| New Member | Greetings to everyone! I am new to the forum and I've been reading some interesting stuff on the message board. I need help, I am designing a real time clock using PIC16F877 and DS1302. I write the software using MPLAB assembler language. I am having a problem of setting time,date and day using assembler. The LCD display do not display anything. Can anyone help with an example code in assembler on how to set date, and time for DS1302 using PIC16f877. Your help is greatly appreciated. Yours Truly Ras Creation King |
| Experienced Member | to start with, you need to understand what your problem is. from reading your posting, it really sounds like your problem is with the LCD but it's hard to tell. You should follow a simple debugging process. isolate components and test them. try just init'ing the LCD and writing data to it. debug that. then test the 1302. debug that. then put them all together. debug that. there have been numerous threads on LCD debugging and 1302 debugging. try chasing those down first. |
| New Member | Thanks for the upful response! I have initialised the LCD and it works. What I did is, I programmed my name to be displayed on the LCD which works fine. I then clear the screen after 20seconds name display for display of time and date but could not display. Could you please tell me how to test DS1302(debugging) alone without microcontroller.I also read DS1302 Dallas datasheet on how to access the memory registers for setting time,date,year etc, but I could not understands on how to load settings(time,date etc) with PIC into DS1302. Your help is very appreciated. Yours Truly Ras Creation King |
| Experienced Member | there are tons of examples for this device. use google. search here as well. by the way, there is a high bit in one of the words that disables the device. I think it is in seconds register. You have to clear that bit to get it to work. |
| New Member | Quote:
I've done it, I used 16F877A and DS1307, display year, data, time on LCD 16x2.
__________________ Kiên quyết đi theo con đường mà Đảng và Bác Hồ đă chọn. | |
| New Member | Greetings beloved. Thanks for every help that I get from this forum. Could you please send me/post for me the code that you used for DS1307. I think the difference will not be that big with DS1302 that I am using. I think I will also learn a lot from your code on how this devices works. below is the program code that I am currently using but is not working, so I will appreciate any help....... ;Moeketsane TP ;20211902 ;BCD Clock using PIC 16f877 AND DS1302 Real time clock. ;The software is written to write my surname and student number, then writes time and date on LCD display LIST P=16F877 #INCLUDE<P16F877.INC> SDA EQU 0X06 SCL EQU 0X06 ;CONSTANT VARS=0CH 00010010 DAT_VAL EQU 0X0C NUM_VAL EQU 0X0D ADR_HI EQU 0X0E ADR_VAL EQU 0X0E DEV_ADR EQU 0X10 ; A2,A1,A0 _N EQU 0X11 O_BYTE EQU 0X12 I_BYTE EQU 0X13 LOOP1 EQU 0X14 LOOP2 EQU 0X15 RASTA EQU 0X21 CLOCK EQU 0X22 TELLER1 EQU 30H ;create a counter named teller1 TELLER EQU 21H ;CREATE A COUNTER FILE NAMED TELLER FLASH EQU 22H ;CREATE A GPR NAMED FLASH ORG 0X00 GOTO PICINIT PICINIT BCF STATUS,RP1 MOVLW 0X06 ;DISABLE COMPERATERS MOVWF ADCON1 ;MAKE SURE PORTA IS DIGITAL OUTPUT BSF STATUS,RP0 ;MOVE TO BANK 1 CLRF TRISA ;MAKE PORTA OUTPUTS CLRF TRISB ;MAKE PORTB OUTPUTS MOVLW B'00000111' ;MOVE BINARY VALUE TO W REGISTER MOVWF OPTION_REG ;PRESET COUNTER T0 256 BCF STATUS,RP0 ;MOVE BACK TO BANK 0 CLRF PORTA ;CLEAR PORTA CLRF PORTB ;CLEAR PORTB GOTO LCDINIT ;GOTO LCD CONFIGURATION SUBROUTINE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;LCD CONFIGURATION;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; LCDINIT CALL LONGDELAY ;CALL DELAY FIRST