Old 31st July 2006, 10:50 PM   #1
Default PIC Switch Management Techniques
Dear fellow Designers/Hobbyists,
Has anyone else struggled to write code to debounce and manage multiple push button switches in the PIC environment? If so, and you've come up with a clever or innovative technique, would you consider sharing it with us here on the Forum, please? We'd love to study it. Thanks.
In that spirit I'd like to share a technique I've developed to process up to 8 switches in parallel in my applications. In a nutshell, it's 27 lines of ISR code that provides the following features/capabilities;
<> process up to 8 switches in parallel
<> eight independent 24.0-msec "debounce" vertical counters
<> debounced switch press audible feedback (beep or click)
<> momentary switch operation (test then clear a SWITCH bit)
<> toggle switch emulation (push to toggle a SWITCH bit from off-to-on or from on-to-off) perfect for lighted switches
I discovered early on that if I set a switch pressed "memory" or "latch" bit to the last state of the switch that I could determine a couple different conditions. Specifically, if the live switch bit is on and the switch memory bit is off I'm detecting a new switch "press", and if the live switch bit is off and the switch memory bit is on I'm detecting a new switch "release". Translating this into ISR code to detect new switch presses for up to 8 switches in parallel, I came up with this (the SWITCH variable contains pressed switch flag bits for MAIN);
;  toggle SWITCH variable switch pressed flags for MAIN
        movf    SWLIVE,W        ; live switch bits for 8 switches
        xorwf   SWPEND,W        ; xor switch pressed latch
        xorwf   SWPEND,f        ; update switch pressed latch
        andwf   SWLIVE,W        ; get new switch pressed bits
        xorwf   SWITCH,f        ; toggle SWITCH flag bits for MAIN
I thought the code was pretty cool considering the size (grin). The MAIN program simply tests a SWITCH flag bit and clears it for "momentary" switches and simply tests a SWITCH flag bit for push button switches emulating "toggle" switches (push the switch to toggle the SWITCH flag bit from on-to-off or from off-to-on). I use "toggle" switch emulation for lighted push button switches.
Next I added code to send audible feedback for "new" switch presses;
;  send short beep for "new" switch presses
        andwf   SWLIVE,W        ; any new switch pressed bits?
        btfss   STATUS,Z        ; no, skip, else
        bsf     BEEPER,5        ; send 32-msec short beep
;  beep (500-Hz tone with 1.0-msec interrupts)
        movf    BEEPER,W        ; is beep on?
        bz      ISR_Next        ; no, branch, else
        btg     Speaker         ; toggle speaker on PORTA,3
        decf    BEEPER,f        ; decrement beep msec counter
ISR_Next
Not bad for a handful of instructions but there's something missing. These 8 switches aren't debounced. How the heck can you provide independent debounce timers for 8 switches? I was sure it could be done but I suspected that it wouldn't be very pretty (grin). That's when I discovered vertical counters. They were difficult for me to grasp at first and I won't go into details here but refer you instead to Scott Dattalo's examples. Here's the final fully debounced example ISR code;
;  Mike McLaren's "debounce" vertical counter ISR code based
;  on concepts and examples from Jonny Doin and Scott Dattalo
;  <> process up to eight switches in parallel
;  <> eight independent 24.0-msec "debounce" vertical counters
;  <> debounced switch press audible feedback (beep or click)
;  <> momentary switch operation (test then clear a SWITCH bit)
;  <> toggle switch emulation (push to toggle a SWITCH bit from
;     off-to-on or from on-to-off) perfect for lighted switches
;  27 words/27 cycles (14-bit core)
;  setup the SWKEYS variable with "live" switch press data from
;  your switch input pins or your scanned switch matrix before
;  falling into this routine.  A '1' bit represents a 'pressed'
;  switch and a '0' bit represents a 'released' switch.
;  execute this code each 1.0-msec interrupt cycle
;  clear vertical counters for bouncing and steady-state switches
ISR_Sw
        movf    SWKEYS,W        ; live switch press data          |B0
        xorwf   SLATCH,W        ; debounced pressed switch latch  |B0
        andwf   VCBIT0,f        ;                                 |B0
        andwf   VCBIT1,f        ;                                 |B0
;  cyclic vertical counter algorithm.  vcmask is seeded with an
;  active switch mask and bn' is the previous state of bn before
;  the bit increment operation.
