Old 3rd October 2006, 10:46 PM   (permalink)
Default Programming 16F628A
I used to use this circuitry
to program the 16F628 PIC using FPP. It doesn't work with the 16F628A.
What to change (hw and sw) to program this kind of device
konservatorium is offline
Old 4th October 2006, 04:05 AM   (permalink)
Have a look at http://www.winpicprog.co.uk which also uses the parallel port. You will need to build a new programmer to use the WinPicPro software but all the info you need is on that site.
kchriste is offline
Old 4th October 2006, 05:32 AM   (permalink)
Thank you for your suggestion. I do not need to design and build a new circuitry but I need to adjust the values for the program to work with my device.
Currently WPP treats the device as it wasn't there. Do you see the problem's cause on the attached screenshots ?
Old 4th October 2006, 05:55 AM   (permalink)
The 16F628A and 16F628 use totally different programming algorithms....
Your problem is that you need to select 16F628A instead of 16F628:
kchriste is offline
Old 4th October 2006, 08:30 AM   (permalink)
If only he had to select 16F628A then I don't think he had asked. The following is the device list included in FPP.
DEVICE device[] = {             /* list of known devices and sizes */
    {"16F83", 83, 512, 64}, {"16F84", 84, 1024, 64},
    {"16F85", 85, 1024, 64}, {"16F86", 86, 2048, 64},
    {"16F627", 627, 1024, 128}, {"16F628", 628, 2048, 128},
    {"16F870", 870, 2048, 64}, {"16F871", 871, 2048, 64},
    {"16F872", 872, 2048, 64}, {"16F873", 873, 4096, 128},
    {"16F874", 874, 4096, 128}, {"16F876", 876,  8192, 256},
    {"16F877", 877, 8192, 256}, {NULL, 0, MAXPM, MAXDM}
The FPP programming software was created in 2001 and does not in its device list has the newer "A" types of PIC which require a different algorithm to program them. I have the feeling that Nigel's WinPicPro is a more updated or expanded version based on FPP judging by the hardware menu.
Since you have tried using WinPicPro but it does not work, you have no choice but to upgrade your hardware. Perhaps you can try searching on the NET for other successful programming arrangement using very few parts. Have a look on the following thread.
Yet another PIC parallel port programmer
Edited: Added pointer to another thread related to a simple parallel port programmer
L.Chung
eblc1388 is offline
Old 4th October 2006, 09:04 AM   (permalink)
No, I've never heard of FPP - I suspect he showed screen shots from both programs - and WinPicProg far predates FPP, WinPicProg was the worlds first Windows based PIC programmer (long before MicroChip moved to Windows).
Old 4th October 2006, 09:09 AM   (permalink)
Have a look on this link I found. I saw "David Tait" on the webpage heading.
software (FPP) for programming PIC microcontrollers
L.Chung
eblc1388 is offline
Old 5th October 2006, 12:28 AM   (permalink)
The 16F628A and 16F628 use totally different programming algorithms....Your problem is that you need to select 16F628A instead of 16F628
Good idea, I also came to this conclusion before.
This programmer is to be used with another program than FPP; I used it with FPP and it worked. It is similar to DT's "Quick and Dirty". Additionally I don't know if it doesn't work at all. This is why I uploaded these two screenshots for you to understand what was entered/adjusted wrong.
Have a look at this link. The screenshot I uploaded not being titled FPP is showing WPP's properties.
I don't understand your intention. Please explain.
Old 5th October 2006, 08:42 AM   (permalink)
That post is meant to show Nigel how I have found the "FPP" program.
L.Chung
eblc1388 is offline
Old 6th October 2006, 01:05 AM   (permalink)
Which circuitry do you recommend ?
Old 6th October 2006, 08:51 AM   (permalink)
Parallel port PIC programmer P16PRO40, detail webpage link in Nigel Goodwin's signature.
Built several, all worked first time.
L.Chung
eblc1388 is offline
Old 6th October 2006, 09:02 AM   (permalink)
"P16PRO programmer for PIC16Cxx microcontrollers by Bojan Dobaj".
I am using the 16F628A.
Old 6th October 2006, 08:48 PM   (permalink)
The PIC16F628A can be programmed with any "Tait" programmer, if that microcontroller is supported by the software. A couple of suggestions:
1) use the 7406 inverting buffers or the 7407 non-inverting buffers, because they have high voltage open collector outputs;
2) update the original design by adding a resistor to pull PGM to ground.
I use this programmer: www.eeng.biz/ppp_e.htm with PIC16F628A, PIC16F88, PIC12F675 (Vpp = 12.7 V)
eng1 is offline
Old 20th October 2006, 04:39 PM   (permalink)
Interesting.
Does this programmer (STK200 Programmer) work with the 16F628A ?
Old 20th October 2006, 04:47 PM   (permalink)
I wouldn't have thought so?, it's not a PIC programmer of any kind!.
UNIT Committment solution using Dynamic programming arijit18 Electronic Projects 1 18th October 2007 09:28 PM
Help with problem programming 16F628A ukatv Micro Controllers 8 25th September 2007 09:23 PM
Standalone Pic Programmer Using ICSP or RS232 Neiwiertz Micro Controllers 11 27th May 2006 02:23 AM
16f628a programming only got 16f628 support will it work? lompa Micro Controllers 6 18th December 2004 06:51 PM
