| Dear frinds I want to conect the PIC16c745 to USB flash disk with USB port on PIC that i can write the file on flash disk and then read this file by PIC or PC How I can do this? please introduce to me a sample project with PIC source code Thanks very much | |
| 2 things... 1. PIC16C745 should be considered as obsolete, they are really old and useless now. Consider a 18F2550, 18F4550 or anything else in the 18F serie 2. A pic can't host a USB device.
__________________ Steve | |
| Dear Steve Thank you very much Yes, they are useless but I can not provide the 18F series. About section two why the PIC with USB port can not host the USB device we know that both of them have USB port. Would you explain your reason? | |
| Hi Mark, USB is quite complex and supports many different transfer modes. I did a quick scan of the datasheets and I think the USB hardware in those PIC's is limited to supporting slow speed interrupt transfers, and they are designed as endpoint devices only. To connect to a USB disk you would need to make a USB host, this is quite different from an endpoint device, and it would have to support bulk transfer mode. Even if you managed to write a cut-down host controller in software you would also need to implement one of several possible mid-level protocols such as SCSI, ATAPI, RBC, UFI etc.. the choice of which one would be dependant on the make model of flash disk you were using as not all flash disks use the same protocol, and some are not even publicly available standards. Then there is the filesystem to consider. I suspect you want the flash disk to be readable by a PC ? If so you are going to need some code to handle this. e.g a FAT driver. I've thought about a project like this in passing, seems to be quite a lot of work to do IMO. I don't want to discourage you tho! | |
| what you need to use... to reduce pain, is a piece of hardware like that http://www.crownhill.co.uk/product.php?prod=1577 Never use it as now.. but it suppose to do the job.
| i agree. Also you could have only the IC... mmm http://www.crownhill.co.uk/product.php?prod=1578 And the builder of.. http://www.ghielectronics.com/