MOVLW 03H ;DIPLAY ON FIRST LINE MOVWF PORTB CALL ENABLE ;CLOCK DATA FROM PORTB TO THE LCD CALL LONGDELAY MOVLW 04H MOVWF PORTB ;CHANGE TO 4 BIT FIRST FOUR BITS CALL ENABLE ;CLOCK DATA CALL LONGDELAY MOVLW 04H MOVWF PORTB ;CHANGE TO 4 BIT SECOND FOUR BITS CALL ENABLE ;CLOCK DATA CALL LONGDELAY MOVLW 08H MOVWF PORTB ;2 LINE MODE, 5X7 DOT FORMAT CALL ENABLE ;CLOCK DATA CALL LONGDELAY MOVLW 0H ;CURSO ON, NOT UNDERLINED AND BLINK OFF MOVWF PORTB CALL ENABLE ;CLOCK DATA CALL LONGDELAY MOVLW 0CH MOVWF PORTB ;CLOCK DATA CALL ENABLE CALL LONGDELAY MOVLW 0H ;INCREMENT DISPLAY MOVWF PORTB CALL ENABLE ;CLOCK DATA CALL LONGDELAY MOVLW 6H MOVWF PORTB CALL ENABLE CALL LONGDELAY GOTO WRITE ;GOTO WRITE SUBRUOTINE TO WRITE DATA LONGDELAY CALL SHORTDELAY MOVLW 0X30 MOVWF TELLER TH1 DECFSZ TELLER,F GOTO TH1 RETLW 0 ;MOVLW 0FFH ;DELAY ;MOVWF TELLER1 ;MOVE VALUE FFH TO TELLER1 ;CALLBACK DECFSZ TELLER1,1 ;DECREMENT TELLER1 UNTIL IT IS 0 ;GOTO CALLBACK ;RETLW 0 SHORTDELAY MOVLW 0X22 MOVWF TELLER1 TH DECFSZ TELLER1,F GOTO TH RETLW 0 ENABLE BSF PORTA,2 ;SET ENABLE BIT NOP RETLW 0 ;;;;;;;;;;;;;;;;;THIS SUROUTINE IS TO MOVE THE FOUR UPPER BITS (03H) TO PORTB WHEN WRITING NUMBERS;;;;;;;;;;;;;;;;;;;;;;;; NUMBER_CHART MOVLW 2H MOVWF PORTA MOVLW 3H MOVWF PORTB CALL ENABLE RETLW 0 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;SUBROUTINE FOR WRITING OUT NUMBERS;;;;;;;;;;;;;;;;;;;;;;;;; STUDNUM ADDWF PCL,F ;ADD WORKING REGISTER TO PROGRAM COUNTER RETLW '0' ;RETURN WITH 0 TO W REGISTER RETLW '2' ;WRITE OUT NUMBER '2' RETLW '0' ;WRITE OUT NUMBER '0' RETLW '2' ;WRITE OUT NUMBER '2' RETLW '1' ;WRITE OUT NUMBER '1' RETLW '1' ;WRITE OUT NUMBER '1' RETLW '9' ;WRITE OUT NUMBER '9' RETLW '0' ;WRITE OUT NUMBER '0' RETLW '2' ;WRITE OUT NUMBER '2' ;;;;;;;;;;;;;;;;;;;;;;;;;;THIS SUBROUTINE IS TO MOVE FROM THE TOP LINE TO THE BOTTOM LINE;;;;;;;;;;;;;;;;;;;;;;;;;;;; LINE_2 CLRF PORTA ;CLEAR RS LINE TO ALLOW COMMANDS MOVLW 0CH ;WRITE OUT 0CH WICH ALLOWS THE COUSER TO MOVE TO THE BOTTOM LINE MOVWF PORTB CALL ENABLE CALL LONGDELAY MOVLW 00H MOVWF PORTB CALL ENABLE CALL LONGDELAY RETLW 0 ;;;;;;;;;;;;;;;;;;;;;;THIS SUBROUTINE IS TO WRITE OUT THE UPPER FOUR (04H) BITS FOR LETTERS A-O;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; UPPER_BITS MOVLW 2H MOVWF PORTA MOVLW 4H MOVWF PORTB CALL ENABLE RETLW 0 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;START TO WRITE CHARECTERS;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; WRITE BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'M' ;M MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'O' ;O MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'E' ;E MOVWF PORTB CALL ENABLE CALL LONGDELAY ;MOVLW 0H ;MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'K' ;E MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'E' ;K MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'T' ;E MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'S' ;T MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'A' ;S MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'N' ;A MOVWF PORTB CALL ENABLE CALL LONGDELAY BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'E' ;N MOVWF PORTB CALL ENABLE CALL LONGDELAY ;BSF PORTA,3 BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS MOVLW 'E' ;E MOVWF PORTB CALL ENABLE CALL LONGDELAY ;BCF PORTA,3 CALL LINE_2 ;MOVE FROM LINE 1 TO LINE 2 CLRF FLASH ;CLEAR TEMPORARY STORAGE FILE MOVLW D'8' ;MOVE VALUE 8 IN TELLER TO ALLOW THE NUMBER SUBROUTIN TO BE REAPEATED 8 TIMES MOVWF TELLER NUMBER BSF PORTA,1 ;SET RS LINE CALL UPPER_BITS ;CALL FIRST FOUR BITS INCF FLASH,F ;INCREMENT TEMPORARY STORAGE FILE MOVF FLASH,W ;MOVE FLASH TO W REGISTER CALL STUDNUM ;CALL NUMBER TABLE MOVWF PORTB ;MOVE DATA TO PORTB CALL