Old 1st November 2006, 12:38 PM   #1
Default Problem with LCD code?
I'm trying to do an example set in a book to learn how to use an LCD in a project, however i've copied the code out and it doesn't work, in previous examples of code there have been errors in the book and i've managed to find them and get the code to work. I can't figure this one out!!
When connected I get a line of solid characters across the 1st line of the LCD and that's it, which is the same as I get if the chip is not connected and the LCD is just powered up. I am supposed to just be using 4 data lines.
R/W tied to ground
RS - A1
E - A2
Using a 16F84A as this was the one in the book, not the controller of my choice but I want to get the thing working on this before moving on!!
Can anybody advise on any code issues?
;ANHEAD84.ASM	Alphanumeric display header using 6 I/O lines.
;On the display RS pin 4 connects to A1.
;R/W pin 5 connects to 0v.
;E pin 6 connects to A2
;D4-D7 pins 11-14 connect to B0-B7.
	TMR0            EQU     1       ;TMR0 is FILE 1.
	PORTA           EQU     5       ;PORTA is FILE 5.
	PORTB           EQU     6       ;PORTB is FILE 6.
	STATUS          EQU     3       ;STATUS is FILE3.
	ZEROBIT         EQU     2       ;ZEROBIT is Bit 2.
	LIST            P=16F84    ;We are using the 16F84.
	ORG             0          ;0 is the start address.
	GOTO            START      ;goto start!
; SUBROUTINE SECTION.
;3 SECOND DELAY
DELAY3  CLRF    TMR0            ;START TMR0
LOOPA   MOVF    TMR0,W          ;READ TMR0 IN W
	SUBLW   .96             ;TIME - W
	BTFSS   STATUS,ZEROBIT  ;CHECK TIME-W=0
	GOTO    LOOPA
	RETLW   0               ;return after TMR0 = 96
;P1 SECOND DELAY
DELAYP1 CLRF    TMR0            ;START TMR0
LOOPC   MOVF    TMR0,W          ;READ TMR0 IN W
	SUBLW   .3              ;TIME - W
	GOTO    LOOPC
	RETLW   0               ;return after  tmr0 = 3
CLOCK   BSF     PORTA,2
	NOP
	BCF     PORTA,2
	NOP
	RETLW   0
A       MOVLW          2         ;enables the display
	MOVWF          PORTA
	MOVLW          4H
	MOVWF          PORTB
	CALL           CLOCK
	MOVLW          1H       ;41 is code for A
	MOVWF          PORTB
	CALL           CLOCK   ;clock character onto display.
	RETLW          0
BB      MOVLW          2         ;enables the display
	MOVWF          PORTA
	MOVLW          4H
	MOVWF          PORTB
	CALL           CLOCK
	MOVLW          2H       ;42 is code for B
	MOVWF          PORTB
	RETLW          0
C       MOVLW          2         ;enables the display
	MOVWF          PORTA
	MOVLW          4H
	MOVWF          PORTB
	CALL           CLOCK
	MOVLW          3H
	MOVWF          PORTB
	RETLW          0
D       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           4H
	MOVWF           PORTB
	RETLW           0
E       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           5H
	MOVWF           PORTB
	RETLW           0
F       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           6H
	MOVWF           PORTB
	RETLW           0
G       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           7H
	MOVWF           PORTB
	RETLW           0
H       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           8H
	MOVWF           PORTB
	RETLW           0
I       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           9H
	MOVWF           PORTB
	RETLW           0
J       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0AH
	MOVWF           PORTB
	RETLW           0
K       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0BH
	MOVWF           PORTB
	RETLW           0
L       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0CH
	MOVWF           PORTB
	RETLW           0
M       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0DH
	MOVWF           PORTB
	RETLW           0
N       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	MOVLW           0EH
	MOVWF           PORTB
	RETLW           0
O       MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           4H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0FH
	MOVWF           PORTB
	RETLW           0
P       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0H
	MOVWF           PORTB
	RETLW           0
Q       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           1H
	MOVWF           PORTB
	RETLW           0
R       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           2H
	MOVWF           PORTB
	RETLW           0
S       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           3H
	MOVWF           PORTB
	RETLW           0
T       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           4H
	MOVWF           PORTB
	RETLW           0
U       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           5H
	MOVWF           PORTB
	RETLW           0
V       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           6H
	MOVWF           PORTB
	RETLW           0
WW      MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           7H
	MOVWF           PORTB
	RETLW           0
X       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           8H
	MOVWF           PORTB
	RETLW           0
Y       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           9H
	MOVWF           PORTB
	RETLW           0
Z       MOVLW           2
	MOVWF           PORTA
	MOVLW           5H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0AH
	MOVWF           PORTB
	RETLW           0
NUM0    MOVLW         	2         ;enables the display
	MOVWF          	PORTA
	MOVLW          	3H
	MOVWF          	PORTB
	CALL            CLOCK
	MOVLW          	0H
	MOVWF          	PORTB
	RETLW           0
NUM1    MOVLW          	2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           1H
	MOVWF           PORTB
	RETLW          	0
NUM2    MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           2H
	MOVWF           PORTB
	RETLW           0
NUM3    MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           3H
	MOVWF           PORTB
	RETLW           0
NUM4    MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           4H
	MOVWF           PORTB
	RETLW           0
NUM5    MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           5H
	MOVWF           PORTB
	RETLW           0
NUM6    MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           6H
	MOVWF           PORTB
	RETLW           0
NUM7    MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           7H
	MOVWF           PORTB
	RETLW           0
NUM8    MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           8H
	MOVWF           PORTB
	RETLW           0
NUM9    MOVLW           2         ;enables the display
	MOVWF           PORTA
	MOVLW           3H
	MOVWF           PORTB
	CALL	 	CLOCK
	MOVLW           9H
	MOVWF           PORTB
	RETLW           0
GAP     MOVLW           2
	MOVWF           PORTA
	MOVLW           2H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0H
	MOVWF           PORTB
	RETLW           0
DOT     MOVLW           2
	MOVWF           PORTA
	MOVLW           2H
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0EH
	MOVWF           PORTB
	RETLW           0
CLRDISP CLRF            PORTA
	MOVLW           0H
	MOVWF           PORTB
	CALL            CLOCK  ;clock command onto display.
