| hi anyone knows the pin position of pic16f630 chip in P16PRO programmer? | |
| Never seen one?, but how many pins is it?, the P16PRO40 chip position depends on the number of pins. | |
| it is 14 pins | |
| It depends on the position of the ICSP pins on the device. The 16F630 would need to go in the 8-pin position and whatever software you're using should be smart enough to use VPP1 instead of VPP2. Good luck. Regards, Mike ![]() Last edited by Mike, K8LH; 8th July 2006 at 10:28 AM. | |
| thank you very much Mike | |
| i try to read the 16f630 using winpicprog, the result is all in 0000? the chip is from the talking car alarm. | |
| Does winpicprog support the 16F630? | |
| i don't know | |
| I don't have a parallel port on my laptop and I gave away my P16PRO40 so I'm not in a very good position to help you. Sorry. The WinPic800 software looks very nice and supports a ton of chips but it doesn't list the P16PRO40 hardware specifically. Looks like a couple hardware listings are identical though, including VPP1 and VPP2 selections. Perhaps someone else on the Forum could help you setup the P16PRO40 with it? Regards, Mike | |
| thanks again mike | |
| just a thought but isn't it likely that a PIC out of a commercial product has the code protect bit set? | |
| Good point. I missed that. | |
| oh,, okay, thanks is there a way that i can change the program in that write protected chip or should i erase it and put another codes in it? | |