ENABLE ;CLOCK DATA TO LCD CALL LONGDELAY ;CALL DEALAY DECFSZ TELLER,F ;DECREMENT TELLER UNTIL 0 MOVLW 0X00 MOVWF DEV_ADR SECONDS MOVLW 0X00 MOVWF RASTA MOVLW 0X00 MOVWF DAT_VAL CALL RANDOM_WRITE MOVLW 0X30 CALL DELAY_N_MS MINUTES MOVLW 0X01 MOVWF RASTA MOVLW 0X00 MOVWF DAT_VAL CALL RANDOM_WRITE MOVLW 0X30 CALL DELAY_N_MS HOURS MOVLW 0X02 MOVWF RASTA MOVLW B'01000010' MOVWF DAT_VAL CALL RANDOM_WRITE CALL DELAY_N_MS ;************************************************* ************************ ; THE FOLLOWING SUBROUTINE SET THE DATE IN FORMAT ;************************************************* ************************ DAYS MOVLW 0X03 ;ADDRESS FOR SETTING DAYS MOVWF RASTA MOVLW B'00000111' MOVWF DAT_VAL CALL RANDOM_WRITE MOVLW 0X30 CALL DELAY_N_MS MONTH MOVLW 0X04 ;ADDRESS FOR SETTING DATE MOVWF RASTA MOVLW 0X05 MOVWF RASTA ;ADDRESS FOR SETTING MONTH MOVLW 0X02 MOVWF DAT_VAL ;SET MONTH INTO FEBRUARY CALL RANDOM_WRITE MOVLW 0X30 CALL DELAY_N_MS YEAR MOVLW 0X06 MOVWF RASTA MOVLW B'01000110' MOVWF DAT_VAL CALL RANDOM_WRITE MOVLW 0X30 CALL DELAY_N_MS CALL RANDOM_READ DONE GOTO DONE RANDOM_WRITE BCF STATUS,5 ;WRITE DAT_VAL TO 16 BIT ADDRESS RLF DEV_ADR,W ;SEND THE ADDRESS BYTE IORLW 0A0H MOVWF O_BYTE CALL OUT_BYTE CALL NACK MOVF ADR_HI,W MOVWF O_BYTE CALL OUT_BYTE CALL NACK MOVF DAT_VAL,W MOVWF O_BYTE CALL OUT_BYTE CALL NACK CALL STOP RETURN ;************************************************* *********************** RANDOM_READ; THIS SUBROUTINE READS DATA AT SPECIFIED LOCATION AND RETURN ; THE RESULTS IN W. ;************************************************* *********************** CALL START BCF STATUS,5 RLF DEV_ADR,W IORLW 0A0H MOVWF O_BYTE CALL OUT_BYTE CALL NACK MOVF RASTA MOVWF O_BYTE CALL OUT_BYTE CALL NACK MOVF RASTA MOVWF O_BYTE CALL OUT_BYTE CALL NACK CALL START BCF STATUS,5 RLF DEV_ADR,W IORLW 0A1H ;R/W SET TO 1 FOR READ OPERATION MOVWF O_BYTE CALL OUT_BYTE CALL NACK CALL IN_BYTE CALL NACK CALL STOP MOVF I_BYTE,W RETURN ;************************************************* ******************* IN_BYTE CLRF I_BYTE MOVLW D'8' MOVWF _N CALL HIGH_SDA IN_BIT CALL HIGH_SCL BTFSS PORTB,SDA GOTO IN_ZERO GOTO IN_ONE IN_ZERO BCF STATUS,5 RLF I_BYTE,F GOTO CONT_IN IN_ONE BCF STATUS,5 RLF I_BYTE,F INCF I_BYTE,F GOTO CONT_IN CONT_IN CALL LOW_SCL DECFSZ _N,F GOTO IN_BIT RETURN OUT_BYTE MOVLW D'8' MOVWF _N OUT_BIT BCF STATUS,5 RLF O_BYTE,F BTFSS STATUS,5 GOTO OUT_ZERO GOTO OUT_ONE OUT_ZERO CALL LOW_SDA CALL CLOCK CALL HIGH_SDA GOTO OUT_CONT RETURN OUT_ONE CALL HIGH_SDA CALL CLOCK GOTO OUT_CONT RETURN OUT_CONT DECFSZ _N,F GOTO OUT_BYTE NACK CALL HIGH_SDA CALL CLOCK RETURN ACK CALL LOW_SDA CALL HIGH_SDA CALL HIGH_SCL CALL LOW_SDA CALL LOW_SCL RETURN START CALL LOW_SCL CALL HIGH_SDA CALL HIGH_SCL CALL LOW_SDA CALL LOW_SCL STOP CALL LOW_SCL CALL LOW_SDA CALL HIGH_SCL CALL HIGH_SDA CALL LOW_SDA RETURN BINGHI CALL HIGH_SCL CALL LOW_SCL RETURN HIGH_SDA BSF STATUS,7 BSF TRISB,SDA BCF STATUS,RP0 RETURN LOW_SDA BCF PORTB,SDA BSF STATUS,7 BCF TRISB,SDA BCF STATUS,7 CALL DELAY_SHORT RETURN HIGH_SCL BSF STATUS,7 BSF TRISB,SCL BCF STATUS,7 CALL DELAY_SHORT RETURN LOW_SCL BCF PORTB,SCL BSF STATUS,7 BCF TRISB,SCL BCF STATUS,7 CALL DELAY_SHORT RETURN DELAY_SHORT MOVLW D'10' MOVWF LOOP2 DELAY_SHORT1 NOP DECFSZ LOOP2,F GOTO DELAY_SHORT1 RETURN DELAY_LONG MOVLW D'50' DELAY_N_MS MOVWF LOOP1 OUTTER MOVLW D'110' MOVWF LOOP2 INNER NOP NOP NOP NOP NOP NOP NOP DECFSZ LOOP2,F GOTO OUTTER RETURN END LOOP GOTO LOOP ;MAKE ENDLESS LOOP WHEN WRITING IS COMPLETE Thanks for everyone's help and support Ras Creation King |
| New Member | You May look at proton pic basic a sample programe , simulator with proteus |
| Experienced Member | Hi Ras, Quote:
