| Inchworm ICD2 Assembly Manual (First Draft) i download "blueroomelectronics Inchworm ICD2 Assembly Manual in PDF" i want to bulit it, if some one already built single side PCB of its so plz post it for me if he don't mind. Thanks | |
There should be posts as I did the board (garage version with laser printer to copper board layout) as Bill posted the PCB (Bill is the Blueroom fellow that designed it). Mike K8LH helped me out on it as well. Search the forums here (not google). Search for ICD2 and inchworm. | |
| | #3 | |
i download the file Quote:
But there is no PCB in this file. I want to use Toner transfer method for making PCB. I need Single Side PCB if some one already made it then help me plzz if he don't mind. Second! Is there any mistake in the circuit which is in the above file... Last edited by Ayne; 3rd October 2006 at 08:31 AM. | ||
I'd rather hand wire a small project like the inchworm (that's how I built the prototype) than etch & drill a PCB. I've been debating selling the blank PCBs, $14 + S&H You'd still need a way to program the initial 16F877A though.
__________________ Bill Home of the Firefly PIC Tutor Inchworm ICD2 http://www.blueroomelectronics.com | |
| | #6 | |
| | #7 | |
The whole thing sells with all the parts sans case for only $39 US, PCB + 16F877A approx $25. Guess I could, thanks for the suggestion Nigel. How's your Inchworm working?
__________________ Bill Home of the Firefly PIC Tutor Inchworm ICD2 http://www.blueroomelectronics.com | ||
| | #8 | ||
| | #9 | |
Black traces and white background | ||
| | #10 |
Nigel is right on the chip. That is a good idea. Mike K8LH sent me one programmed. Ayne, load it in a graphic program and flip it to black and white, or select the dark green and hit delete. That is what I did. But for $14 maybe just order one. They are BLUE and professionally done. | |
| | #11 | ||
the picture is not in only two colors Quote:
And the second is shiping problem therefore i can't buy. | |||
| | #12 |
Ayne, you should fill in your location in the profile. I Bill does not have one, I will find the one I converted post it. | |
| | #13 |
Here's a .PDF 1:1 not mirrored, I've never tested this version. Check the transistor orientation.
| | #14 |
Thank u "William At MyBlueRoom" ..
| | #15 |
You're welcome
| icd2, inchworm, pcb |
| Inchworm ICD2 Assembly Manual (First Draft) | William At MyBlueRoom | Micro Controllers | 12 | 7th November 2006 09:37 AM |
| Inchworm ICD2 in 3D! | William At MyBlueRoom | General Electronics Chat | 8 | 16th August 2006 02:04 PM |
| ICD2 USB, have a error, pls help me ! | Congty | Micro Controllers | 4 | 2nd August 2006 12:46 PM |
| Inchworm ICD2 Bootstrap loader BETA | William At MyBlueRoom | Micro Controllers | 15 | 31st July 2006 06:53 PM |
| icd2 picdem2 plus | jijita | Micro Controllers | 2 | 10th September 2004 04:18 PM |