	MOVLW           1
	MOVWF           PORTB
	CALL            CLOCK
	CALL            DELAYP1
	RETLW           0
; CONFIGURATION SECTION.
START   BSF     STATUS,5        ;Turn to BANK1
	MOVLW   B'00000000'     ;5 bits of PORTA are O/Ps.
	TRIS    PORTA
	MOVLW   B'00000000'
	TRIS    PORTB           ;PORTB IS OUTPUT
	MOVLW   B'00000111'
	OPTION                  ;PRESCALER is /256
	BCF     STATUS,5        ;Return to BANK0
	CLRF    PORTA           ;Clears PORTA
	CLRF    PORTB           ;Clears PORTB
;Display Configuration
	MOVLW   03H             ;FUNCTION SET
	MOVWF   PORTB           ;8bit data (default)
	CALL    CLOCK
	CALL    DELAYP1         ;wait for display
	MOVLW   02H             ;FUNCTION SET
	MOVWF   PORTB           ;change to 4bit
	CALL    CLOCK           ;clock in data
	MOVWF   PORTB           ;must repeat command
	MOVLW   08H             ;4 bit micro
	MOVWF   PORTB           ;using 2 line display.
	CALL    DELAYP1
	MOVLW   0H              ;Display on, cursor off
	MOVWF   PORTB           ;0CH
	CALL    CLOCK
	MOVLW   0CH
	MOVWF   PORTB
	CALL    CLOCK
	CALL    DELAYP1
	MOVLW   0H              ;Increment cursor, 06H
	MOVWF   PORTB
	CALL    CLOCK
	MOVLW   6H
	MOVWF   PORTB
	CALL    CLOCK
;Program starts now.
BEGIN   CALL           CLRDISP
	MOVLW          8H       ;Cursor at top left, 80H
	MOVWF          PORTB
	CALL           CLOCK
	MOVLW          0H
	MOVWF          PORTB
	CALL           CLOCK
	CALL            M               ;display M
	CALL            DELAYP1         ;wait 0.1 seconds
	CALL            I               ;display I
	CALL            C               ;Etc.
	CALL            DELAYP1
	CALL            R
	CALL            DELAYP1
	CALL            O
	CALL            DELAYP1
	CALL            C
	CALL            DELAYP1
	CALL            O
	CALL            DELAYP1
	CALL            N
	CALL            DELAYP1
	CALL            T
	CALL            DELAYP1
	CALL            R
	CALL            DELAYP1
	CALL            O
	CALL            DELAYP1
	CALL            L
	CALL            DELAYP1
	CALL            L
	CALL            DELAYP1
	CALL            E
	CALL            DELAYP1
	CALL            R
	CALL            DELAYP1
	CALL            S
	CALL            DELAYP1
	CLRF            PORTA
	MOVLW           0CH            ;Cursor on second line, C3
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	CALL            A
	CALL            DELAYP1
	CALL            T
	CALL            DELAYP1
	CALL            GAP
	CALL            T
	CALL            DELAYP1
	CALL            H
	CALL            DELAYP1
	CALL            E
	CALL            DELAYP1
	CALL            GAP
	CALL            M
	CALL            DELAYP1
	CALL            M
	CALL            DELAYP1
	CALL            U
	CALL            DELAYP1
	CALL            DELAY3          ;wait 3 seconds
	CALL            CLRDISP
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           0H
	MOVWF           PORTB
	CALL            CLOCK
	CALL            C
	CALL            DELAYP1
	CALL            O
	CALL            DELAYP1
	CALL            N
	CALL            DELAYP1
	CALL            T
	CALL            DELAYP1
	CALL            A
	CALL            DELAYP1
	CALL            C
	CALL            DELAYP1
	CALL            T
	CALL            DELAYP1
	CLRF            PORTA
	MOVLW           0CH             ;Cursor on 2nd line
	MOVWF           PORTB
	CALL            CLOCK
	MOVLW           3H
	MOVWF           PORTB
	CALL            CLOCK
	CALL            D
	CALL            DELAYP1
	CALL            A
	CALL            DELAYP1
	CALL            V
	CALL            DELAYP1
	CALL            E
	CALL            DELAYP1
	CALL            GAP
	CALL            DELAYP1
	CALL            S
	CALL            DELAYP1
	CALL            M
	CALL            DELAYP1
	CALL            I
	CALL            DELAYP1
	CALL            T
	CALL            DELAYP1
	CALL            H
	GOTO            BEGIN
END
spondootre is offline
Old 1st November 2006, 12:46 PM   #2
wow...that looks a little simplified and over fussy for controlling an lcd module...