Regards, Robert Code: CONV_ASCII_RTN ; ASCII conversion routine SWAPF BUFFER1,W ; w now contains buffer1, with nibbles inverted ANDLW 0FH ; AND buffer1 with 1111 to get NIBBLE in lower bits ADDLW 30H ; add 30h (b'110000') to make ASCII MOVWF HiNibble ; save HiNibble MOVF BUFFER1,W ; move buffer1 back to W to get the high byte ANDLW 0FH ; AND buffer1 with 1111 to get NIBBLE in lower bits ADDLW 30H ; add 30h (b'110000') to make ASCII MOVWF LoNibble ; save LoNibble RETURN READ_SEC ; DS1302 read seconds register BSF IO_RST ; take IO reset high to initiate transfer MOVLW 81H ; binary is 10000001 read seconds command MOVWF BUFFER1 ; store it in the buffer CALL SHIFT_OUT ; and send to DS 1320 CALL SHIFT_IN ; read a bite from DS1320 BCF IO_RST ; IO_RST low RETURN READ_MIN ; DS1302 read minutes register BSF IO_RST ; take IO reset high to initiate transfer MOVLW 83H ; binary is 10000011 read minutes command MOVWF BUFFER1 ; store it in the buffer CALL SHIFT_OUT ; and send to DS 1320 CALL SHIFT_IN ; read a bite from DS1320 BCF IO_RST ; IO_RST low RETURN READ_HOUR ; DS1302 read hour register BSF IO_RST MOVLW 85H MOVWF BUFFER1 CALL SHIFT_OUT CALL SHIFT_IN BCF IO_RST ; IO_RST low RETURN READ_DAY ; DS1302 read day register BSF IO_RST MOVLW 87H MOVWF BUFFER1 CALL SHIFT_OUT CALL SHIFT_IN BCF IO_RST ; IO_RST low RETURN READ_MONTH ; DS1302 read month register BSF IO_RST MOVLW 89H MOVWF BUFFER1 CALL SHIFT_OUT CALL SHIFT_IN BCF IO_RST ; IO_RST low RETURN READ_YEAR ; DS1302 read year register BSF IO_RST MOVLW 8DH MOVWF BUFFER1 CALL SHIFT_OUT CALL SHIFT_IN BCF IO_RST RETURN DS1302_INIT_RTN SET_SEC ; Set seconds on DS1302 BSF IO_RST ; take IO reset high to init transfer MOVLW 8EH ; Write protect off bin 10001110 MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 00H ; Write protect on MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST ; toggle IO reset NOP BSF IO_RST ; IO_RST high MOVLW 80H ; Select second register MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT ; this needs to have a set_time var moved into W, rather than literal: ie 55h. ; MOVLW 55H ; This is the value seconds will be set at. MOVF CLOCK_SEC, W ; ***! UPDATED !*** MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST ; IO_RST low RETURN SET_MIN ; Set minutes on DS1302 BSF IO_RST ; take IO reset high to init transfer MOVLW 8EH ; Write protect off MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 00H ; Write protect on MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST ; toggle IO reset NOP BSF IO_RST MOVLW 82H ; b'10000010' is write minutes command MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT ; MOVLW 59H ; This is the value minutes will be set at. MOVF CLOCK_MIN, W ; ***! UPDATED !*** MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST ; IO_RST low RETURN SET_HOUR ; Set hours on DS1302 BSF IO_RST ; take IO reset high to init transfer MOVLW 8EH ; Write protect off MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 00H ; Write protect on MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST ; toggle IO reset NOP BSF IO_RST MOVLW 84H ; b'10000100' is write hour command. MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT ; MOVLW 22h ; This is the value that will be set in hours. 23H MOVF CLOCK_HRS, W ; ***! UPDATED !