Old 26th June 2009, 01:58 AM   #31
Oh okay. But what do you mean by "proper" initialization? It's going through the registers that control the oscillator and setting the values.
dknguyen is offline
Old 26th June 2009, 02:08 AM   #32
That's what I mean. I just want a working example of an LED blinker for the dsPIC33. I just started with the dsPIC33 today. I usually use 8 bit devices.
solarwind is offline
Old 26th June 2009, 05:43 AM   #33
See my code in this thread.
kchriste is offline
Old 26th June 2009, 06:39 AM   #34
Many thanks, human.
Old 12th October 2009, 03:11 AM   #35
hey guys need sum help. is there any difference in programming between the dspic30f and dspic33f? i am well versed with AVR family.recently started with PIC. plz cld sum1 giv me links to C tutorials for dspic33f. urgent....
dracoz is offline
Old 12th October 2009, 05:57 AM   #36
Not much difference; more to do with different PIC features and peripherals than anything else. I posted some very simple 30F starter code here where as the link above was for a 33F. Are you already familiar with C or not? If not, a generic C tutorial would help also.
kchriste is offline
Old 13th October 2009, 07:18 AM   #37
i am familiar with C . have done projects on Atmel microcontrollers. m goin to use the dsPIC33FJ128MC804. ya i saw ur code before already. thanks for it. i guess il hav 2 studythe datasheet more thouroughly. jst got confused with some of the header files... i can use MPLAB IDE v8.36 for programming rite..? is there a simulator also available with it...?
thanks much appreciate
dracoz is offline
Old 13th October 2009, 09:44 PM   #38
Wow, major resurrection of zombie thread.
The way you declare interrupts is different from other PICs. Also the way of declaring the setting for the config "fuse" bits is different.
MPLAB Sim (part of MPLAB) works for 33F just like any other PIC chip.
You need to select the Linker script for your specific part, select the device under MPLAB's Configure tab, and add "#include <p33fxxxx.h>" at the top of the file.
Oznog is offline
dspic33f, whoopie
