Old 14th June 2006, 11:16 AM   #1
Default I/O output
How do I change a single bit value of a port? What is the syntax?
Manie is offline
Old 14th June 2006, 11:36 AM   #2
Depends what processor you're talking about, and what laguage you're using, your question is far too vague to answer!.
Old 14th June 2006, 11:37 AM   #3
I am using a PIC16f737 and programming in C
Manie is offline
Old 14th June 2006, 11:39 AM   #4
Can't help you with C, but in assembler it's simply:
bsf Port, pin
to set a pin high
bcf Port, pin
to clear a pin.
As it's such a basic thing to do, you should have suitable examples with your C compiler?.
Old 14th June 2006, 01:50 PM   #5
port_value = port_value | (1<< bitposition)
or
port_value |= (1<< bitposition)
Gods own Country
Incredible !ndia
www.flickr.com/photos/_akg/
"Give a man a fish, and he will eat for a day. Teach that man to fish, and he will eat for a lifetime."
akg is offline
Old 14th June 2006, 02:37 PM   #6
example:
setting PORTB bit 0
PORTB|=(1<<0);
setting PORTB bit 2
PORTB|=(1<<2);
clearing PORTB bit 2
PORTB&=~(1<<2);
Learning is a life-long process...
GraveYard_Killer is offline
Old 14th June 2006, 02:49 PM   #7
Check your C-compiler. Many of them have a declaration syntax for bits. If they do then the statement is just something like
bit  GIE  INTCON.7
GIE = 0 ; /* Disable Interrupts */
GIE = 1 ; /* Enable Interrupts */
The declaration syntax is not part of the C language standard, but several compilers for processors that support bit addressing have invented such extensions. You do have to look carefully in the compiler documentation though.
Look for #pragma keyword=extended or something similar to see if there is a switch that enables or disables the extended language features.
If you think you've found something then write a short test program and look at the compiler output to see if it matches both your understanding and Nigel's example.
On real ports with a mixture of inputs and outputs you need to be careful with bsf and bcf instructions because in hardware they read all 8 bits of a port, modify the single bit, and write back all 8 bits. This can be problematic and there are warnings in the PIC data sheets.
Let us know what you find.
Papabravo is offline
i or o, output