*** ; working here the time is set before entering the routine, so look for all calls to set_hour! MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST RETURN SET_DAY ; Set days on DS1302 BSF IO_RST ; take IO reset high to init transfer MOVLW 8EH ; Write protect off MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 00H MOVWF BUFFER1 CALL SHIFT_OUT BCF IO_RST ; toggle IO reset NOP BSF IO_RST MOVLW 86H ; b'10000110' is write date command. MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 31H ; This is the value that is set. MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST RETURN SET_MONTH ; Set months on DS1302 BSF IO_RST ; take IO reset high to init transfer MOVLW 8EH ; Write protect off MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 00H MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST ; toggle IO reset NOP BSF IO_RST MOVLW 88H ; '10001000' is write month command. MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 12H ; This is the value that is set. MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST RETURN SET_YEAR ; Set years on DS1302 BSF IO_RST ; take IO reset high to init transfer MOVLW 8EH ; Write protect off MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 00H MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST ; toggle IO reset NOP BSF IO_RST MOVLW 8CH ; b'10001100' is write year command. MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT MOVLW 01H ; This is the value that is set. MOVWF BUFFER1 ; send to ds 1320 CALL SHIFT_OUT BCF IO_RST RETURN SHIFT_IN ; Read a byte from the DS1302 and store it in BUFFER1 BSF STATUS,RP0 ; bank 1 MOVLW B'00000100' ; make b2 an input MOVWF TRISA BCF STATUS,RP0 ; bank 0 MOVLW .8 MOVWF LOOP_CNT1 ; initialize loop counter for 8 bits of data CLRF BUFFER1 ; clear the buffer BCF IO_CLK SH_2 BSF IO_CLK BCF STATUS,C BTFSC IO_DATA BSF STATUS,C BCF IO_CLK RRF BUFFER1, F ; rotate the buffer DECFSZ LOOP_CNT1, F GOTO SH_2 BSF STATUS,RP0 MOVLW B'00000000' MOVWF TRISA BCF STATUS,RP0 RETURN SHIFT_OUT ; DS1302 serial out routine MOVWF BUFFER1 MOVLW .8 MOVWF LOOP_CNT1 BCF IO_CLK SH_1 BTFSC BUFFER1,0 BSF IO_DATA BTFSS BUFFER1,0 BCF IO_DATA BSF IO_CLK RRF BUFFER1,1 BCF IO_CLK DECFSZ LOOP_CNT1, F GOTO SH_1 RETURN | |
| New Member | Give thanks Beloved! I will simulate the software today and test the breadboarding. I hope it will work fine and I will tell you of the outcome. Thanks again for all your efforts, I really appreciates it. Peace and Love Ras Creation King |
| New Member | Hi BeeBop, I studied your software and I hope it will work. One more thing, I don't see where you initialised LCD. If there is, just let me know. I will also try to incorporate it with LCD initialisation that I used in my previous program. I will let you know the outcom as soon as possible....Give thanks. Peace and Love Ras Creation King |
What I was doing was storing the time in variables when I read it, and I was using those to compare, and display the time. I will give you the routine to read the clock, but it isn't very good in that I have used more variables than necessary, so it is not very efficient. This is old assembly as I now would use 0x0F rather than 0Fh as is used in these routines. The routines come from a rather large application, and I'm not sure I ever finished the thing before I started using C to develop. Hope it is still useful for you. Regards, Robert Code: ;;;********************************************************************************************************** ;;; Subroutine Name: Readtime ;;; Description: Read the clock and store the time in vars. ;;; ;;; Requires: Three vars for each part of time - hours, minutes, seconds, ;;; day, month, year. ;;; Returns: An ascii char in each of the Hi/Low vars. ;;; Locations Affected: W and all the variables used. ;;;********************************************************************************************************** Readtime ; ***! LOOKS LIKE THIS COULD USE WORKING HERE SOON! !