Old 11th October 2006, 04:32 AM   #1
Question Need help with LCD 16x2 hitachi HD44780 and 16f84a
Hi every one! this is my first post here..
Im trying to send from the pic a line text " hello" to the LCD. My first try was successfull with PIC SIMULATOR IDE. I programmed the code and used the LCD simulator..and it showed: "Hello". Today I programmed the code using Micro code studio plus and Pic basic pro.
This is an extract from Micro code studio Help about LCDOUT
PICBasic asumes the LCD is connected to specific pins unless told otherwise. It assumes the LCD will be used with a 4-bit bus with data lines DB4 - DB7 connected to PICmicro PORTA.0 - PORTA.3, Register Select to PORTA.4 and Enable to PORTB.3. It is also preset to initialize the LCD to a 2 line display.
so iīve used this diagram with the exeption that i connected ra4 directly to RS pin in LCD, and iīve connected to MCLR with Vdd with a 10k resistor, the capacitor for contrast in the LCD is a 10k one, the vss pin in the micro is connected directly to ground and vdd pin directly to +5v:
this is my code:
pause 1000
loop:
High PORTB.2 ' turn on a Led
pause 500
LCDOUT $FE, 1, "Hello"
low PORTB.2 ' turn off the led
pause 500
goto loop
end
i didnīt use DEFINE coz according to the LCDOUT statement iīve showed to you, from Microcode studio help. The diagram and the code are just what i need. Just for the record: iīve read all the info in the internet about interfacing pics and LCD
The LCD isnīt showing anything. But the led is actually working.
Can anybody help me???
evilsent is offline
Old 11th October 2006, 05:26 AM   #2
Have you included the resistor from RA4 to Vdd? This is needed as RA4 is an open collector output and can therefore only pull the output low.
Pommie is online now
Old 11th October 2006, 06:43 AM   #3
No i havenīt included the resistor, is it mandatory in order to make things right??? and if itīs so..itīs a 4700 = 4.7k resistor??. Iīm gonna try with this resistor. Thanks 4 the advice. Is anything else wrong with my project???
Thanks 4 the help Mike.
evilsent is offline
Old 11th October 2006, 07:40 AM   #4
Yes, you need the resistor. 4700Ω =4.7kΩ but anything around that value will work (2k to 20k).
Old 11th October 2006, 08:08 AM   #5
please try this:
' Set LCD Data port
DEFINE LCD_DREG PORTB
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTB
' Set LCD Register Select bit
DEFINE LCD_RSBIT 1
' Set LCD Enable port
DEFINE LCD_EREG PORTB
' Set LCD Enable bit
DEFINE LCD_EBIT 0
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
pause 100
lcdout $fe,1,"Hello"
end
LCD Connection
Pin1=Vss: connect to ground
Pin2=Vdd: connect to Vcc=5V
Pin3=Vo: connect to middle pin of the POT(20K) to control brightness
Pin4=RS(register select): connect to micro pins that specify in the software(RB1)
Pin5=RW(Read/Write): connect to ground because we want to only write
Pin6=E(Enable): connect to micro pin that specify in the software(RB0)
Pin7 to 10: No connection
Pin 11 to 14: connect to RB4 to RB7
Pin15: connect to Vcc with a resistor(100 or 200 ohm resistor is good)
Pin16: connect to ground.
pin 16 and pin 16 are for backlights
the other two pins of pot should connect to VCC and ground and you should connect the MCLR with a 4.7K or 10K resistor to the VCC.
amindzo is offline
Old 11th October 2006, 01:52 PM   #6
Please try this,
Answer the question that was asked.
Old 11th October 2006, 04:04 PM   #7
Thank you guys for helping me...iīll try your suggestions when i get home...and iīll let you know what happened.
greetings
evilsent is offline
Old 11th October 2006, 05:47 PM   #8
 ' Set LCD Data port
DEFINE LCD_DREG PORTA
DEFINE LCD_DBIT 0
The schematic uses the lower 4 bits of PORTA
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
William At MyBlueRoom is offline
Old 12th October 2006, 01:05 AM   #9
william, you said that the schematic that i used, uses the lower 4 bits of porta.
What does it mean?? i Thought that when you set:
DEFINE LCD_DBIT 0
it means that you wanna use DB0-DB3 as data bus. Or it really means the pins at the port specified. PORTA.0, PORTA.1.......,PORTA.3 in the PIC?????
Because now i followed the schematic im my breadboard and nothing happened..well the led works fine....and the LCD at least turns on all lines showing almost transparents squares.
Is because of the code????
And if its my code..can anyone show me a code for this schematic that actually works?
Thank you all!
evilsent is offline
Old 12th October 2006, 02:15 AM   #10
It should work as it is.
Here is the example code from http://www.melabs.com/resources/samples/pbp/lcd.bas
' PicBasic program to demonstrate operation of an LCD in 4-bit mode
' LCD should be connected as follows:
'       LCD     PIC
'       DB4     PortA.0
'       DB5     PortA.1
'       DB6     PortA.2
'       DB7     PortA.3
'       RS      PortA.4 (add 4.7K pullup resistor to 5 volts)
'       E       PortB.3
'       RW      Ground
'       Vdd     5 volts
'       Vss     Ground
'       Vo      20K potentiometer (or ground)
'       DB0-3   No connect
        Pause 500       ' Wait for LCD to startup
loop:   Lcdout $fe, 1   ' Clear LCD screen
        Lcdout "Hello"  ' Display Hello
        Pause 500       ' Wait .5 second
        Lcdout "World"
        Goto loop       ' Do it forever
As you can see the only thing that could be wrong is the omission of the pullup on RA4. If it doesn't work then check your wiring.
Old 12th October 2006, 03:40 AM   #11
im sure that the wiring between lcd and the pic is correct, im sure my code is correct as the one mike posted. The thing is that when the pic start to work..the lcd show me the 2 lines with all the pixels "on" in all of the 16 positions. What i did next was to disconect the wires from LCD...except the ground, +5v, and contrast. And the LCd just show one line with all the pixel "on"
. IS it normal??? or my LCD is damaged??
I dont know what else to try....
edit: i tried the code above and nothing the same thing happened :'(
evilsent is offline
Old 12th October 2006, 03:56 AM   #12
It looks like your LCD is OK. The reason you only see 1 line with only power connected and 2 lines with the pic connected is that the pic is initializing the LCD to be a 2 line unit. Can you adjust the contrast from all black through to all light?
Old 12th October 2006, 04:42 AM   #13
IT WORKS!!!!!!!! the reason that it wasn working was coz the 10k POT was defective..i tried to adjust the contrast and nothing happened...i change te pot and everything goes fine!!!!!!!!!
Thank you people for all the help u gave me!!!
Thanks mike! thanks william at the blue room and to amindzo
evilsent is offline
Old 12th October 2006, 05:56 AM   #14
Hi every body,
the lcd connection that pommie siad is a default one(that don't need any define in software) and if you want to connect lcd to PORTB or PORC and so, on you should define the lcd parameters as i said befor.
it is better to make a 100 or 150 ms delay to make the lcd ready befor you want to write on lcd.
amindzo is offline
Old 12th October 2006, 10:55 AM   #15
Default lcd 16*2
can i groung the vss pin3 ,then what will be the result of lcd brightness?
rshafi68 is offline
16f84a, 16x2, hitachi, lcd
