i try to use pic18f452 as analog to digital i programme it and i get successful programming by IC- prog but when i t try to convert analog to digital i do not get any thing in the PORTC i use RC oscillator and pin#2(AN0) is analog input and Vref+,Vref- are the same Vdd&Vss... this is the code: List p=18f452,f=inhx32 #include <p18f452.inc> org 0x0000 clrf PORTC movlw 0x00 movwf TRISC movlw B'11000000' movwf ADCON1 movlw B'11000001' movwf ADCON0 again: bsf ADCON0, GO Wait: btfsc ADCON0,GO ;Wait for conversion to complete goto Wait movf ADRESH,W ;Write A/D result to PORTC movwf PORTC ;LEDs goto again end why i do not get the result of converting analog to digital in the portC and how we can get it... is the problem from code or circuit | |
Ok, if you load your code into MPLAB (www.microchip.com) and run it, you will see the following error generated.... "ADC-W0010: A Minimum of 2 TADs are required before another conversion should be started." In other words, you need to leave a delay before starting another conversion. Depending how fast you are clocking this device, will depend on how long you need to wait. So something like...... clrf 0x30 wait_2tad: decfsz 0x30,f goto wait_2tad ;wait 256 clks This will wait 256 clks, but this may be too short/long, check it out ![]() Also a..... movlw 0x7f movwf TRISA After (or before) your TRISC wouldn't go amis, I know it's supposed to power-up as inputs, but it's good practice to included it. Just another problem waiting to get you is that this processor has 2 inturupt vectors at 0x04 and 0x08, if you put code into these areas and don't disable all the int's then fun things will start to happen! ![]() Just go over the data sheet again, pages 181->187, it takes you step by step through the ADC. I may have also missed the setting of another register, just got that feeling PIC's have a habit of not playing nice, and the data sheets don't always spell it out (well only after you know what went wrong, and you find it!).Anyone else got any input (i.e. tell me what I have missed!)? List p=18f452,f=inhx32 #include <p18f452.inc> org 0x0000 clrf PORTC movlw 0x00 movwf TRISC movlw 0x7f movwf TRISA movlw B'11000000' movwf ADCON1 movlw B'11000001' movwf ADCON0 again: bsf ADCON0, GO Wait: btfsc ADCON0,GO ;Wait for conversion to complete goto Wait movf ADRESH,W ;Write A/D result to PORTC movwf PORTC ;LEDs clrf 0x30 wait_2tad: decfsz 0x30,f goto wait_2tad ;wait 256 clks goto again end Hope this helps
__________________ Regards MATT! | |
In addition to the wait that Matt added, there should be one wait routine right after the point where you turn the A/D on. The sample and hold capacitor needs time to charge when first turned on and after every sample. Another thing you are doing is moving your the high bite of your acquisition to PORTC when you are set up to right justify your conversion. Change ADCON1 to B'01000000' to make it left justified. That way the all of the MSBs will reside in ADRESH. | |
See, I KNEW I had forgotton something Thanks phalanx
| | #5 | |
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. | ||
| | #6 |
I am new to actually programming the pic, but my question is I am trying to build a project where I input an analog from an audio jack to the Pic18452 and then use the AD in the pic to get a Digital signal, which will be transferred to nrf24L01+, which should transfer it to another nrf24L01+ (should be set as a receiver) and use the Pic18452 to output the digital as analog to the audio jack or whatever source. Right now I am trying to compile the code and I am getting an error in the line List p=18f452,f=inhx32 can someone provide me information on what does that mean or direct me where to read, I am willing to learn, and please if anyone can provide me any tutorials to a project similar to this. | |
| adc, pic |
