Old 26th September 2006, 12:44 PM   #1
Default Input Counter Pic16F84A (Code problems)
My goal with this project i'm working on is to count the number of times a button is pressed in a timespan eg 1 second. These are the 2 approaches i've used that are simulated succesfully, but don't work when put on the chip
The first thing i tried is using the interrupt on RB0, when that was triggered it went into a loop for a couple seconds, then every time the interrupt was triggered it incremented a counter and at the end of the delay it used the counter value in a table to get which port to set to high.
Again, that worked in my simulations, but not on the chip.
The next approach i used was to use Timer0, and increment the counter just using RB0 but not as an interrupt. Put it in a loop looking for Rb0 to go high/low, and when the timer overflowed check the counter value against the table, but again my attempts have failed.
Has anyone got any idea as to what i'm obviously missing, as i am fairly new to pic programming. The latest code follows.
org			0x00	;This is where the PC points to on power up & reset
;**********************SETUP CONSTANTS***********************
INTCON		equ 0x0B	;Interrupt control register
TMR0		equ	0x01
STATUS		equ 0x03	;Banks
OPTION_REG	equ	0x81	;Option Reg
PC			equ 0x02	;Set Program Counter to 02h for table data
TRISA		equ 0x85	;Tristate A
PORTA		equ 0x05	;Port A
TRISB		equ 0x86	;Tristate B
PORTB		equ 0x06	;Port B
SWITCHCOUNTER		equ 0x0C
COUNTER		equ 0x0D
COUNTER2	equ 0x0E
COUNTER3	equ	0x0F
TEMP		equ	0x10
goto		main
;************************INTERRUPT ROUTINE*******************
org			0x04
	movwf	TEMP
	movlw	0x04
	subwf	SWITCHCOUNTER,W
	btfss	STATUS,0
	goto	carry_on
	goto	clear
retfie
carry_on
	movf	TEMP,w
	call	table
	movwf	PORTA
	call	Delay2		;This delay is the button press length
	call	ClosePorts
	call	SetVars
	bcf		INTCON,2
retfie
clear
	call	SetVars
	bcf		INTCON,2
retfie
main
;*****************SETUP INTERRUPT RESGISTERS*****************
bsf			INTCON,7	;Set the Global interrupt switch
bsf			INTCON,5	;TMR0 interrupt enabled
bcf			INTCON,2	;INTF - Clear flag
;**********************SETUP THE PORTS***********************
bsf			STATUS,5	;Switch to bank 1
movlw		0x01		;Set W to 000001
movwf		TRISB		;Put W into TRISB
movlw		0x00		;Set W to 000000
movwf		TRISA		;Put W into TRISA
movlw		b'11010100'
movwf		OPTION_REG
bcf			STATUS,5	;Switch to bank 0
call	SetVars
intLoop
	btfss	PORTB,0
	goto	intLoop
	call	Delay3
	btfsc	PORTB,0
	goto	$ -1
	incf	SWITCHCOUNTER
	call	enableInt
goto intLoop
SetVars
	clrf	TEMP
	clrf	SWITCHCOUNTER
	movlw	0xFF
	movwf	COUNTER
	movlw	0xFF
	movwf	COUNTER2
	movlw	0xFF
	movwf	COUNTER3
	call	disableInt
return
Delay2
	Loop2		decfsz	COUNTER,1
		goto 	Loop2
		decfsz	COUNTER2,1
		goto	Loop2
return
Delay3
	Loop3
		decfsz	COUNTER,1
		goto 	Loop3
return
ClosePorts
	bcf		PORTA,0
	bcf		PORTA,1
	bcf		PORTA,2
return
disableInt
	bcf		INTCON,7
	bcf		INTCON,5
return
enableInt
	clrf	TMR0
	bcf		INTCON,2
	bsf		INTCON,7
	bsf		INTCON,5
return
table
	movf	SWITCHCOUNTER,w
	addwf 	PC,1
	retlw	0x00
	retlw	0x01
	retlw	0x02
	retlw	0x04
end
loco is offline
Old 26th September 2006, 01:05 PM   #2
First off, the 16F84 is LONG! obsolete, it was replaced by the 16F628 last century!.
