Old 30th June 2006, 08:17 PM   (permalink)
Default ICD2 Variable VPP?
In the original ICD2 schematic MC uses an MCP41010 digital pot connected to the '877 RB1, RB6, and RB7 pins for the SPI interface and driving an MC34063 switching regulator.
Does the ICD2 really control the VPP voltage? If so, is there any reason you can think of that would prevent me from designing a little 8-pin 12F683 boost regulator with an SPI interface that would emulate the 256-steps of the digital pot to provide the same "variable VPP" function in a single circuit for my ICD2-USB clone design?
TIA, Mike
Mike, K8LH is online now
Old 30th June 2006, 08:44 PM   (permalink)
Hi Mike,
I am designing new ICD2 clone as well and I have been thinking about this too. Although I do have the MCP part on the shelf, I will replace it with a simple trimmer set to 12.5V (this value works the best for me). I used to program 18F with 13V without problems, so fixed VPP shouldn't be a problem.
EDIT: 12F683 emulating MCP + DC-DC booster is just not worth the effort IMHO
"I share, thus I am"
Jay.slovak
Read this!
ICD2 Clone
Best PIC/DsPIC Bootloader
Read my Inchworm ICD2 review!
Jay.slovak is offline
Old 30th June 2006, 08:48 PM   (permalink)
Hi Jay,
So, what are you using to generate VPP?
Mike
Old 30th June 2006, 08:53 PM   (permalink)
Currently MC34063 but will switch to (simplier) MAX632.
Jay.slovak
Read this!
ICD2 Clone
Old 30th June 2006, 11:37 PM   (permalink)
Ok, so you've got an IC and a trimmer (pot). That's cool.
I agree that it may be too much work/effort. If it could be done though, I think I'd prefer a single IC solution with ICD2 controlled variable VPP. Less board space, more control, great "cool" factor (grin).
Mike
Old 1st July 2006, 04:56 AM   (permalink)
TIA, Mike
Here's the MCP41010 in a ICD2 schematic from CZ...
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
William At MyBlueRoom is offline
Old 2nd July 2006, 05:30 PM   (permalink)
Yes, I've seen that schematic Bill. Thanks.
I was thinking about something like the drawing below. A single chip that emulates the 256-step MCP41010 digi' pot and provides the variable boost VPP output voltage.
Regards, Mike
Old 2nd July 2006, 05:36 PM   (permalink)
Doesn't the PICKIT1 already do that to generate the 13V Vpp from the 5V USB voltage?.
Old 2nd July 2006, 05:53 PM   (permalink)
Hi Nigel,
That PWM drive is right out of the PICKit2 schematic.
This circuit, if it can be done, would basically combine the function of the MCP41010 digital pot' and the MC34063 switching regulator from the original ICD2 design, all in a single IC. And, the ICD2 firmware is already set up to control it. Cool, huh?
Regards, Mike
Old 2nd July 2006, 06:00 PM   (permalink)
Hi Nigel,
Yep!, it certainly is!
Old 2nd July 2006, 06:56 PM   (permalink)
Should'nt there be feedback? I think since the ICD2 uses a linear PS and a LM317 once the voltage is set that's that.
But with a boost converter you'll have to monitor the output somehow dynamically...
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
Old 2nd July 2006, 07:30 PM   (permalink)
Please check out the original ICD2 schematic with MCP41010 and MC34063. The '877/A monitors the voltage via ADC and then adjusts the digi' pot. This should work, shouldn't it? Or should I consider 12F683 A2D PID loop to make it all that much more "bullet proof"?
Mike
Old 2nd July 2006, 08:18 PM   (permalink)
I would certainly add some sort of Feed-back to the 12F683 (and a suitable control algoritm). Without it, the generated voltage could change as the current draw changes.
Jay.slovak
Read this!
ICD2 Clone
Old 2nd July 2006, 08:34 PM   (permalink)
Hi Jay,
Do you think it's worth putting the effort into the project? I'm still not sure how the ICD2 firmware utilizes that digital pot control function. Does it actually vary VPP voltage depending on Target device?
Regards, Mike
Old 2nd July 2006, 08:43 PM   (permalink)
Hi Mike,
As I already said "12F683 emulating MCP + DC-DC booster is just not worth the effort IMHO".
It is very little known about ICD2s control over Vpp. My guess is, each firmware sets it's own Vpp (12.5V for 18F, 12F for 12F683, whatever) and keeps it that way. I think the value is Hard-coded in the Firmware.
PS: Don't take me wrong. I think that 12F683 solution is elegant. I just don't think developing it for saving one IC and build only one or two ICDs is a waste of your (precious) development time. But, if you were to make a thousand ICDs, price savings could be significant.
Jay.slovak
Read this!
ICD2 Clone
