Old 30th July 2006, 02:50 PM   (permalink)
Default Serial Communication between two pic micro
I have a problem with serial communication. I want to send a byte to the reciver by Rf transmitter and reciever.I read the sensor data and pic16F873A send it to RF transmitter and then RF reciever take it to the pic16F873A in reciever circuit.
maby you said the reoson is the errors would be occurs in RF transportation.
but i coonect two micro by a wire and also i have aproblem. and in the reciever lcd don't show any number or a wrong number.
wire that i use is short.
what is the problem?
is it in my software?
i write it in pic basic.
i write my program for transmitter and reciever.
could you help me with this?
tarnsmitter:
define OSC 4
include"modedefs.bas"
trisb= %00000000
x var byte
y var byte
i var byte
pause 2000
x=23
y=2
for i=1 to 10
serout PORTB.7,N1200,[y]
serout PORTB.7,N1200,[x]
next i
end
reciever:
define OSC 4
' Set LCD Data port
DEFINE LCD_DREG PORTC
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTC
' Set LCD Register Select bit
DEFINE LCD_RSBIT 1
' Set LCD Enable port
DEFINE LCD_EREG PORTC
' Set LCD Enable bit
DEFINE LCD_EBIT 0
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
pause 100
lcdout $fe,1
trisb= %11111111
x var byte
y var byte
z var byte
start:
lcdout $fe,1
serin PORTB.5,N1200,[2],x
serin PORTB.5,N1200,[2],y
serin PORTB.5,N1200,[2],z
if (y=z) then
lcdout $fe,1,#y
endif
pause 5000
goto start
end
Amin Derazgisoo
amindzo is offline
Old 30th July 2006, 02:59 PM   (permalink)
You can't just send standard RS232 over an RF link, because it's AC coupled! - this is why coding systems are used, check my PIC RF tutorial.
Old 30th July 2006, 03:09 PM   (permalink)
i just read the data of the sensor and get it to pic and then micro take it to RF transmitter and in the reciever circuit,RF reciever get the serial date and give it to micro.
but i have aproblem. i also have a oproblem by connecting two micro by wire.
and there are alot of errors.
amindzo is offline
Old 30th July 2006, 06:02 PM   (permalink)
Begin with a simple wire solution and try to understand what you do first. Sure your program don't work. try the following
'    Transmitter
define OSC 4
include "modedefs.bas"
TRISB = 0
y var byte
z var byte
i var byte
y=20
z=200
LOW PORTB.7 ' set serial output to normal state
Pause 2000  ' settle delay
Start:
    for i=1 to 10
        serout PORTB.7,N1200,[2,y,z]
        next i
    goto Start
    end
'    Receiver
define OSC 4
trisb= %11111111
DEFINE LCD_DBIT 4
DEFINE LCD_RSBIT 1
DEFINE LCD_EBIT 0
DEFINE LCD_BITS 4
DEFINE LCD_LINES 2
pause 100
lcdout $fe,1
y var byte
z var byte
start:
    SERIN2 PORTB.5,N1200,[Wait(2),y,z]
    lcdout $fe,1,DEC y, DEC z
    goto start
    end
Once this one work, implement the RF... but you'll have to do more than that simple above. Reliable RF is not as simple as most might think.
mister_e is offline
Old 30th July 2006, 09:29 PM   (permalink)
i wrote your program but it didn't work.
amindzo is offline
Old 30th July 2006, 09:30 PM   (permalink)
assuming your errors are due to serial I/O on your direct connected pics, a couple of possibilities:
- running both with internal osc could result in too much baudrate error (you could be seeing up to double the spec'd error rate)
- what kind of wire are you using between them - twisted or parallel? running over other signal sources? route the wires away from signal sources.
- bypassed your power on both PICs?
lots of people do use straight async on RF TX/RX but there are issues. it can be made to work but you are better off using some sort of coding - manchester, for example.
philba is offline
Old 31st July 2006, 05:29 AM   (permalink)
I used 20M crystal for my work but it didn't work.when i used 4M crystal it works but it has errors.i want to use haming code .
i want to send about 10 bytes.i want to know that i should send each byte for example 10 times or
i send all of them 10 times?
i think my program is wrong.could you help me with this?
amindzo is offline
Old 31st July 2006, 07:05 AM   (permalink)
can't you put the data in a latch and then extract it with the second µC
Boscus is offline
Old 31st July 2006, 07:24 AM   (permalink)
what do you mean?
what should i do?
amindzo is offline
Old 31st July 2006, 07:56 AM   (permalink)
You should be able to use async to communicate between 2 pics. especially at 1200 baud. something else is not right here. I would chase this one down.
you have connected the grounds of the 2 circuits, right? why don't you post a schematic?
philba is offline
Old 31st July 2006, 09:26 AM   (permalink)
I am not familier with pic basic, can you connect the output of your TX chip to the PC? and use something like Hyperterminal to read the bytes coming from the TX chip, if this works ok then it's the RX that is at fault.
I am also wondering if the RX chip is expecting the data to be "flipped/inverted" such as would happen with an rs232 translation chip like the MAX232, if so then you will not have any joy until you flip/invert this data
You can write some simple RS232 routines in assembler (AKA bit-banging) that will let you communicate with a PC directly (only a 10K resistor needed), if you want an example of this then let me know. Is it possible to incorperate asm into pic Basic??
Basically I am trying to say, break down your problem into smaller chunks to try and find were the problem is........ As nigel has said, this won't help with radio, but you will learn along the way The main problem with radio is that when the TX (radio) module is not powered and active, you will see a lot of "noise" on the RX side, this is why basic serial comms won't work
Hope this helps
Regards
MATT!
Matt(Pic progger) is offline
Old 31st July 2006, 10:16 AM   (permalink)
i have coonectedn the grounds of 2 circuit but in real they should be far as each other about 10 meter so i can't connect the grounds of two circuits.
amindzo is offline
Old 31st July 2006, 10:42 AM   (permalink)
So are you saying that close together, with the ground connected, they work?
Regards
MATT!
Old 31st July 2006, 11:59 AM   (permalink)
in both situation they work with errors.
amindzo is offline
Old 31st July 2006, 12:00 PM   (permalink)
i thin i have problem with program.could you help me with this in picbasic?
amindzo is offline
