Old 19th November 2006, 06:12 AM   #1
Default Problem with 89s52 program..
Hi ..
I wrote the following code in Keil for a 89s52 and downloaded it to the chip..
It is only for the bot to move straight..I am using a L298HN ..the code ompiled successfully .. But the bot does not move .. I am getting a voltage reading of 3-4 volts at the Port 2 pins .. PLzz help me out ..
File Type: c forwardtest.c (173 Bytes, 17 views)
jagzviruz is offline
Old 19th November 2006, 07:56 AM   #2
try this ok
#include<AT89x52.h>
int forward=0x33; //assum the code for for movement
int revers=0xD2; //assum the code for rev movement
void gofor();
void gorev();
void delay();
void main()
while(1){
gofor();
delay();
delay();
delay();
delay();
gorev();
delay();
delay();
delay();
delay();
return;
void gofor()
P2=forward;
void gorev()
P2=revers;
void delay()
for(;;
for(;;
manish12 is offline
Old 20th November 2006, 03:31 PM   #3
The robot go forward with motor I think you should learn how to control motor first.
Microcontroller Programming Forums:
http://forum.mcuprogramming.com
Answer to your questions!
Microcontroller Programming Blog:
http://mcu-programming.blogspot.com
uC - News, Resources and Tutorials
sci-3d is offline
Old 21st November 2006, 06:57 AM   #4
i could not quite understand sci-3d .. i'll shortly put up the circuit i am using ..
Old 23rd November 2006, 04:55 AM   #5
Default Am attaching the l298 ckt that i am using
I have attached the l298 ckt that i am using .. will some one plzz look it up and tell me if it is correct or not
89s52, problem, program
program for writing and testing circuits luca-deltodesco General Electronics Chat 3 13th August 2006 11:17 AM
Newbie, please help with power problem techieguy Micro Controllers 11 25th July 2005 01:07 PM
Program Address for 16F628A johnnyquest Micro Controllers 1 11th January 2005 07:47 PM
Problem with 89S52 rellutzu Micro Controllers 6 24th May 2004 03:23 AM
PicBasic Keypad program Sora Micro Controllers 0 20th April 2004 08:02 PM