;  a switch is debounced or filtered after sampling it at the
;  same level through four vertical counts spanning 24.0-msecs
;    b0 ^= (vcmask)
;    b1 ^= (vcmask & b0')
;    b2 ^= (vcmask & b0' & b1')
;  Mike McLaren's "cumulative AND" vertical counter method
;    b0 ^= vcmask : vcmask &= bo'
;    b1 ^= vcmask : vcmask &= b1'
;    b2 ^= vcmask
        andwf   COLPOS,W        ; 8-msec 'column' prescaler       |B0
        movwf   VCMASK          ; seed "cumulative AND" mask      |B0
        xorwf   VCBIT0,f        ; b0 ^= vcmask                    |B0
        xorwf   VCBIT0,W        ; restore b0' in W                |B0
        andwf   VCMASK,W        ; vcmask &= b0'                   |B0
        movwf   VCMASK          ;                                 |B0
        xorwf   VCBIT1,f        ; b1 ^= vcmask                    |B0
        xorwf   VCBIT1,W        ; restore b1' in W                |B0
        andwf   VCMASK,W        ; vcmask &= b1'                   |B0
;  each '1' bit in the SLATCH variable represents a "debounced"
;  24.0-msec switch press (bit cleared when switch is released)
        xorwf   SLATCH,f        ; update debounced state latch    |B0
;  send a 32-msec short beep for new debounced switch presses
        andwf   SWKEYS,W        ; new debounced switch press?     |B0
        btfss   STATUS,Z        ; no, skip, else                  |B0
        bsf     BEEPER,5        ; send 32-msec short beep         |B0
;  toggle SWITCH flag bits for processing by the MAIN program
;  test SWITCH bits for emulated "toggle" switches.  test then
;  clear SWITCH bits for "momentary" switches.
        xorwf   SWITCH,f        ; toggle SWITCH bits for MAIN     |B0
;  advance ring counter prescaler (initialized value = 00000001)
;  for the next interrupt cycle
        rlf     COLPOS,W        ; advance column ring counter     |B0
        rlf     COLPOS,f        ;                                 |B0
        movf    BEEPER,W        ; beep timer set?                 |B0
        bz      ISR_Next        ; no, branch, else                |B0
        movf    GPIO,W          ; read port                       |B0
        xorlw   1<<Speaker      ;                                 |B0
        movwf   GPIO            ; toggle piezo speaker pin        |B0
        decf    BEEPER,f        ; decrement timer                 |B0
ISR_Next
This small "debounce" vertical counter ISR code has turned out to be so handy that I use it for switch management even on the simplest projects that might only have one or two switches. And managing lighted push button switches emulating "toggle" switches is a breeze (push on, push off).
Those of you interested in vertical counters should check out Scott Dattalo's examples and a "vertical counter" thread on the MC Forum.
Have fun. Kind regards, Mike
Mike, K8LH is offline
Old 1st August 2006, 09:18 AM   #2
The answer should be obvious- you need an independent debounce counter for each pin.
So you either say:
if(pinDebounceFlags!=0x00){
    unsigned char i;
    for(i=0;i<8;i++){
        if(pinDebounceCounter[i]>0){
            --pinDebounceCounter[i];
            if(pinDebounceCounter[i]==0){
                 pinDebounceFlags&=~(0b1<<i);
or you can go with a timer solution, which is preferred since the debounce period remains constant even when the processor has to do other tasks.
Oznog is offline
Old 28th September 2006, 01:33 PM   #3
Just brought the code in the first post up-to-date.
I also have example vertical counter ISR code now with debounce and repeat capability, if anyone's interested. It's relatively small and tight at 48 words and provides a 512-msec repeat rate for designated repeat keys. It's kind of nice to designate a pair of repeat switches on-the-fly and simply push and hold them to increment or decrement displayed values instead of repeatedly pushing them (then I un-designate them as repeat switches when done).
Regards, Mike
management, pic, switch, techniques