*** ; If I got rid of all the high low ascii vars, could also get rid of ; call convert to ascii and below in each! CALL READ_HOUR ; readTime rd_hrs MOVF BUFFER1, W ; load the raw data MOVWF BCD_HOURS ; STORE THE RAW VALUE CALL CONV_ASCII_RTN ; BCD to ASCII MOVF HiNibble, W ; NIBBLE MOVWF HOURS_H ; Store the high byte MOVF LoNibble, W ; NIBBLE MOVWF HOURS_L ; Store the low byte CALL READ_MIN ; readTime rd_min MOVF BUFFER1, W ; load the raw data MOVWF BCD_MINUTES ; STORE THE RAW VALUE CALL CONV_ASCII_RTN ; BCD to ASCII MOVF HiNibble,W ; NIBBLE MOVWF MINUTES_H ; Store the high byte MOVF LoNibble,W ; NIBBLE MOVWF MINUTES_L ; Store the low byte CALL READ_SEC ; readTime rd_sec MOVF BUFFER1, W ; load the raw data MOVWF BCD_SECONDS ; STORE THE RAW VALUE CALL CONV_ASCII_RTN ; BCD to ASCII MOVF HiNibble,W ; NIBBLE MOVWF SECONDS_H ; Store the high byte MOVF LoNibble,W ; NIBBLE MOVWF SECONDS_L ; Store the low byte CALL READ_DAY ; readTime rd_day MOVF BUFFER1, W ; load the raw data MOVWF BCD_DAYS ; CALL CONV_ASCII_RTN ; BCD to ASCII MOVF HiNibble,W ; NIBBLE MOVWF DAYS_H ; Store the high byte MOVF LoNibble,W ; NIBBLE MOVWF DAYS_L ; Store the low byte CALL READ_MONTH ; readTime rd_mth MOVF BUFFER1, W ; load the raw data MOVWF BCD_MONTH ; CALL CONV_ASCII_RTN ; BCD to ASCII MOVF HiNibble,W ; NIBBLE MOVWF MONTHS_H ; Store the high byte MOVF LoNibble,W ; NIBBLE MOVWF MONTHS_L ; Store the low byte CALL READ_YEAR ; readTime rd_yr MOVF BUFFER1, W ; load the raw data MOVWF BCD_YEAR ; CALL CONV_ASCII_RTN ; BCD to ASCII MOVF HiNibble,W ; NIBBLE MOVWF YEARS_H ; Store the high byte MOVF LoNibble,W ; NIBBLE MOVWF YEARS_L ; Store the low byte RETURN | |
| New Member | Hi BeeBop, Thanks for your quickest responses. I really appreciate all your efforts. I will try my best to incorporate your software with the LCD output as I want. I hope retrieving data(time, date, etc) from variables and display it on LCD would not be troublesome. I am using SDA and SCL of PIC 16f877 to communicate with DS1302. I will just set up and Oscilloscope on this pins to see if communiction does happen, what do you suggest? Thanks again for everything Ras Creation King |
| | (permalink) | ||
| Experienced Member | Hi Ras, Those routines are pretty 'rough,' and really should only be a starting point for you. Like I said, they were done long ago, and now I can see so many weak spots! I'll try and point out what those are, and give you some other info, which may be helpful. Quote:
Code: #DEFINE IO_RST PORTA,0 ; SERIAL DATA #DEFINE IO_CLK PORTA,1 ; SERIAL CLOCK #DEFINE IO_DATA PORTA,2 ; DATA IN/OUT Code: ;set up the ports
INIT_RTN
CLRWDT
BANK1 ; switch to bank one
MOVLW B'00000111' ; Port A all digital
MOVWF ADCON1
MOVLW B'00000000' ; B'00000000' 0X17 00010000
MOVWF TRISA ; Port A is output
MOVLW B'00001111'
MOVWF TRISC ; PortC is input/output
MOVLW B'00000000'
MOVWF TRISB ; PORTB is output
MOVWF TRISD ; PORTD is output
MOVWF TRISE ; PORTE is output
BANK0 ; switch back to bank zero Quote:
All of the routines which read the clock use a temporary file which is named buffer1, so you will need that. You will also notice lines like this: Code: ; MOVLW 22h ; This is the value that will be set in hours. MOVF CLOCK_HRS, W ; ***! UPDATED !*** You will notice in the 'Readtime' routine that each of seconds, minutes, etc is read, and the value returned in Buffer1. That value is then stored in variables such as BCD_HOURS, as a packed BCD byte. It also requires two variables, HiNibble and LoNibble, which are used to get an ascii value, and store the time as ascii, in variables like HOURS_H and HOURS_L. I'm sure it could all be done much more elegantly, with a lot fewer variables, but that will be your job. :-) I declared my variables like this: Code: ; The folowing are to store time CBLOCK 0x32 HOURS_H ; VARIABLE 32h HOURS_L ; VARIABLE 33h MINUTES_H ; VARIABLE 34h MINUTES_L ; VARIABLE 35h SECONDS_H ; VARIABLE 36h SECONDS_L ; VARIABLE 37h DAYS_H ; VARIABLE 38h DAYS_L ; VARIABLE 39h MONTHS_H ; VARIABLE 3Ah MONTHS_L ; VARIABLE 3Bh YEARS_H ; VARIABLE 3Ch YEARS_L ; VARIABLE 3Dh ... BCD_HOURS ; VARIABLE 45h change to BCD_SECONDS BCD_MINUTES ; VARIABLE 46h change to BCD_MINUTES BCD_SECONDS ; VARIABLE 47h COUNT_HOURS BCD_DAYS ; VARIABLE 48h COUNT_DAYS BCD_MONTH ; VARIABLE 49h COUNT_MONTH BCD_YEAR ; VARIABLE 4Ah 4Ah COUNT_YEAR ENDC ;***! 