Old 11th October 2006, 04:14 PM   (permalink)
Wink Microcontroller Insystem Programmer
Hi Everybody
I have planned to do a project using 8052. I dont have any kit to write program into that. So I want an insystem Programmer to write into it. Also I want the circuit for connecting with PC. Also circuit to know how other pins has to be connected???
I have some information which I can share to those who want to know. Others please share wat u know....
Ganeshkumar is offline
Old 11th October 2006, 04:20 PM   (permalink)
Have you checked google.com ? Should be plenty there.
mramos1 is offline
Old 11th October 2006, 04:46 PM   (permalink)
Question I am using ATMEL AT89S8252
The fact is I have downloaded a software SP89 (>300kB). It uses Hex file to transfer to 8052. Can I know some simple software to write my own program in Asssembly and convert to .hex file???
Also circuit to know how all pins has to be connected??? Only some i knew. for ex. Clock, vcc,gnd.
Old 11th October 2006, 05:18 PM   (permalink)
http://www.8052.com/links.phtml is a good start.
mramos1 is offline
Old 17th October 2006, 02:29 AM   (permalink)
hi i am new member of this site but with lots of electronics exp.
any away, use the asim khan isp programer for easy and fast working.
i early test it you can go with ATMEL ISP but ITS parallel port cable conection dia is not found any where so best go with ASIM KHAN ISP.
ok regard.
NAME: MANISH MESHRAM [ MTECH IN VLSI ]
you will find me around you for similer problem
manish12 is offline
Old 17th October 2006, 01:09 PM   (permalink)
i use a programmer that i downloaded from www.8052.com give it a try... for creating hex code.. i suppose keil is the best software on the block
impossible says i'm possible
desperadogear is offline
Old 21st October 2006, 04:19 AM   (permalink)
Smile Hi Thanks Everybody
My first stage of the project is over. Thanks for Everybody...
I fused a sample program into it using SP89 n AEC n checked it. It works...
My next stage is to interface ADC0808 IC n show the analog voltage in a digital manner.. If possible send me any simple interfacing circuit. What to give in Clock pin of ADC0808. Can I use crystal clock if available???
Thankssss
Old 21st October 2006, 04:41 AM   (permalink)
NO dont use the xtal if its frq>680kHz , if used use the some buffer or cmos driver / inverter between adc and xtal pin.
best is use adc 0804 for single ana. input. it use the r & c for clk geration.
if more than 1 input use 4051.
Or adc0808 use 555 as clk genretor.
ok
manish12 is offline
programmer! 4electros Micro Controllers 8 12th November 2007 08:48 PM
PIC programmer & WinPicProg: my findings eblc1388 Micro Controllers 5 27th August 2005 12:13 PM
PIC Programmer through COM and ICSP (JDM ??) test1 Micro Controllers 6 12th October 2004 09:06 AM
MicroController P87LPC762 Programmer igor_yoshida Micro Controllers 0 23rd April 2004 01:17 AM