I'm sure there is far better code than that available to you...
try using Nigel's code, or go to the piclist and snag some from there or something...
tunedwolf is offline
Old 1st November 2006, 12:54 PM   #3
Any idea what's wrong with this code though? I would like to use another code but I am very new to this and would prefer to find help with this code first before moving on. I can't figure out where there's a problem.
Old 1st November 2006, 01:05 PM   #4
DER!!!
I missed out a line!!
__CONFIG H'3FF0'
Old 8th November 2006, 03:03 PM   #5
Please check Delaying. Each LCD command need to delay for a while to operate.
Microcontroller Programming Forums:
http://forum.mcuprogramming.com
Answer to your questions!
Microcontroller Programming Blog:
http://mcu-programming.blogspot.com
uC - News, Resources and Tutorials
sci-3d is offline
Old 8th November 2006, 03:45 PM   #6
You should find a new example. That is terrible. Have a look at Nigels Tutorial on LCDs.
Pommie is online now
Old 8th November 2006, 05:00 PM   #7
if you have problem with lcd, please try this:
Set LCD Data port
DEFINE LCD_DREG PORTB
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTB
' Set LCD Register Select bit
DEFINE LCD_RSBIT 1
' Set LCD Enable port
DEFINE LCD_EREG PORTB
' Set LCD Enable bit
DEFINE LCD_EBIT 0
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
pause 100
lcdout $fe,1,"Hello"
end
LCD Connection
Pin1=Vss: connect to ground
Pin2=Vdd: connect to Vcc=5V
Pin3=Vo: connect to middle pin of the POT(20K) to control brightness
Pin4=RS(register select): connect to micro pins that specify in the software(RB1)
Pin5=RW(Read/Write): connect to ground because we want to only write
Pin6=E(Enable): connect to micro pin that specify in the software(RB0)
Pin7 to 10: No connection
Pin 11 to 14: connect to RB4 to RB7
Pin15: connect to Vcc with a resistor(100 or 200 ohm resistor is good)
Pin16: connect to ground.
pin 16 and pin 16 are for backligh
this a very simple code for lcd.if you don't have problem with this program so you have problem in another part.
amindzo is offline
Old 8th November 2006, 05:22 PM   #8
But it's not much use if you don't have the same BASIC compiler as you, and you don't even mention what it is?.
Old 8th November 2006, 07:53 PM   #9
you are right. he writes his program in assembelly.
amindzo is offline
Old 9th November 2006, 08:03 AM   #10
SF ftw!
digital-diy.com - Hobby microcontroller projects and tutorials. Assembly, PICBasic and C examples.
gramo is offline
Old 9th November 2006, 08:30 AM   #11
Thanks for all the replies,
I am just learning from the very beginning about programming PIC, I use assembly language as I feel I can relate to it better than other languages, I have no previous programing experience and understood nothing about registers etc. Thanks to this site and others including Nigels very excellent tutorials I am having more eureka moments!! I am now making an electrical flush system with LCD display for a toilet, i've adapted and written new code for this and it works fine on the breadboard. Next is photo etch the board and install it!!
Old 9th November 2006, 10:41 AM   #12
Originally Posted by spondootre
I am now making an electrical flush system with LCD display for a toilet.....
I hope, for your sake, and the others that use the toilet, that your code is more stable than my first attepts, could get very messy!!!
I am dying to know what messages you are going to put on your LCD!
Regards
MATT!
Matt(Pic progger) is offline
Old 9th November 2006, 10:48 AM   #13
LOL, no daft messages on the finished project!! Although I have had a few choice phrases while testing. I have been working with the ISD2532 playback/record chip on another project and had thoughts of adding sound effects to it.........but i'm not going to!! It isn't for my home so it has to be sensible!! I could add a small fanfare for 1 million flushes!!
Old 9th November 2006, 02:22 PM   #14
maybe ya need a strain gauge
Old 29th April 2008, 09:42 AM   #15
help Program 18F4520 with LCD
PhamDongPhuoc is offline
code, lcd, problem
problem with timer code nicoli Micro Controllers 5 9th November 2005 01:27 AM
Problem with Code: Help Electrix Micro Controllers 7 29th September 2005 08:42 PM
Tough assembly program for the PIC16F84 asmpic Micro Controllers 34 3rd December 2004 07:50 PM
weird pic code problem Fletcher Micro Controllers 9 13th October 2004 03:39 PM
An error in pic16f84a, why? Zener_Diode Micro Controllers 6 11th April 2004 03:55 AM
