' ';} bufferptr = number; // Handle the equals operation here for brevity. // All we need do is preserve the previous operator in // lasttoken. if (currtoken != 0x3D) lasttoken = currtoken; } lastpress = key; } } VOID calc_opfunctions (CHAR token) // Handle the operations. Lvalue holds the result and we test for // consecutive operator presses. { CHAR data result; switch(token) // Add. { case '+' : if ((currtoken == '=' ) || ((lastpress >= 0x30) && (lastpress <=0x39))) { lvalue += rvalue; result = calc_chkerror(lvalue); } else { result = SLEEP; } break; // Subtract. case '-' : if ((currtoken == '=' ) || ((lastpress >= 0x30) && (lastpress <=0x39))) { lvalue -= rvalue; result = calc_chkerror(lvalue); } else { result = SLEEP;} break; // Multiply. case '*' : if ((currtoken == '=' ) || ((lastpress >= 0x30) && (lastpress <=0x39))) { lvalue *= rvalue; result = calc_chkerror(lvalue); } else { result = SLEEP;} break; // Divide. case '/' : if ((currtoken == '=' ) || ((lastpress >= 0x30) && (lastpress <=0x39))) { if (rvalue) { lvalue /= rvalue; result = calc_chkerror(lvalue); } else { result = ERROR;} } else { result = SLEEP;} break; // Cancel. case 'C' : lvalue = 0; rvalue = 0; currtoken = '0'; lasttoken = '0'; result = OK; break; default : result = SLEEP; } calc_output(result); } /************************************************** ********************** ***** Utility Routines ***** ***************************/ INT calc_chkerror (LONG num) // Check upper and lower bounds for the display. // i.e. 99999999 and -99999999. { if ((num >= -9999999) && (num <= 9999999)) return OK; else return ERROR; } VOID calc_output (INT status) // Output according to the status of the operation. // *Sleep* is used for the first op press after a full cancel // or on startup. { switch (status) { case OK : calc_display(calc_decascii(lvalue)); break; case SLEEP : break; case ERROR : calc_display("Exception "); break; default : calc_display("Exception "); break; } } LONG calc_asciidec (CHAR *buffer) // Convert the ASCII string into the floating point number. { LONG data value; LONG data digit; value = 0; while (*buffer != ' ') { digit = *buffer - 48; value = value*10 + digit; buffer++; } return value; } CHAR *calc_decascii (LONG num) // A rather messy function to convert a floating // point number into an ASCII string. { LONG data temp = num; CHAR xdata *arrayptr = &outputbuffer[MAX_DISPLAY_CHAR]; LONG data divisor = 10; LONG data result; CHAR data remainder,asciival; INT data i; // If the result of the calculation is zero // insert a zero in the buffer and finish. if (!temp) { *arrayptr = 48; goto done; } // Handle Negative Numbers. if (temp < 0) { outputbuffer[0] = '-'; temp -= 2*temp; } for (i=0 ; i < sizeof(outputbuffer) ; i++) { remainder = temp % divisor; result = temp / divisor; // If we run off the end of the number insert a space into // the buffer. if ((!remainder) && (!result)) { *arrayptr = ' ';} // We're in business - store the digit offsetting // by 48 decimal to account for the ascii value. else { asciival = remainder + 48; *arrayptr = asciival; } temp /= 10; // Save a place for a negative sign. if (arrayptr != &outputbuffer[1]) arrayptr--; } done: return outputbuffer; } CHAR calc_testkey (CHAR key) // Test whether the key is a digit or an operator. Return 1 for digit, 0 for op. { if ((key >= 0x30) && (key <= 0x39)) { return 1;} else { return 0;} } /************************************************** ********************** ***** I/O Routines ***** ***********************/ CHAR calc_getkey (VOID) // Use the input routine from the *Keypad_Read* assembly file to // Scan for a key and return ASCII value of the Key pressed. { CHAR data mykey; do mykey = input(); while (mykey == 0); return mykey; } VOID calc_display (CHAR buf[MAX_DISPLAY_CHAR]) // Use the Output and Clearscreen routines from the // *LCD_Write* assembly file to output ASCII values to the LCD. { INT data i = 0; clearscreen(); for (i ; i <= MAX_DISPLAY_CHAR ; i++) { if (buf[i] != ' ') { output(buf[i]); } } } |
| hyperterminal communication w/ 8051 | spyghost | Micro Controllers | 8 | 22nd May 2008 10:54 AM |
| 8051 Microcontroller (Urgent Help) | UAE_Engineer | Micro Controllers | 5 | 22nd March 2007 11:13 AM |
| Could I get away with this? (8051 + AM29F010B) | mstechca | Micro Controllers | 0 | 9th March 2006 02:05 AM |
| interfacing 16*16 matrix display with 8051 | pmphilip | Micro Controllers | 0 | 1st February 2005 03:47 AM |
| 8051 "data" storage within program memory - how? | L0D|Mr_B | Micro Controllers | 1 | 11th January 2004 02:56 PM |