Your interrupt code is very badly flawed, you don't do any context saving and restoring, so it will corrupt your main program. Also, you have THREE 'retfie' instructions, it's good practice to only have one of these.
What about key debouncing?, if you don't debounce them you'll get multiple counts for every press.
Old 26th September 2006, 01:12 PM   #3
yeah that's the problem living in africa, we're about a century behind everyone else :P I'll look into improving those factors, thank you for your help, this is my first time using interrupts so i'm not all clued up. Let me give these suggestions a bash. Thanks
loco is offline
Old 26th September 2006, 01:53 PM   #4
If you check my LED multiplexing tutorials, you'll see examples of context saving and restoring.
Old 26th September 2006, 02:19 PM   #5
Ok, as far as i can tell, i've added some debounce code, tidied the interrupt up a bit, it still has 2 retfie's tho. It works with in the simulation, but goes crazy when i put it in the circuit, i have 3 led's hooked up to RA0, RA1 and RA2, the theory is that when i press the button once RA0 lights up for x time, when i press it twice RA1, and 3 times RA2. But in the circuit it doesn't do that at all? The led's just randomly flash for a while, and aren't very responsive to the button presses?
TMR0		equ	0x01
PCLATH		equ	0x0A
COUNTER		equ 0x0D
COUNTER2	equ 0x0E
COUNTER3	equ	0x0F
TEMP		equ	0x10
s_temp		equ	0x11
w_temp		equ	0x12
p_temp		equ	0x13
goto		main
org			0x04
	movwf	TEMP
	movwf	w_temp
	swapf	STATUS,W
	movwf	s_temp
	movfw	PCLATH
	movwf	p_temp
	movlw	0x04
	btfss	STATUS,0
	goto	carry_on
	goto	clear
carry_on
	movf	TEMP,w
	call	table
	movwf	PORTA
	call	ClosePorts
	call	SetVars
	bcf		INTCON,2
	movfw	p_temp
	movwf	PCLATH
	swapf	s_temp,W
	movwf	STATUS
	swapf	w_temp,f
	swapf	w_temp,W
retfie
clear
	call	SetVars
	bcf		INTCON,2
	movfw	p_temp
	movwf	PCLATH
	swapf	s_temp,W
	movwf	STATUS
	swapf	w_temp,f
	swapf	w_temp,W
retfie
main
movlw		b'11010100'
movwf		OPTION_REG
call	SetVars
intLoop
	btfss	PORTB,0
	goto	intLoop
	call	Delay3
	btfss	PORTB,0
	goto	intLoop
	btfsc	PORTB,0
	goto	$ -1
	call 	Delay3
	btfsc	PORTB,0
	goto	$ -1
	incf	SWITCHCOUNTER
	call	enableInt
goto intLoop
SetVars
	clrf	TEMP
	clrf	SWITCHCOUNTER
	movlw	0xFF
	movwf	COUNTER
	movlw	0xFF
	movwf	COUNTER2
	movlw	0xFF
	movwf	COUNTER3
	call	disableInt
return
Delay2
		goto 	Loop2
		decfsz	COUNTER2,1
		goto	Loop2
return
Delay3
	Loop3
		decfsz	COUNTER,1
		goto 	Loop3
return
ClosePorts
	bcf		PORTA,0
	bcf		PORTA,1
	bcf		PORTA,2
return
disableInt
	bcf		INTCON,7
	bcf		INTCON,5
return
enableInt
	clrf	TMR0
	bcf		INTCON,2
	bsf		INTCON,7
	bsf		INTCON,5
return
table
	addwf 	PC,1
	retlw	0x00
	retlw	0x01
	retlw	0x02
	retlw	0x04
end
loco is offline
code, counter, input, pic16f84a, problems
Problems with PIC16F84A qty Micro Controllers 1 14th October 2005 07:36 AM
Break out of loop? 1Steveo Micro Controllers 4 4th February 2004 02:46 PM
some testing code.... of code of 89C51 for LCD kumar_3k Electronic Projects Design/Ideas/Reviews 0 5th November 2003 06:23 PM
input output code for C# 20303675 Electronic Projects Design/Ideas/Reviews 0 17th August 2003 03:33 PM