0x4A !*** Also, later I began using constants like these: Code: ; *************** DECLARE CONSTANTS ******************** ; *************** DS1302 CONSTANTS ******************** #define rd_sec 81h #define rd_min 83h #define rd_hrs 85h #define rd_day 87h #define rd_mth 89h #define rd_yr 8Dh #define wt_sec 80h #define wt_min 82h #define wt_hrs 84h #define wt_day 86h #define wt_mth 88h #define wt_yr 8Ch #define loctCmd 8Ch #define initCmd 8Ch #define clrCmd 8Ch #define HiConst b'00000010' #define LoConst b'00001001' #define twntThr b'00100011' Best wishes, Robert | ||
| New Member | Hi Robert, Thanks for your quickest responses. I really learn a lot from you. Beloved, I like the way you explain things as I now understands things that were my big problems like how to access registers of DS1302 to set time,date,etc.thanks for your help, But now I think I am getting lost. since my programm code had errors, I tried to assemble your code and simulate it to see what happens but unfortunately nothing. Could you please send me the code with LCD initialising and hope is working because now I think my code that I happen to include to your code might also have errors. I am really in need of your help as I must submit this project nextweek wednesday(I need it working). I have copleted all paper work(user manual, Technical manual and Design manual and Schematic layout). I know you have a lot of works to do, Please send me the code and I will do the rest. Thanks again for your support,guidance and inspirations Yours truly, Ras Creation King |
| Experienced Member | Hi Ras, I think you had best go over to Nigel's tutorials for that LCD. The one I used is serial - it is connected by one wire to the pic. Here: PIC programmer software, and PIC Tutorials at: http://www.winpicprog.co.uk Look at tutorial 3. If you give it a try and run into problems, you can get some help, but I think you need to do some coding which works with your hardware - I don't even know how your LCD is hooked up. It seems to be using 4bit mode. But, just in case you don't believe me, here are my LCD routines: Best wishes, Robert Code: ;********************************************************************************************************* ;* LCD SUBROUTINEs ;;;********************************************************************************************************** ;;; Subroutine Name: LOCATE_0_0 ;;; Description: Sends a command to serial LCD, ;;; calling for coordinates corresponding ;;; to ROW 0, COL 0. ;;; Requires: Nothing. ;;; ;;; ;;; Returns: Nothing. ;;; Locations Affected: W is destroyed. ;;;********************************************************************************************************** LOCATE_0_0 MOVLW 0A1H ; LOCATE command loctCmd 0,0 CALL SENDCHAR ; send to micro TX_PROC MOVLW 00H ; ROW 0(x location of display) (X axis is from 0 to 20.) CALL SENDCHAR ; send location to micro TX_PROC MOVLW 00H ; COL 0(y location of display) ( Y axis is from 0 to 3) CALL SENDCHAR ; send location to micro TX_PROC RETURN LOCATE_0_1 MOVLW 0A1H ; locate 0,0 command loctCmd CALL SENDCHAR ; send command to micro TX_PROC MOVLW 00H ; row 0 command CALL SENDCHAR ; send command to micro TX_PROC MOVLW 01H ; colume 1 command CALL SENDCHAR ; send command to micro TX_PROC RETURN CLEAR MOVLW 0xA3 ; clrCmd CALL SENDCHAR ; TX_PROC MOVLW 01H CALL SENDCHAR ; TX_PROC RETURN CURSOR_OFF MOVLW 0A3H ; cursor off command is 0xA30C, SEND 0xA3 CALL SENDCHAR ; SEND cursor off command TX_PROC MOVLW 0CH ; second part of cmd is 0x0C CALL SENDCHAR ; so send it TX_PROC RETURN CURSOR_ON MOVLW 0A3H ; cursor off command is 0xA30C, SEND 0xA3 ***! ??? !