http://www.maxstream.net/products/xb...ule-zigbee.php just reading up on them, the pro version will transmit > 2,400 ft and only costs $32US, check out some range tests here: | ||
My problem with the rfPIC's is mostly how much external circuitry they require, particularly the receivers. | ||
| | (permalink) | ||
Microchips App notes I'm going to use to help are: AN238 = Tire Pressure Monitoring (TPM) System.pdf AN826 = Crystal Oscillator Basics and Crystal Selection for rfPIC and PICmicro® Devices.pdf AN831 = Matching Small Loop Antennas to rfPIC™ Devices.pdf AN846 = Basic PLL Filters for the rfPIC™ _rfHCS.pdf TB069 = rfPIC12F675 Transmitter Module.pdf TB070 = rfRXD0420 Receiver Module.pdf rfPIC Development Kit 1 User's Guide.pdf Here is a page from the datasheet showing a "typical" apllication for the rfPIC...
__________________ Well paint me purple and call me BARNEY!! Last edited by Polkie; 8th October 2006 at 06:38 PM. | |||
| Polkie. I have ordered samples from Microchip. I was going for some DSP Pics next. Maybe I will get two of those as well. But like Nigel said. Complex extra circuit for the TX/RX. Also for my use it would be remote. I could drop a sealed lead-acid battery on it. The Xbee-pro has quite a range and you just use serial I/O with it. So for the extra couple of dollars you save a ton of time. Just a thought. | |
| hai friends do any one done simple project on rfid .if so please mail me.my id is sasi.s.kala@gmail.com | |
| Hi, I have same problem as you. I am also using the same microcontroller rfpic12f675. and also using the MPLAB ICD2 for program controller. but i m not able to program this controller using this ICD2. So if u have solve problem can u send me the circuit to connect ICD2 with microcontroller. i have done connections mention in microchip site. but still problem comes. so help me in this matter. Thank You, Keyur Parekh | |
| hi can anybody help how to program rfpic12f675 controller using MPLAB ICD2? and if possible can anybody send me circuit for the connection of mplab icd2 and microcontroller. i need urgently. | |
| Read the datasheet. It says how to connect it up and the it should be ok
__________________ Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? | |
| Look at the date of the thread, you are answering a VERY VERY old thread. | |
| Yea it was the Old Me... I think I had more hair then | |