*** CALL SENDCHAR ; SEND cursor off command TX_PROC MOVLW 0CH ; second part of cmd is 0x0C CALL SENDCHAR ; so send it TX_PROC RETURN LCD_INIT MOVLW 0xA0 ; LCD initialization command is 0A0H initCmd CALL SENDCHAR ; send the command TX_PROC MOVLW .200 ; DELAY aroud 600US CALL DELAY_US ; wait for lcd RETURN LCD_STRING MOVLW 0A2H ; String command (PRINT) is 0xA2 CALL SENDCHAR ; send string command to micro TX_PROC RETURN PRINT MOVLW 0A2H ; string command (print) CALL SENDCHAR ; send command to micro TX_PROC RETURN END_STR CLRF FETCH_SEQ ; clear the variable FETCH_SEQ MOVLW 00H ; End of string COMMAND CALL SENDCHAR ; send command to micro TX_PROC RETURN ;;;***************************************************************************************************** ;;; Subroutine Name: COLON ;;; Description: Print a colon. ;;; ;;; Requires: sub- SENDCHAR. ;;; Returns: A colon on the LCD. ;;; Locations Affected: . ;;;***************************************************************************************************** COLON MOVLW 03AH ; COLON COMMAND CALL SENDCHAR ; TX_PROC RETURN ;;;***************************************************************************************************** ;;; Subroutine Name: SPACE ;;; Description: Print a blank space. ;;; ;;; Requires: sub- SENDCHAR. ;;; Returns: A space on the LCD. ;;; Locations Affected: . ;;;***************************************************************************************************** _SPACE MOVLW 20h ; 0C7H CALL SENDCHAR ; SENDCMD TX_PROC RETURN ;;; ********************************************************************************************************* ;;; Subroutine Name: SENDCHAR ;;; Description: SENDCHAR outputs a byte to the serial LCD. ;;; ;;; Requires: the char, in ASCII format, to be stored in W, before calling it.. ;;; Calls: DELAY_ONE. ;;; Uses variables BUFFER1, LOOP_CNT. ;;; Locations Affected: IO_TX pin, STATUS, BUFFER1. ;;; ********************************************************************************************************* SENDCHAR ; SERIAL OUT MOVWF BUFFER1 ; Send W reg to file BUFFER1 ; From tx procedure MOVLW .8 ; Because 8BIT transmission, MOVWF LOOP_CNT ; so count to 8 BCF IO_TX ; send low on lcd bus CALL DELAY_ONE ; wait 52 usec SEND_1 CLRWDT ; Clear the watchdog RRF BUFFER1, F ; rotate variable BUFFER1 to the right BTFSS STATUS,CF ; CF EQU .0 = STATUS BCF IO_TX ; IO_TX = PORTB,0 - first pin of B is lcd bus BTFSC STATUS,CF ; BSF IO_TX ; set lcd bus high CALL DELAY_ONE ; DECFSZ LOOP_CNT, F ; decriment the loop counter GOTO SEND_1 ; while there is still data o transmit, go back to SEND_1 BSF IO_TX ; lcd bus high CALL DELAY_ONE ; RETURN ;************************************************************************************************************** ;* DELAY SUBROUTINEs ;;;********************************************************************************************************** ;;; Subroutine Name: DELAY_ONE ;;; Description: Timer delay for serial LCD, ;;; 4800-> 208US Delay(64) , 192000->52US Delay (14) ;;; Requires: DELAY_US, DL_0. ;;; ;;; Returns: Nothing. ;;; Locations Affected: W is destroyed. ;;;********************************************************************************************************** DELAY_ONE ; MOVLW .14 ; 19200 Baud Rate ;MOVLW .64 ; 4800 Baud Rate DELAY_US MOVWF DELAY_TIMER DL_0 DECFSZ DELAY_TIMER, F GOTO DL_0 RETURN DELAY_MS MOVWF LOOP_CNT CLRF LOOP_CNT1 DE_1 DECFSZ LOOP_CNT1, F GOTO DE_1 DECFSZ LOOP_CNT, F GOTO DE_1 RETURN |
